44 unknown users
 Page :  1  2  3  4
[Forum] Report bugs V4.5
n°239
BostonPeng
Posted on 11-15-2008 at 10:00:41 PM
Thanks, Gruzz. The usability takes a bit of a hit when something simple like this is so hard to find. Just sayin'... ')
n°240
Posted on 11-16-2008 at 09:02:19 AM
True, but this topic might be a bad example to try this feature. It's much handier to use in a topic where you've put a question. Turn on e-mail notification, and you'll only get e-mails till your question is answered. After that, no-one revives the topic anymore, and you won't get any more messages. :)
n°241
BostonPeng
Posted on 11-16-2008 at 01:21:58 PM
Actually this was the perfect topic to try it on. I was monitoring it to see the response to the specific bug I had +1'd.
Too bad it didn't work, since I got the message that you had posted again. I think it's time to kill my account since I don't see myself using it that much any longer.
n°242
Posted on 11-16-2008 at 04:40:35 PM
Alright, I hope we have been of any help to you. :) Au revoir! ;)
n°247
Aqua Crystal
Posted on 11-23-2008 at 09:44:43 PM
I can't upload anything. I get to step 3 and then it just stops. The little loading thing in the middle works but nothing happens. Also it's not just a matter of patience as I sat around well over an hour waiting for it to work. :frown:
http://www.hotlinkfiles.com/files/2076000_jua8l/Signature.png
My Blog
n°249
Posted on 11-24-2008 at 06:59:51 AM
Is this regarding attachments in posts, or uploading to the gallery?
n°250
Aqua Crystal
Posted on 11-24-2008 at 06:11:07 PM
It regards uploading to the gallery.
My Blog
n°251
Posted on 11-24-2008 at 08:57:49 PM
Is there a specific category where you upload your file? :) I just tried uploading something, and it worked fine. :yes: Also, try turning off any P2P software you might be running.
n°252
legace
Posted on 11-25-2008 at 04:19:55 PM
What kind of file are you trying to upload? If it's a program, make sure the file-extension is .zip.
n°253
Aqua Crystal
Posted on 11-25-2008 at 08:46:05 PM
I said I was on step three so I'm uploading a preview image. However I will close any P2P programs and try again! :biggrin:
Edit: I'm afraid it didn't help.
Message quoted 1 times
Message edited by Aqua Crystal on 11-25-2008 at 09:03:34 PM
My Blog
n°254
Posted on 11-26-2008 at 08:07:41 AM
I know, but in what category are you uploading? :) Is it in Wallpapers, Themes, Dock skins, etc.?  :wink:
n°255
TheVestel
PHP Programmer
Posted on 11-26-2008 at 06:37:23 PM
Offtopic: Am I correct when I say that this topic is only for Forum bugs? :)
n°256
Vermi
MindHacker
Profil: Admin
Posted on 11-27-2008 at 11:54:08 AM
Request for test
Hello all,
Like many of you noticed it, it seems that there are some problems for uploading creations.
I made some modifications, but at my house, everything works (with all web browsers that I have).
So, I ask you to retry sending your creations, and tell me the error message that you received (if you have one).
If the upload stops without an error message again, this may be important information.
Describe to the maximum how the error takes place (file size which you are trying to send, if it appears instantly or after a time, if it appears by a random way or for the sake of some files, some creations…)
Post your bug reports on this topic, don't send it by MP.
Well, every information other than "that bug" will be welcome !
In advance, thanks to all those who help to delete these bugs on the site.
Message edited by Vermi on 11-27-2008 at 03:10:08 PM
n°257
Aqua Crystal
Posted on 11-27-2008 at 07:30:36 PM
I was refering to other person not you...
Any way it's a wallpaper in computer&os. The image is 911x569 and is 280kb. I have thought about shrinking it some more. Will that help?
My Blog
n°258
Vermi
MindHacker
Profil: Admin
Posted on 11-28-2008 at 04:27:26 PM
So, it's not the ZIP upload wich is bugged, I see. Thanks, I will take a look as fast as possible.
n°259
Aqua Crystal
Posted on 11-30-2008 at 11:28:24 PM
It's still not working. Have you taken a look at it yet?
My Blog
n°260
Vermi
MindHacker
Profil: Admin
Posted on 12-01-2008 at 12:05:39 PM
You can re-try, I had error handling again.
n°261
Aqua Crystal
Posted on 12-01-2008 at 07:19:52 PM
It still doesn't seem to be working. I don't know if my file is a format it doesn't like. I assume png's are ok.
My Blog
n°262
Vermi
MindHacker
Profil: Admin
Posted on 12-01-2008 at 09:05:22 PM
PNG's are ok, it's not the problem. I'm trying to know if the problem is in the page or not. The more I check, the more it seams to be before the page is called. It's very strange. I will double check if the page can leave without a message. I'll tell you when it will be done.
Thanks for your help.
n°263
Posted on 12-05-2008 at 09:21:35 AM
I am not sure if I should post this problem here :neutral: but admins may give me a reply on this
I tried to submit a creation and on 4th step , where .zip file is asked to upload, I am facing a problem , the 1.98MB file takes infinite time for uploading .I know my internet connection is not that bad , I uploaded on deviantart too but I can't upload it here , the preview files were uploaded but the zip file didn't :/ what could be the possible reason for this?
Igloo <---> DeviantArt
n°264
Vermi
MindHacker
Profil: Admin
Posted on 12-05-2008 at 11:46:48 AM
I made some bug fixes, can you re-try ?
n°265
Posted on 12-05-2008 at 04:04:21 PM
you are the man :D it just worked like a charm!
n°266
Vermi
MindHacker
Profil: Admin
Posted on 12-05-2008 at 04:06:00 PM
No problem, I'm glad it work for you , I hope it will work for everyone now :)
I'm on this bug for a while !
n°267
Aqua Crystal
Posted on 12-06-2008 at 10:20:31 AM
Thank you! It's finally working  :biggrin:.
My Blog
n°328
truth
Posted on 03-01-2009 at 07:22:15 AM
Error:
1.The [unread] tag on private message threads is never removed, even
if you read them .
Language:
1. It shows "Interlocutor" for "receiver" in private messages.
2. The functions for add url, add flash, etc in post editor are not in
    English.
http://img504.imageshack.us/img504/108/sigglassms3.png
n°329
Posted on 03-01-2009 at 10:18:44 AM
truth wrote :
Error:
if you read them .
Just a quick question. Do you know that the [unread] tag means that the person who you send the message to just hasn't read it?  :smile:
 Page :  1  2  3  4
Top
