29 unknown users
Still having screenshot problems...
n°142
SimonLinus
Posted on 05-02-2009 at 07:07:20 AM
  I run XP, service pack 3. I was using Windowblinds and had no problems taking screenshots of my different configurations. Windowblinds seemd to hog resources, so I asked some friends about an alternative and found Crystal.xp. This has been great. I love everything so far. For now I'm just using the Vista theme that is right there on the main page. I'm also using a RocketDock. For a person that stuck to Xp in Classic Mode..I'm actually loving the look of this. Only ONE PROBLEM. No matter how I try to take a screenshot- all I can capture is the desktop background. No toolbar, no rocketdock, nothing. Just my selected desktop image. I decided to try Screenhunter, then another screenshot app- just to see if the standard way of taking a screeny just wasn't working for some reason. Still no luck.
I just registered for these forums- so if the topic has been discussed elsewhere please forgive me and help me out with a link. I did at least look , and havent seen this topic discussed yet.
n°143
SimonLinus
Posted on 05-02-2009 at 07:12:36 AM
I do use multiple monitors...but I already tried getting a screenshot using only one. I even did windowblinds again for a few minutes just to see if *somehow* something had changed with my setup that affects getting a screenshot of an app that changes the look of XP. No problems getting a windowblinds screenshot. Only bricopacks. I can even get screenshots of say, firefox, or vlc, while using bricopacks. Just not the toolbar or rocketdock.
n°144
poiru
Posted on 05-02-2009 at 11:52:42 AM
How do you take screenshots?
Press the PRNT SCRN key on your keyboard (next to F12) and then open Paint. Now press CTRL and V (or select File -> Paste).
Does this method work?
poiru.deviantart.com
