27 unknown users
pls help! I destroyed my crystal OS !!!!!!
n°203
noor123
Posted on 09-08-2009 at 04:58:03 PM
I added a windows update that destroyed my computer!
Here's the full story:
When I got the computer from a computer guy who was working in my friend's company, the computer guy said he had put on it "Windows Crystal XP". He said it was a new operating system from Microsoft and that there is a "mirror program" instead of system restore.
After a few months, I updated the computer (using windows updates as I always do) and then after the update I was shocked to find that the start button wasn't a penguin, it looked like in Windows 98 or something and the welcome screen was the normal windows XP instead of crystal :aww: and then a window appeared saying that files required to run windows are now replaced with unrecognizable versions and that I have to put my windows CD to restore the files BUT I DON'T HAVE THAT CD!!! I couldn't use system restore and I searched the computer and found no trace of the "mirror program" whatsoever  :gimpwarning: I tried to contact the computer guy but I found that he had went to live in Italy!!!
P.S:
I found that a number of my computer games that used to work perfectly fine stopped working or crash after a few minutes from opening them.
So can anyone help me out? Can I download the CD online or something (I am unable to buy it because I'm not in USA or Canada or Europe)? Can I re-install Crystal xp from the internet? Can I somehow restore the files?
My main concern is restoring the files so that the games and programs can work again.
I'm sorry for taking your time. I hope that I gave you all the information you need to fix the problem.
Thank you
n°204
poiru
Posted on 09-08-2009 at 05:03:05 PM
What Service Pack do you have installed?
poiru.deviantart.com
n°205
truth
Profil: Top Penguin
Posted on 09-09-2009 at 05:42:24 AM
1. try find bricopack shortcut in startmenu , and run update
bricopack.
else
2. open "add remove programs" , uninstall bricopack. that should restore files.
else
3. download and install windows sp3 update from microsoft.
else
you really need a windows CD.
Good bye friends.
