46 unknown users
Hardware & help
n°34
iraliyah
Posted on 01-07-2009 at 01:05:44 AM
well i want to change my xp pro theme. but i don't know if my my system is compatibility with bricopack Vista inspirat 2.    i've got windows XP pro (version 2002 ) with SP 3 AMD Athlon(tm)64 processor + 3800. Does anyone knows what i shoul ddo ?? help please :ohill:
n°35
uttaresh
The Penguin Master
Posted on 01-07-2009 at 02:35:54 AM
Do you have Windows XP 64-bit?
One forum at a time.
n°36
iraliyah
Posted on 01-07-2009 at 05:23:00 PM
no ,i've got Windows XP professional  32 bit
n°40
uttaresh
The Penguin Master
Posted on 01-07-2009 at 11:11:11 PM
You should have no problems then. But if you have below 1GB of RAM, I would suggest you NOT install RocketDock, YzShadow, and Styler with it.
Just go for Vista Inspirat 2 exclusively, and you should be fine. :yes:
n°41
y1n14i11
Posted on 01-08-2009 at 07:17:07 AM
you can copy themes in this folder
C:\WINDOWS\Resources\Themes
there are the normally windows xp skin and it don´t slow down your pc
Bad English because German^^
http://www.abload.de/img/ballpsigvdfv.png
n°42
uttaresh
The Penguin Master
Posted on 01-08-2009 at 08:25:58 AM
He is talking about the Bricopack, not a normal theme. You don't have to copy anything, just install it as it is. ;)
n°46
optimalsupreme-ban
Posted on 01-12-2009 at 07:03:07 PM
It does slow it down its more graphics afterall  -the faster the system -the more it wont look like it slowed down
n°47
uttaresh
The Penguin Master
Posted on 01-13-2009 at 03:47:44 AM
No, they do not slow anything down. There are no "more" graphics. Other graphics REPLACE the original ones, nothing is added.
n°52
optimalsupreme-ban
Posted on 01-25-2009 at 04:42:33 AM
correction they are replaced with better graphics so it does take longer or u wouldnt need such ram  -common sense
n°53
uttaresh
The Penguin Master
Posted on 01-25-2009 at 08:01:52 AM
Oh boy. Doesn't matter if they are replaced with "better" looking graphics. The resolution is the same. The size is the same. The color depth is the same. So no more RAM is needed.
And please stop embarrassing yourself. "Common sense", yeah right ...
n°54
legace
Posted on 01-25-2009 at 09:31:32 AM
:lol:
It doesn't matter if it's "better" graphics. The thing is that the Vista Inspirat theme is more complex (more shellstyles) and because of that the filesize of the Vista Inspirat theme is a few MB bigger.
Here is an example (I know you're stupid, but I hope this isn't too hard for you)
- With the Luna theme your PC uses 100MB RAM
The Luna theme takes 5MB RAM.
So without the Luna theme your PC would take 95MB RAM in total.
- Now you use the Vista Inspirat theme, which takes 6MB RAM
Instead of adding 6 to 100, you should add 6 to 95.
This means that the total RAM usage for Vista Inspirat would be 101MB.
Message quoted 1 times
Message edited by legace on 01-25-2009 at 09:31:52 AM
http://uploadpsd.com/file/67463.png
n°55
optimalsupreme-ban
Posted on 01-27-2009 at 07:12:32 AM
this is why u use outdated systems and dont have a clue on what is really going on. if it where the same color depth or same effect -that would be true but with differnt color and depth -hence special effects-which is why u get the brico pack- the reason why u dont see it is becuase of the cpu and ram u have -it takes care of the problem. If it where no differnt then i could use 98se system and achive the same result -u cant even run xp with that u need a better system .Which is why the requirments are set to run this program. newer efect better system is needed- dam some people need to get a clue and go back toshool to learn the truth.
HERE ENDTH THE LESSON
n°56
optimalsupreme-ban
Posted on 01-27-2009 at 07:17:42 AM
legace wrote :
:lol:
u jsut admited urself - ad if it didnt matter u wouldnt need a better system - what a bunch of fools no wonder u use the system that u do u cant handle the truth get a life . funny thing is with those extra shells u ned a better system. What a FOOL  Get an Amiga and not worry about takeing so much ram. well if u have an PS3 =Itanium u have the Amiga -oh by the way read above loser
n°58
uttaresh
The Penguin Master
Posted on 01-27-2009 at 10:28:40 AM
I don't understand a word you're saying.
Go taketh some English lessons.
n°61
legace
Posted on 01-30-2009 at 10:22:15 AM
If your computer can handle XP fine, then a few MB more RAM usage can't really harm.
And by the way, I don't use Windows (unless I have to).
n°69
optimalsupreme-ban
Posted on 02-06-2009 at 03:10:01 AM
lol
me amiga os and yet no problems -linux invented on an amiga  with the express purpose of getting people over to the amiga -took intel to do it
n°70
optimalsupreme-ban
Posted on 02-06-2009 at 03:11:45 AM
simple u dont kow what u are talking about -best not to talk to a fool-another thing get an amiga learn the truth
n°71
legace
Posted on 02-06-2009 at 08:39:56 PM
lol
I have never used Amiga, I admit that, but I can't see any use for Amiga. Linux/Mac/Windows have the majority of the computer users,so I don't really care about Amiga. It might be great, but withoutapps, I don't want to use it.
And by the way, Linux is not "invented" on Amiga. The Linux kernel is written from scrath by Linus Torvalds (if I remember correctly).
We got a saying here in Finland, and a rough translation of it to English would be: "The snow of last winter"
And Amiga is the snow of last winter.
For those who are stupid, snow melts (= disappears).
Message edited by legace on 02-06-2009 at 08:42:24 PM
n°74
optimalsupreme-ban
Posted on 02-08-2009 at 04:48:58 PM
funy if u did care u wouldbee having the problems you have - so you have nobody to blame but yourself and others like you
funny it has so many apps its not even funny and all better then anything on any of those platforms.
ur right u cant see becasue u havent seen it if it wasnt for the amiga u wouldnt be having what u have in the pcs now duo cores and such-u need to get one then youll see that even though old its still the best. well its an Itanium=ps3 so ...
mac is x86 always has been now the os is a paid version of linux -such a ripoff..
It was invented on an AMiga he has Amigas just becasue  its invented by him-that I know doesnt mean it wasnt invented on an Amiga .
Quote from him pcs at the time didnt have the power to accomplish what I needed.
Proof besides him-ask him  go to his house youll see the Amiga 3000 -the Amigas  any model does more stuff then an x86 can ever hope to do or have.
linux Pro march of 2004
" Linux was first on an Amiga -being invented on there by Linus"
" Linux was invented on an Amiga" Nick Vitech in linux Format August of 2008. in answer a ? where did linux come from
I have both mags
there is no quotes as it didnt exsist  before made by someone hence with invented no quotes
o u guys tend to rewrite history or the preset jsut to make it look like u can do it. or you are taught that way which is wrong
yes on an amiga to get  u guys over to the amiga - took intel and sony =Itanium=PS3 -both amiga clones to do it
yes its perfect honest no flaws and not anyone is every the same as the last one.
funny wrong again London Musem 25 years .hollywood, Nasa evn your own military . need to no more ask
and produces life giving water -hecne life giving knowlege-thts amiga -thanks to intel and sony
not meant to bash- u asked ? i gave facts
kinda of reptitive to keep on repeating-email me  -hombreone@gmail.com
Message edited by optimalsupreme-ban on 02-08-2009 at 05:03:15 PM
