17 unknown users
[Photoshop tutorial] Make a puzzle!
n°251
acid
Posted on 02-16-2006 at 12:07:19 AM
DIFICULTY: EASY
WHAT YOU NEED: photoshop only
 :meuh:  :fouet:
take a image, the on of your choise. i took this on:http://www.image-dream.com/membre/up/mini_fastupload/a7ebeb2b270059bf6d79e83678e636e0.JPG
1)perso, i wanted to add a cool effect: filters,filter galerie, and follow the image :http://www.image-dream.com/membre/up/mini_fastupload/635616b83492574a4b461c5c3363c7d9.JPG
2)clone the calque(layer in english?)
3)do like in the image:http://www.image-dream.com/membre/up/mini_fastupload/28315aa1e5dc6fa11dfa7f0e4362e8ec.JPG
4)Press style, press (puzzLe), press Bisautage et estampage/texture(sry can't translate that lol). apply your personal parameter :http://www.image-dream.com/membre/up/mini_fastupload/68eafd5f5eb127e03c1242f69dd26ca2.JPG
5)flatten the image
6)take the layout plucks, and cut a piece. :boulay:)http://www.image-dream.com/membre/up/mini_fastupload/a461f61d43765d8c797306297a7087e7.JPG
7)move that piece on a new document.
8)do a rotation ( here its 30  )to the piece :images,rotation of the zone of works, property.
9)Made a reflection of light : filter, returned, Halation(halo) and configured like u want
10)replace the piece somewhere inthe puzzle , and tadam,its end ! !
http://www.image-dream.com/membre/up/mini_fastupload/9ab941de9080ded013611857ab6d7e7d.JPG
a+ :smile:
I HOPE MY TRANSLATION ARE GOOD I HOPE YOU CAN UNDERSTAND MY TRANSLATION !
if u cant ask me for help !
edit:I am so sorry, my pictures got lost with the time. there was picture, but they are gone :frown:
n°262
Draginol
Posted on 02-26-2006 at 06:49:44 AM
That was interesting tutorial but I have to say it was a little difficult to understand when the picture quality wasn't the best...
Nice effort though and I shall give it ago!
n°263
k-net
Posted on 02-26-2006 at 12:55:35 PM
topic moved
n°264
linkinmimil
Posted on 02-26-2006 at 02:29:28 PM
Il y a programme qui permet de faire tout ça simplement et sans toshop. Mais je sais plus le nom désolé. sinon c'est un beau tuto
n°265
wamseb
Profil: Top Penguin
Posted on 02-26-2006 at 03:23:12 PM
ca rend super bien!
beau tuto!
Merci
n°266
zohair
Posted on 02-26-2006 at 06:12:50 PM
cool can it be in english?
n°326
coolguy
Posted on 05-31-2006 at 10:40:43 AM
nice tutorial acid...but little difficult to understand ..would giv it a try..
n°328
KDezign
Posted on 06-02-2006 at 12:22:28 AM
Yeah!!!
Nice tut, i like it.
Thanks  :lol:
n°330
Neil
Posted on 06-02-2006 at 07:47:06 PM
Wow such a Simple, easy tutorial. Thank you very much Acid, :loveit:
It's a great work though it had some difficulties to understand the process because It was not a complete English
translation.
I think perhaps it'll be better if I explain in Simple English what Acid Was telling you for the readers
who only deals with English. But remember All the credits to Acid, :angel:
So It's like this,(I was unable to locate the exat texture in Photoshop CS2 I hope Acid will explain this
but I can give you the rest of the instruction of thie process imagining you've found the exat texture.)
Open one of your favourite images in Photoshop (bmp, Jpeg, .gif) and from the tool bar select a background color
(here, Acid has selected blue (R-60, G-1, B-255) (#083dff)
Right click on the background layer and select 'Duplicate'
http://img197.imageshack.us/img197/5121/023ex.png
Select the Duplicated layer (background copy) and navigate to Filter>Filter Gallery. There, Under 'Brush Strokes' gallery, select
Sumi-e then hit OK.
http://img197.imageshack.us/img197/4661/032dx.png
you'll have this now
http://img197.imageshack.us/img197/848/015la.png
Double click on the duplicated layer or right click on it and select 'Blending Options'
http://img293.imageshack.us/img293/9587/048zl.png
On the blending option Window check on 'Bevel and Emboss' & keep its default settings.
