Graphic Tutorials : mychu and 35 unknown users
 Page :  1  2  3  4  5  6  7  8  9
Previous
[Photoshop tutorial] Make a TinyTux
n°305
k_millio
Profil: Modo
Posted on 05-18-2006 at 08:07:56 PM
Create a TinyTux with Photoshop
First of all, download this model (or this one if you're using Photoshop 7). This will avoid you to re-do all the shapes.
You will see, actually if you are using Photoshop 7.0 or a newer version, that this PSD contains Layer groups. These will be really usefull at the end of the tutorial considering the large amount of layers.
You will also see two invisible layer groups. They contain the Tux's feet in its sitting version, and its beak when it's opened. Yeah, this tutorial won't just show you how to create only one position of the TinyTux ...
To shorten this tutorial, I've considered that the sitting tux and the standing where exaclty the same (well, exaclty, except for the feet :he:). We're now going to make the standing TinyTux with a closed beak :oui:
Let's get the tutorial started :tongue:
This tutorial is made of 6 large parts (I've posted a message for each), here's an index :
I - The body
II - The white stain
III - The closed beak
IV - The TinyTux's feet when it's standing
V - The opened beak
VI - The TinyTux's feet when it's sitting
I wish you will enjoy yourself reading my tutorial, and that it'll be clear enough. Now, have a nice (and long :he: ) reading :jap:
n°306
k_millio
Profil: Modo
Posted on 05-18-2006 at 08:10:42 PM
I - The body
1. First of all, open the model, if you haven't done it yet. You should see this (if you don't, this tutorial will seem much more difficult :he: ) :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/0.png
Open the "Body" layer group (by clicking on the little arrow next to its icon) and click on the "Body" layer.
2. Create a new layer (by pressing Ctrl+N), and name it "Bottom reflection". Click on its thumbnail while pressing Ctrl (we will call this action a Ctrl+Click), this will make the "Body" layer's shape as your selection. Now, contract the selection by 1 pixel ("Select > Modify > Contract" the enter 1 in the dialog box).
3. Select the gradient tool and choose a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient. Then draw a gradient like on the image :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/1.png
Reduce the layer's opacity to 35%.
4. Don't deselect and create a new layer called "Top reflection 1". Choose a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient. Draw a gradient like on this image :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/2.png
:idea: Holding Shift while drawing a gradient will give you a perfectly straight gradient !
Then contract the selection by 6 pixels and delete (you can now deselect by pressing Ctrl+D). Reduce the layer's opacity to 60%.
5. Create a new layer called "Top reflection 2", then, with the elliptical marquee tool, draw a selection, as shown below :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/3.png
You can use the "Select > Transform selection" to center you selection (:caution: Increasing the size of your selection with this function will create a blured selection).
Then draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient form the top of your selection to its bottom.
Then, put the layer's opacity on 60%.
6. Now, create a new layer called "Top reflet 3", draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient in the same selection from its top to its middle. Now move the selection by approximately 15 pixels to the bottom and delete. Now, reduce the layer's opacity to 30% and deselect. You should obtain this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/4.png
Let's do the same with the TinyTux's wings ...
7. Open the "Wings" sub-folder, and select the "Left wing" layer. Create a new layer named "Left wing reflection". Ctrl+Click on the "Left wing" layer and contract the selection by 1 pixel. Then, draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/reflected.gif Reflected gradient, like on the image.
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/5.png
8. Transform the selection so that it looks like on the image (I've rotated the selcetion by 8° and moved it) :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/6.png
Delete. Ctrl+Click on the "Body" layer and move the selection by approximately 18 pixel to the right. Delet again and deselect. Reduce the layer's opacity to 40%.
9. Duplicate the "Left wing reflection" and rename it "Right wing reflection". Make it slide over the "Right wing" layer. Select all, then flip horizontal ("Edit > Transform > Flip Horizontal";), this will move the new reflection over the right wing.
This is it, we've finished with the body :^^:
If you've followed this part of the tutorial, you should obtain this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/7.png
You can now collapse these two layer groups :wink:
n°307
k_millio
Profil: Modo
Posted on 05-18-2006 at 08:12:57 PM
1. Open the "White stain" layer group, click on the "White stain" layer and create a new layer named "White". Put your cursor between the two layers and press Alt, the cursor should change. Then, click (do not stop pressing  Alt). You should see this (in the Layers' window) :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/clipping.png
This is called a Clipping mask, this means that whatever you do on ther "White layer", it won't be able to overflow from the "White stain" layer's shape, this function is reaaly useful sometimes (actually, it's really useful more frequently than sometimes :he:).
