22 unknown users
Forum Rules
n°167
Profil: Admin
Posted on 10-23-2008 at 10:11:31 AM
Usernames
Don't use rude words in your username
If you want to change your username, use the form in the account manager
Avatars and Sigs
Your signature should not be more than 320x80 pixels and should not exceed 40Kb. You can use a signature OR three userbars. If you use an image in your signature, DO NOT add too much text below (two lines).
Your Avatar should not be more than 128x128 pixels and should not exceed 40Kb!
If your avatar and sig are considered as chocking, illegal or run counter to the forum design (for example, animated sigs), they can be deleted.
Subjects titles
Use an explicit title! Subjects having title as "heeelp me" or "Great!!!" will be removed. Expose your question clearly. Also avoid descriptions in all capital letters!
Use square brackets to indicate more precisely the aim of your topic.
For example : [Wallpaper] Sunset in Miami
Add [Solved] at the beginning of your title when somebody has answered your question.
Your messages:
The sharing of files with copyrights is of course prohibited, like any message in connection with their obtaining.
Use search tool before posting a New Topic! It is indeed irritating to still answer the same questions again and again. So if you really do not find anything with search, then post your question.
Please, post only one time the same subject in the appropriate forum and not several times in various forums by thinking that you will have an answer faster.
The messages which are not in connection with the subject of the topic will be moved or removed! Also avoid flooding!
When you have a problem, try to give the maximum information so that one can solve it as soon as possible.
In all the cases try to be polite and courteous, you are in a public place. Do not use rude words. Messages or posts with vulgar words will be immediately removed
SMS Style messages are prohibited!! If SMS Style messages are seen, those members will be suspended or sometimes even banned !! A forum message should not be small like SMS. Your messages are not limited to 160 characters per message!! Moreover this forum is French/English: French people often use an online translator to see what is happening on the English Part of the forum (and conversely). However, online translators cannot translate these SMS style messages, therefore the sentences become incomprehensible.
All these rules are there to ensure the proper operation of the forum! Thank you for abiding these rules, in the contrary case, your account will be removed and your posting privileges will be taken off.
Message edited by Gruzz on 10-03-2009 at 03:52:07 PM
