safiyu and 26 unknown users
URGENT HELP NEEDED !
n°510
shaun001
Posted on 07-20-2010 at 11:47:06 PM
hello
i have a site problem i bet some one on here can fix this small issue
i am working on a small simple project i haven an 17" wide screen laptop so i have built my site around this screen
but if you look at it threw a 15" screen its all over the place the site is -      http://www.vickybutterflies.co.uk
i would be very greatfull if some one could help me out with this
many thanks
shaun  :cool:
n°511
peteandoreen1
Posted on 07-21-2010 at 11:01:50 AM
re-size to 1280x1024 or 800x600 then all will be well. I looked at your site with a 19" Monitor and same story all overt the place. The above sizes are pretty standard for this day.
n°512
Tanshin
Posted on 07-21-2010 at 09:51:49 PM
It's probably best to go for 1024x768 because operating systems like to default to that sometimes (older ones, new ones check for your optimum resolution). It's definitely the safest bet.
http://i15.photobucket.com/albums/a398/saladbar1/mystbar_cxp.png
n°513
shaun001
Posted on 07-22-2010 at 01:06:41 AM
i am new to all this i am just learning new things every day
so could you please tell me what i need to change
thanks
shaun
n°514
Tanshin
Posted on 07-22-2010 at 05:00:57 AM
It looks like you're having issues with your CSS. You've used absolute positioning that's relative to the page itself (or the window I guess). At some point tomorrow I'll poke through your CSS and code in depth to see what's going on where and try and get that straightened out for you. I'll explain what needed to be changed when I send it back your way.
(note to mods: Should probably be moved to M. Aid)
Message edited by Tanshin on 07-22-2010 at 05:01:18 AM
n°515
ghostnatyphon
Who Dares Wins
Posted on 07-22-2010 at 09:47:39 PM
(note to mods: yea it isn't a site or forum issue at all. but then again it's not a graphic request so it doesn't fit in there... in fact it doesn't fit anywhere. This reminds of something about requesting a code/programming area...)
I'm sorry, I couldn't help putting that out there, perfect chance to rant. :neutral:
http://img693.imageshack.us/img693/1117/april2010sigtest1.png
n°516
Tanshin
Posted on 07-22-2010 at 11:03:50 PM
Very true there Ghosty. I haven't gotten to do this yet today (doctors appointments, always fun).
n°517
Tanshin
Posted on 07-23-2010 at 05:50:32 PM
Actually, can you compress the directory you have for your site and send them to me? It's much easier than trying to get all of the assets from your site.
