21 unknown users
C: not H:
n°21
cincyfan43
Posted on 12-19-2008 at 07:46:33 PM
Hello to all!  :biggrin:
I'm using the Vista Inspitat 2 program..it is running perfectly. The one minor problem I have is when I tried to update my graphics driver it tried to load it into C: (except that my hard drive is H:) Can anyone tell me what my options are? Is it possible to change H: to C: without screwing things up? Thank you in advance for any help you can give me.
n°22
Aptitude
Posted on 12-19-2008 at 08:11:43 PM
move windows to C:?
i'm pretty sure C: is the default drive for windows so i don't know why it wouldn't be on there in the first place
n°23
Brandon11185
Posted on 12-19-2008 at 08:29:08 PM
some people have the system directory as all sorts of crap... you can try creating a system partition and let it install the files there, and then drag the files over into the real hd.
I am actually God Of Mana
n°24
x3lumin8x
Posted on 12-19-2008 at 10:26:47 PM
Do you have more than one partition?
