17 unknown users
The Vista Insipirat 2 doesn't show for my Bar theme?
n°25
deicide6funder
Posted on 12-20-2008 at 06:21:13 PM
I've had already Vista Insp.2 for quite a while and this morning my bar theme suddenly changed to the original XP one. I tried to change it back to vista theme but i can't find it on my theme properties. Why did it suddenly change? I haven't installed andy SP's recently they have all already been installed a long time ago. Should i uninstall and install it again? The Vista Insp 2.? Or is there away i can fix it?
n°26
uttaresh
The Penguin Master
Posted on 12-20-2008 at 06:32:04 PM
What "Bar" are you alluding to? :whistle:
Message quoted 1 times
Message edited by uttaresh on 12-20-2008 at 06:32:52 PM
One forum at a time.
n°27
deicide6funder
Posted on 12-20-2008 at 06:49:25 PM
I attached a screen shot. This is what my bar is supposed to look like in the bar properties, but it's not like that anymore. Last night it was normal but this morning i didn't see the vista theme bars anymore :(. Don't know what happened?
http://www.crystalxp.net/forum/mesimages/308939/sample.jpg
Message edited by deicide6funder on 12-20-2008 at 06:50:22 PM
n°28
uttaresh
The Penguin Master
Posted on 12-20-2008 at 07:48:36 PM
Oh. Just go to Contol Panel>>Display.
Select the Appearance tab.
In the Windows and Buttons list, choose Vista Inspirat 2.
Click OK.
That should do it. ;)
n°29
deicide6funder
Posted on 12-20-2008 at 07:50:21 PM
Hey! I tried that but it didn't work either. I actually uninstalled the Inspirat and reinstalled it! Everything shows up now! :) I don't know why my menu buttons stopped working.
n°64
dazza
Posted on 02-02-2009 at 05:34:34 AM
if it happens again right mouse click on my computer then go to advanced then performance then settings and tick "apply visual styles to windows and buttons"
http://www.crystalxp.net/forum/mesimages/302482/Signature post-it copy.png
n°65
Absolute Wolf
Posted on 02-02-2009 at 09:17:06 AM
Doubt it will help in this case.
Had the same problem  a couple of months back and had to reinstall the package. But other than that there was no bug.
n°78
vitezomani
Posted on 02-16-2009 at 04:18:50 PM
y have vista inspirate 2 and 1 y  have http://www.crystalxp.net/forum/mesimages/312514/2-14-2009 1-50-40 PM.jpg
Message edited by vitezomani on 02-16-2009 at 04:19:54 PM
n°79
uttaresh
The Penguin Master
Posted on 02-17-2009 at 04:10:55 AM
Have what?
n°80
poiru
Posted on 02-17-2009 at 03:55:51 PM
You guys might want to try to patch UxTheme if this happens..
http://www.softpedia.com/get/Syste [...] cher.shtml (for SP3)
http://www.softpedia.com/get/Syste [...] cher.shtml (for SP2)
poiru.deviantart.com
n°82
ethnopunk
Posted on 02-21-2009 at 06:57:14 PM
I installed the Vista Inspirit 2 pack today. Its great but my headphones are now suddenly dead, and after about half-an-hour, the animations stopped. I've re-installed the audio drivers, and the only sound I get is very soft out of the back jacks, not the front. How do I get the kool animations back? Also, any advice with the sound issue, which also seems to plague my ubuntu set-up.
