34 unknown users
[News EN] Loginox : customize the login of Mac OS X Leopard
n°5326
Enigmatux
Posted on 02-20-2009 at 11:36:34 AM
Here a free software easy to use that allows you to change by any other image your login background image of your Leopard  : Loginox.
If your Mac is password protected, the first screen you see after starting up is the login screen. This screen contains the default image of Mac OS X 10.5 Leopard, which can get boring after a while.
Read the whole article