2. Then, draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient, as shown below :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/8.png
3. Create a new layer called "Temp". Use the ellipticall marquee tool to draw a selection like this one :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/9.png
Fill it with any color, then reduce its Fill opacity to 0% :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/10.en.png
4. Apply these layer styles to the "Temp" layer :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/11.en.png
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/12.en.png
5. Create a new layer called "Black", and move it under the "Temp" layer. Select the "Temp" layer again and press on Ctrl+E (this'll merge the two layers). Now, apply a 2 pixel radius Gaussian blur ("Filter > Blur > Gaussian blur";).
Drag the "Black" layer between the "White" and "White stain" layers (this will include the "Black" layer into the existing Clipping mask). Then change the layer's blending mode to Overlay and put its opacity on 80%.
6. Create a new layer called "Reflection". Move it over the "White" layer and create a Clipping mask between the two layers (this will also include the "Reflection" layer into the existing [i]Clippinng mask).
Draw a selection like this one with the elliptical marquee tool :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/13.png
Then draw a gradient from the right-top corner to the opposite one. Then, put the selection on 30%. You should now obtain this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/14.png
We're now going to modify the eyes ...
7. Open the "Eyes" sub-group and select the "Left eye" layer. Create another layer named "Left eye reflection". Then, Ctrl+Click on the "Left eye" layer and reduce the selction's size with the transform selection function, so that it looks like that :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/15.png
Draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient form the top of your selection to its bottom. Then, reduce the layer's opacity to 50%.
8. Duplicate the "Left eye reflet" layer and rename it "Right eye reflection". Move this newly created layer over the "Right eye" layer, then, select all and flip horizontal. The eyes and their reflections should become symetrical.
The white stain is now also finished. You can collapse the two groups we worked in in this part.
You should normally obtain something like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/16.png
n°308
k_millio
Profil: Modo
Posted on 05-18-2006 at 08:14:39 PM
1. Open the "Closed beak" layer group and select the "Beak" layer. Now create a new layer called "Left color". Make a new Clipping mask between these two layers. Now, draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient. Then draw a gradient like on the image :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/17.png
Change the layer's blending mode to Overlay and put its opacity to 80%.
2. Now, draw a rectangular selection as shown below :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/18.png
Then, press on the layer mask icon (http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/mask.gif) located at the bottom of the layers' window. This really usefull function hides every pixel of the layer which isn't in the selection.
3. Duplicate the "Left color" layer, and rename it "Right color". Then add a Clipping mask between the two layers. Now, click on the thumbnail of the layer's mask, select all and flip horizontal. Put the layer's opacity on 40%. You should see something like that :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/19.png
4. Create a new layer and call it "Reflection 1". Add it into the Cllipping mask, then draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient from the top of the beak to its bottom. Ctrl+Click on the "Beak" layer, and move the selection by 6 pixel or so to the bottom.
Now, put the layer's opacity on 50%.
5. Create a new layer called "Reflection 2" and include it in the existing Clipping mask. Then draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient form the top of the beak to its bottom.
Then, change the layer's opacity to 30%.
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/20.png
We're now going to add a drop shadow to the beak ...
6. Create a new layer called "Shadow" and make it slide under the "Beak" layer. Ctrl+Click on the "Beak" layer and with the polygonnal lasso tool (or with the pen tool if you know how to use it), modify the selection and move it so that it looks like on this image :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/21.png
7. Draw a black to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient from the top of the selection to its bottom. Then deselect and apply a 4 pixel radius Gaussian blur. Now reduce the layer's opacity to 25%.
The closed beak is now finished. You should normally see something like this by now :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/22.png
n°310
Profil: Modo
Posted on 05-20-2006 at 12:22:55 PM
In this part of the tutorial, all the layers created in the "left foot" layer-group must be in a Clipping mask with the "Foot" layer, so I won’t repeat it.
