25 unknown users
Ideas Please :(
n°59
FriedShrimp
Posted on 01-28-2009 at 02:29:52 AM
Well, I wanted to install Bricopack Vista Ultimate 2 on my desktop and it is xp. I dont know if i should since many people told me that once you install it you cant get it out or your comp just crash and cannot be turn on.  :ohill:  :no:  :no:  It work on my cousin's pc but i am scare that it might screw up my desktop. Should I take a risk? :|
n°60
Posted on 01-28-2009 at 10:17:16 AM
Vista Ultimate 2 will change some image system files. It's best to install the BricoPack in Safe-Mode. This way is the safest for installing the BricoPack. :) If anything will go wrong, this forum will be here to help you.
n°62
turtle bacon
Profil: Top Penguin
Posted on 02-02-2009 at 01:32:03 AM
It shouldn't i install it on my old comp it fine! =]
http://www.crystalxp.net/forum/mesimages/305312/Cryt.gif
Your Toast Has Been Burnt, and No Amount Of Scraping Will Remove The Black Parts!
n°121
smallrabbit
Posted on 04-12-2009 at 01:52:11 AM
Such software dramatically changes system as well as explorer. This mean it makes system more unstable. This does not mean your system will not function properly but sometimes it may cause troubles. Especially when you try to uninstall it because it overrides important system files and with deinstalling it you also deinstall those system files. And now Windows does not have them any more. So here is where trouble arise.
If you need more customization advice visit my blog at www.pcterritory.net. Welcome
www.pcterritory.net
