yjwho General & Off Topic Discussion : Neil and 30 unknown users
Need Help uninstalling!
n°95
Lorenc
Posted on 03-19-2009 at 09:12:34 PM
Ok I just installed the Vista Inpirat ultimate without knowing it cannot be used for Win 64x. I downloaded it and it fucked up... No I can't see my taskbar or nothing just a mouse. I managed to uninstall it but I still dont see a Start Menu and or icons... The only thing I see is my RocketDock...
If someone is to be so kind to help me restore my computer please do...
n°96
786darkblade
Posted on 03-25-2009 at 11:59:01 PM
Yes, this was the same question i was asking but mines was more confusier xD but i dont know how no one told me
n°97
uttaresh
The Penguin Master
Posted on 03-26-2009 at 01:00:52 AM
Well, I'm no expert, but my guess would be that your Windows Explorer file has been ruined. It's the file that includes the taskbar. Try to find the file explorer.exe for your Windows version online, and then replace it with the one on your PC. I don't know about 64 bit version, but for normal Windows, put it in:
C:\Windows\explorer.exe
But don't take my word for it, I don't know for sure.
One forum at a time.
n°98
turtle bacon
Posted on 03-26-2009 at 11:59:52 AM
Thisptoblem happened to me too when I tried to instal the Uxtheme patch what did was system restore to a point back in time but in windows xp I don't know if it
http://www.crystalxp.net/forum/mesimages/305312/Cryt.gif
Your Toast Has Been Burnt, and No Amount Of Scraping Will Remove The Black Parts!
n°99
786darkblade
Posted on 03-26-2009 at 09:52:18 PM
My explore exe cannot run because i cant find my vista template
n°119
smallrabbit
Posted on 04-12-2009 at 01:44:34 AM
One of the things you can do is to run explorer. Probably it is not working. To do that press ctrl+ald+del. Task manager will open. Go to applications tab and press new. Enter explorer and hit enter. This should call explorer. If this does not help try using sfc/scannow command in cmd. Read this http://www.pcterritory.net/2009/03 [...] login.html how to do this. This command will try to fix your system for errors. It can help.
www.pcterritory.net
n°183
Norad678
Posted on 06-29-2009 at 10:25:35 AM
I've been trying to unistall the vista theme. But it's not in add/remove programs. I've tried everything. I went in safe mode and deleted the bricopack folder But All there is left is the vista temp file. And it says i cannot delete it because "Folder Is Not Empty" Any answers? Please..i don't know what else to do.
n°197
tito5000
Posted on 08-21-2009 at 03:35:43 AM
I had the same problem, i didnt know XP 64x was not compatible with this software.  my solution was open the Task Manager and Run "CMD", then type "SFC/SCANNOW".....wait for fix the problems and, type again "explorer" .......That's it!! Problem Solved!....i hope its works 4 u.