1. Go in the "Foot up" layer-group, then in the "left foot" layer-group. There, click on the "foot" layer and create another called "Color 1". Draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient, from the left end of the foot (don’t limit yourself at the visible foot) to the right end. Then change the layer blending mode to Overlay.
2. Create a new layer called "Color 2". Draw a black to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient, from the right end of the foot to the left end. Then change the layer blending mode to Soft light.
3. Ctrl+click on the "Foot" layer, then move the selection by 2 pixels upwards. After that, invert the aforesaid selection and delete the layers "Color 1" and "Color 2".
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/23.png
4. Keep the active selection, and create a new layer called "outline" then draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient from the right end to the left end of the foot. Change the blending mode of the layer to Overlay.
5. Invert the selection, and created a new layer called "Reflection outline". Then, fill the selection with white. Move it by two pixels upwards and delete. Reduce the layer's opacity to 50%.
Here his the result of this step :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/24.png
6. Create a new layer called "Reflection front toe", then use the polygonal lasso to draw a selection like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/25.png
Fill with white and reduce the layer's opacity to 75%.
7. Create a new layer called "Glow front toe". Select the gradient tool and draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient, as shown on the picture.
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/26.png
After that, reduce the layer's opacity to 35%.
8. Duplicate the two last layers, rename them respectively "Reflection middle toe" and "Glow middle toe". Move it in order that it looks like this picture :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/27.png
9. Create a new layer called "Reflection back toe", and fill it with white. Then, Ctrl+Click on the "Foot" layer, and move the new selection by 4 pixel downwards, and delete.
With the polygonal lasso, select a shape like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/28.png
Then, delete. Reduce the layer's opacity to 50%
10. Create a new layer called "shadow". Draw a selection as shown below, then fill with black.
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/29.png
Deselect and apply a 6 pixels radius Gaussian blur. Reduce the layer’s opacity to 20%.
11. Now, you can close the "Left foot" layer-group, duplicate it and rename it "Right foot". Do a flip horizontal (in Edit > Transform). The two layer-groups called "Right foot" might superimpose themselves. If that's not the case, move the second in order to they superimpose themselves, then delete the one which wasn't in the model originally.
You might have this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/30.png
12. Go in "White stain" layer-group and create a new layer-group called "Stand foot glow". Ctrl+Click on the "Body" layer and create a layer mask on this new layer-group. Now, Ctrl+Click on the "foot" layer of the "left foot" layer-group, and Ctrl+Click on the "body" layer by pressing "Alt" (Like this, the body's form is removed of the shape). Your shape might looks like that :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/31.png
Create two new layers, the first name "Left foot glow 1", the second "Left foot glow 2". Fill the selection of the first with #FFFF00, and to the same for the second but with #FFB300
:idea: Press "shift" during a Ctrl+Click add the layer's form to the shape.
13. Apply a 8 pixel gaussian blur on the first layer and regulate its opacity on 50%, and apply a 4 pixels gaussian blur on the second. Reduce its opacity to 25%
14. Duplicate these two layers and rename them respectively "Right foot glow 1" and "Right foot glow 2". Select all, and do a flip horizontal of these 2 layers in order for them to correspond to the right foot.
TinyTux's feet when he is standing are finished. You should have a result like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/32.png
n°311
Profil: Modo
Posted on 05-20-2006 at 02:34:17 PM
V- The opened beak
In this part, we are going to make the opened beak and the inside of this one. Set the layer-group "Closed Beak" invisible and set it visible for the layer-group "Opened beak".
1. Create a new layer called "Left Color"; create a Clipping mask between this layer and the "Beak" layer. Draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient, as shown on the image :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/33.png
Then change the blending mode of the layer to Overlay and its opacity to 80%.
2. Draw a rectangular selection like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/34.png
Then, create a layer mask.
3. Duplicate the layer and rename it "Right color". Include the new layer in the Clipping mask. Hit Ctrl+A, and do a flip horizontal. Reduce the layer's opacity to 40%.
4.
Create a new layer called "Reflection 1". Include it in the Clipping mask. After that, draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient, from the top of the beak to the bottom.
Ctrl+Click on the "Beak" layer, then move the selection by 6 pixels downwards. Reduce the layer's opacity to 50 %.
