42 unknown users
hello need help thanks
n°57
crazyjef69
Posted on 01-27-2009 at 08:11:13 AM
hi i have a hp pavillion notbook dv 6000 i recently reformated it installed windows builder but due the sata drive i have in the machine i had to disable it in order for it to reformate so my question how would i make it work with the sata drive it working fine but the problem is i cant install  the lastest version of msn on it so thanks for ur help
n°63
turtle bacon
Posted on 02-02-2009 at 01:33:44 AM
Make sure you have correct drivers
http://www.crystalxp.net/forum/mesimages/305312/Cryt.gif
Your Toast Has Been Burnt, and No Amount Of Scraping Will Remove The Black Parts!
n°66
optimalsupreme-ban
Posted on 02-02-2009 at 11:08:07 PM
ctualy any xp sp2 and above will recognize sata -so make sure u set it as a sata not ide compatible- for once u switch thenu put the os on it -thenu switch back -u lose eerything
n°67
legace
Posted on 02-03-2009 at 04:05:42 PM
If you have a Windows XP CD with no SP or SP1, you might want to refer to a slipstream guide to slipstream SP3 into that CD.
-> http://www.winsupersite.com/showca [...] stream.asp
Btw. you need a Windows PC to do the slipstreaming :/
http://uploadpsd.com/file/67463.png
n°75
optimalsupreme-ban
Posted on 02-09-2009 at 12:57:55 AM
remrk should stay im here-for facts;
you dont need a windows pc pc means personal computer and windows nor 86 is that. to do slip streaming wrong -amig wasdoing it long long ago -before windos ever exsisted.you just need an os that has the app.
try from scratch xp sp3 from a torrent or buy it .xvlite or some program like it to do the slipstreaming.
side not what people wont do to keep the facts from being shown
n°160
catherine35
Posted on 05-20-2009 at 10:16:15 AM
Hello I need help if someone would please
n°161
catherine35
Posted on 05-20-2009 at 10:17:43 AM
anyone there?
n°162
uttaresh
The Penguin Master
Posted on 05-20-2009 at 10:48:17 AM
Help with what?
One forum at a time.