Go to Texture, check it as on and Change the following parameters.
Scale- (180%)
Depth- (-34%)
&Make sure to check on 'Invert' & 'Link with layer'boxes.
http://img476.imageshack.us/img476/4323/ex1se.png
And select the Texture under above parameters and hit Ok.
Select duplicated layer (background copy) and click, Ctrl+Shift+E to merge the visible layers.
Select the Magic Wand tool (press W) and click on an area covered with a single block to create a selection (like in the picture)
http://img293.imageshack.us/img293/7937/095nh.png
Extra:*
:penguin: If this is not possible to do,(If you are unable to select the whole area surrounded by the block)
Ctrl+Shift+N to create a new layer (layer 01) and fill it with White (RGB-255) (#ffffff)
:penguin: Now go to the layers blenging options and select the exat texture pattern you've seleted for the Background copy with the
same paremeters. Only change the depth to (+4)
http://img293.imageshack.us/img293/2835/077lb.png
:penguin: then go to 'Bevel and Emboss'and change the following
Depth- (300%)
Highlight mode - (Multiply)
Highlight color - (Black), (RGB-0), (#oooooo)
Highlight Opacity - (100%)
http://img476.imageshack.us/img476/4903/069tp.png
Hide the other layers by clicking the 'eye' on the left of the corresponding layer.
Create another new layer (Layer 02) and click, Ctrl+Shift+E to merge the visible layers. this will disable the blending option customising menu for 'layer 01'
Now try to select the surrounded enviroment of the clip using 'Magic Wand tool'
http://img476.imageshack.us/img476/5061/085uy.png
Unhide the hidden layer (probably Background copy) and select it. Make sure the selection still remains in the window.
Select Move tool (press V) and move the selection a bit and rotate it up to 30 degrees clockwise (CW)
That's it! :party: You've completed the tutorial and Now you can save your design.
http://img476.imageshack.us/img476/3132/107pv.png
Note:* This is what I've done with the tutorial but using a different texture pattern. But it worked well according to Acid's instructions.
n°331
k-net
Posted on 06-02-2006 at 08:41:25 PM
Good tuto, well explained :great:
But the final effect isn't really like a puzzle :tongue:
n°332
Neil
Posted on 06-02-2006 at 09:29:10 PM
Thanks K-net :loveit:
Yes, actually I've mentioned that above. I was ubable to find the exat pattern of texture in Photoshop CS2 (I've searched everywhere)
If someone could give me an info regarding that I'll be able to complete the tuto more successfully :oui:
n°836
untamedkreationz
Posted on 12-02-2006 at 02:04:18 AM
If anyone is still wondering about the puzzle texture, Here is how to load it
Click Filter-Texture-Texturizer
Once it Loads on the right- hand side click the arrow for the file dialog box. The Puzzle Texture is located in the Application Path/Adobe/Adobe Cs/Presets/Texture
Just select the puzzle.psd to load it  :oui:
n°837
Damballa
Posted on 12-03-2006 at 02:53:42 AM
Where you get that Texture!
n°977
kinan
Posted on 02-27-2007 at 10:50:46 PM
thank you for this tuto
but wer can i find this patern
10x
n°1520
acid
Posted on 06-23-2007 at 09:19:40 PM
Hi back!
omg, this have more than a years! i got some luck to remember my password ^^
anyway, if someone is still wondering where i got the textures, it was include with photoshop. go take a look in your presets/texture folder, its called "puzzles"
n°1521
Posted on 06-24-2007 at 10:24:59 AM
Welcome back acid. :great: If you'd like to edit your tutorial, I'd be happy. There's some sms-language in there, and some pictures would come in handy, as said before. I'm not sure what the rules are for a tutorial to stay in this section, I'll have to talk with an Didas about this subject once. :smile:
n°1595
acid
Posted on 07-15-2007 at 06:56:29 AM
I fixed most of the spelling error/sms i have seen. I am sorry about this, I am french :smile:
Try to take a look at the one in the french section, my pictures are "mybe" still there.
Quick Edit:
Here are some of the step, thanks to Neil!
translation.
Sumi-e then hit OK.
Scale- (180%)
Depth- (-34%)
Extra:*
Depth- (300%)
And finnaly, here is the famous Puzzle !
http://xs217.xs.to/xs217/07280/itshere.JPG
