17 unknown users
itunes problem
n°5
dazza
Posted on 03-17-2009 at 07:05:54 AM
i know someone with a macbook air everytime he plugges in a iPod it opens itunes then straight away itunes shuts again
please help him  :great:
-Dazza
http://www.crystalxp.net/forum/mesimages/302482/Signature post-it copy.png
n°6
Posted on 03-17-2009 at 10:41:24 AM
Weird. :yes: Try deleting the preference file of iTunes and start it again. ;)
n°7
dazza
Posted on 03-21-2009 at 12:32:25 PM
ok
n°9
turtle bacon
Profil: Top Penguin
Posted on 03-26-2009 at 01:48:33 AM
He might of not itstalled or updated it correctly the simplest thing todo is  un instal it then re instal
http://www.crystalxp.net/forum/mesimages/305312/Cryt.gif
Your Toast Has Been Burnt, and No Amount Of Scraping Will Remove The Black Parts!
n°10
dazza
Posted on 03-31-2009 at 08:27:07 AM
ok thanks success !!!!:lol:!!
n°142
jamespdavid
Posted on 11-25-2011 at 11:57:06 AM
-Dazza
I think you don't have installed iTunes successfully. you need to restore it from the Apple's Official site. Once you install it you will be able to transfer all kinds of data to iPod and vise versa to your laptop. This way you can easily perform iPod recovery if the data gets deleted or damaged.
n°150
veeko33
Posted on 12-01-2011 at 03:19:42 AM
When utilizing the search email, one can find complimenta Los Angeles escort remedies that can help. Reduce costs to utilise can be described as Los Angeles escorts The search engines search.Simplyjust input people's brand, associated with the expression email, or perhaps the emailcorrect, Los Angeles asian escort with the search engineproverbial box. The final results can easily deliver several differentinformation. You couldexperiment with acquiring an individual byLosAngeles asian escorts college or possibly office environment when you know who specifics. Whenever virtually nofinal results turn up, check out carrying out a Google search using the very same procedure
n°162
albert123
Posted on 12-14-2011 at 06:45:01 AM
-Dazza
If you have been unable to sync your iPod with your MacBook Air with iTunes, then it means that iTunes is not of the latest version. Get the latest version and install it. However, if the problem is not fixed then use iPod file transfer software for the purpose.
n°167
allonamon
Posted on 01-23-2012 at 02:15:49 PM
ITunes problem?
Any idea why my iTunes keeps saying that it cannot find all of my songs when I can see them when I open the program and they are all saved in the same place on my computer? (It has worked properly for the last 4 months without a problem)
wireless dog fence
scat mat
dog training collars
n°169
akankshi
Posted on 01-29-2012 at 05:44:05 AM
I think Dazza got the best solution and tackle the problem. As it seems from this message.
Thus no need to give more suggestion to him.
http://www.zerostylus.com/
