Graphic Selections & Desktops : omohit and 38 unknown users
I can't download anything from Microsogt websites
n°33
haran
Posted on 01-03-2009 at 06:57:19 PM
Whenever I try to download something from the Microsoft website from Windows Media player to .net framework, I get a 'Connection Interrupted' error:
The connection to the server was reset while the page was loading.
The network link was interrupted while negotiating a connection. Please try again.
Nothing is wrong with my internet but I don't know why this is happening. It happens with IE and firefox.
So I'm trying to install .NET Framework 3.5 but when I press download, I get that error.
I'm using Windows XP SP2 and I turned on automatic updates.
n°122
smallrabbit
Posted on 04-12-2009 at 01:57:42 AM
maybe Microsoft is facing some server problems on their networks. Try another day. Another option is you got infected with some virus which prevents you to contact and/or update windows. So try to find yourself a good antivirus or host intrusion prevention program. Go to www.pcterritory.net Here you will find almost 50 security programs you may use without cost.
Message edited by smallrabbit on 04-12-2009 at 02:00:33 AM
www.pcterritory.net