5. Create a new layer called "Reflection 2". Include it in the Clipping mask too. Then draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient, from the top of the beak to the bottom. Reduce the layer's opacity to 30%. You should have something like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/35.png
6.
Open the "Inside" layer-group, and click on the layer which has the same name. Create a new layer called "Color 2" (Logical, I know) and create a Clipping mask. Draw a selection like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/36.png
Fill it with white. Change the blending mode of the layer to Soft light.
7. Duplicate this layer, rename it "Color 1" and drag it between "Inside" and "Color 2" layers. Apply a more or less 6 pixels Gaussian blur, and change the layer blending mode to Overlay.
8. Create a new layer called "Reflection"; make it slide under "Inside" layer. Ctrl+Click on this layer, then increase the size of the selection by 2 pixels. Draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient from the bottom of the selection to the top. Reduce the opacity of this one to 75%.
Your beak should look like that :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/37.png
Now, you can collapse the "Inside" layer-group.
9. Now, create a new layer called "Shadow" and drag it under the "Beak" layer. Ctrl+Click on this one and use the polygonal lasso or the pen tool, modify the selection and move it in order to it looks like this one :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/38.png
10. Draw a black to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient from the top of the selection to the bottom. Deselect and apply a 4 pixels Gaussian blur. Reduce the layer's opacity to 25%.
The opened beak is now finished (so you can collapse the "closed beak" layer-group). You should have something like this picture :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/39.png
n°314
Profil: Modo
Posted on 05-21-2006 at 06:42:25 PM
VI – The TinyTux's feet when he is sitting
Set invisible the "Stand feet" and "Stand feet glow" layer-group and set visible the "Sitting feet" layer-group, and expand it. In this part of the tutorial, all the layers created in the "Left foot" layer-group must be in a Clipping mask with the "Foot" layer, so I won't repeat it.
1. Go in the "Sitting Feet" layer-group, then in "Left foot". Click on the "Foot" layer, and create 3 layers called "Color 1", "Color 2", and "Color 3". Change the layers blending mode to Soft Light.
2. In the first layer, draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient from A to B (red arrow), in the second, do the same but from C to D (green arrow). Then in the third, draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient from E to F (blue arrow).
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/40.png
3. Now, create a new layer called "Reflection 1". Draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/radial.gif Radial gradient, as shown on the picture :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/41.png
Ctrl+Click on the "Foot" layer, then move the selection by more or less 6 pixels downwards. Delete and deselect. Put the layer's opacity to 75%.
4. Create a new layer called "Reflection 2". Draw a selection as shown below, then draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradient from the left end of the foot to the right end.
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/42.png
Reduce the layer's opacity to 50% and deselect it.
5. Create 3 new layers called "Outline 1", "Outline 2", "Outline 3". Change their blending mode to Overlay. In the first, draw a black to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/reflected.gif Reflected gradient, like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/43.png
On the second, draw a white to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/reflected.gif Reflected gradient, as shown on the same picture. Finally on the third, draw 2 black to transparent http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/linear.gif Linear gradients, from A to B and from C to D, as on this picture :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/44.png
6. Ctrl+Clicl on the "Foot" layer, then move the selection by 2 pixels upwards. Delete the "Outline 1" layer and then invert the selection. There, delete "Outline 2" and "Outline 3" layers. Invert again the selection, and move it by 2 pixels upwards. Delete these two layers and deselect. If you have managed to follow these instructions, you should obtain something like this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/45.png
7.
Now, collapse the "Left foot" layer-group, then duplicate it, and rename it "Right foot". Do a flip horizontal. The two layer-groups called "Right foot" should superimpose themselves. If that's not the case, move the second one in order to have them superimpose themselves, then delete the one that was located in the original model.
You should have this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/46.png
Now we are going to add some glows …
8. Go in the "white stain" layer-group. Create a new layer-group called "Sitting feet glows". Ctrl+Click on it, Create two new layers called "Left foot glow 1" and "Left foot glow 2". Ctrl+Click on the "Foot" layer from the "Left foot" layer-group (the one in which we have just worked). Fill the selection on the first one with #FFFF00, and repeat the same process on the second one, except that you do it with #FFB300 instead.
9. Apply an 8 pixels Gaussian blur on the first layer and set its opacity to 50%, then apply a 4 pixels Gaussian blur on the second one. Reduce the opacity of this one to 25%
10. Duplicate these two layers and rename them respectively "Right foot glow 1" and "Right foot glow 2". Select all, and do a flip horizontal of these 2 layers in order for them to correspond to the right foot.
The tutorial is now finished. If you followed it correctly, you should obtain this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/TinyTux/47.png
n°316
Rock
Posted on 05-27-2006 at 06:29:24 PM
French:
J'adore !!! Moi mon photoshop est en anglais donc je vais prendre ce magnifique tutorial qui a été fabuleusement traduit
Merci  :penguin:
Je compte faire toutes les versions  :mdr:
English:
I love it ! My photoshop is in english so i'll take this beautiful tutorial. I like the traduction Thank to Xena and k_millio !  :jap:
Thank !  :penguin:
I'll do all versions  !  :mdr:
n°317
k_millio
Profil: Modo
Posted on 05-28-2006 at 07:32:19 AM
Thanks a lot Xena for translating these parts of my tutorial :jap:
n°318
puma91
Posted on 05-28-2006 at 09:56:38 AM
Thanks!! Is super!!!  :mdr:
my photoshop is also in English!
 :loveit:  :loveit:  :loveit:
n°319
Skunkie
Posted on 05-28-2006 at 12:06:48 PM
The tutorial is very well done!  Great job guys!  :great:
n°323
coolguy
Posted on 05-30-2006 at 12:16:16 AM
i am New Penguin .here ....looked at this tutorial ...seems gr8..thanxs 4 making it available in english,.....would try this tutorial..it would be tough 4 me because i am  New in this stuffs..
Hope other english tutoriaLs come soon......
n°324
Rock
Posted on 05-30-2006 at 11:34:41 PM
Yess I like english tutorials too  :mdr:
:party: Welcome on  :penguin: CrystalXP !  :penguin:  :party:
n°325
Neil
Everyday is a Countdown
Posted on 05-30-2006 at 11:52:06 PM
Fantastic work Guys :cool:  " :great: two thumbs up :great: "
n°344
Phactor
Posted on 06-08-2006 at 01:58:52 AM
4. Create a new layer and call it "Reflection 1". Add it into the Cllipping mask, then draw a white to transparent  Linear gradient from the top of the beak to its bottom. Ctrl+Click on the "Beak" layer, and move the selection by 6 pixel or so to the bottom.
No matter what i do my beak fx comes out wrong. Maybe im misunderstanding the "Move" part? :cry:  I don't get it!
http://img.photobucket.com/albums/v233/BigJim101/aacb9a28.png
n°346
Tchii_chan
Posted on 06-08-2006 at 09:21:41 AM
humm "move the selection by 6 pixel or so to the bottom" and press del
they forgot that I think ^^;
n°348
Phactor
Posted on 06-08-2006 at 10:24:03 AM
It dose say to do that, but my problem is the gradent should be on the thiner section i beleve.
n°357
Ivan_xXx
Posted on 06-12-2006 at 08:28:07 PM
it says move the selection down six pixels
to do that hold down the space bar while pressing the aarow keys
 :great:
and yes once the selection is moved down you do press del
n°358
Phactor
Posted on 06-13-2006 at 02:36:29 AM
Cool! thanx Ivan_xXx :great:
http://img.photobucket.com/albums/v233/BigJim101/aa6b5059.png
n°359
Ivan_xXx
Posted on 06-13-2006 at 08:56:59 PM
your welcome :wink:
nice tux now how about some cloths? :happy2:
n°360
pollock
Posted on 06-19-2006 at 11:31:06 AM
Wow!!!
It so Good.
n°376
Dlaor
Posted on 06-30-2006 at 08:05:16 PM
cool :biggrin:
n°377
jeeva
Posted on 07-01-2006 at 09:27:43 AM
good job.
one of the best tutorials in the net.
 :loveit:  :great:
n°378
downloadfa
Posted on 07-01-2006 at 10:10:38 AM
cool :lol:
n°517
mitnachel1
Posted on 08-03-2006 at 11:41:58 AM
WOW i love it! i made all 4 :lol:  :boulay: ... i'm new here and new to photoshop and i whant to know if this is good for a biggener?
http://www.pictor.co.il/lils22/226798/5745571.jpg
Previous
Top
