26 unknown users
 Page :  1  2  3  4  5  6  7  8  9  10  11
[Photoshop tutorial] How to Create Signatures
n°50
crystalmsn
Profil: Top Penguin
Posted on 11-21-2004 at 12:14:07 PM
Eliaden: Corrected as per your wish :great:
n°51
ELIADEN
Posted on 11-21-2004 at 08:32:13 PM
thanks again  :great:
n°52
Aid
Posted on 11-21-2004 at 11:21:33 PM
Yayy! Thanks alot Eliaden.  :biggrin:
n°53
ELIADEN
Posted on 11-21-2004 at 11:25:34 PM
:great:  :great:  :great:  :great:  :great:  :great:
n°54
Aid
Posted on 11-26-2004 at 08:03:54 PM
Made new sig.  :smile:  I tried to do a "glass" effect but it's hard for me.  :frown:
n°55
batux
Posted on 11-26-2004 at 08:06:43 PM
great aid :mdr:
n°56
Aid
Posted on 11-26-2004 at 09:08:49 PM
batux wrote :
great aid :mdr:
Thanks.   :he:
n°57
ELIADEN
Posted on 11-27-2004 at 01:51:25 AM
it is SO NICE
I really like this light effect
Simply a very good job
n°58
crystalmsn
Profil: Top Penguin
Posted on 11-27-2004 at 08:18:43 AM
Seems nice sigs are coming :great:
n°59
crystalmsn
Profil: Top Penguin
Posted on 11-29-2004 at 10:49:45 AM
Hi Eliaden,
Is this correct? If not what went wrong and how to correct it?
http://members.lycos.co.uk/tamizh/images/Fond-Signature_reflec.jpg
Thanks  :great:
n°60
ELIADEN
Posted on 11-29-2004 at 04:58:57 PM
crystalmsn wrote :
Hi Eliaden,
Thanks  :great:
Pretty nice one....  :great:
First of all
if you want to make the edges look nicer, I mean the white around
If it's for this forum then change the color of it
R: 239
G: 239
B: 249
Or
#EFEFF9
if you want to use it for another forum then instead of this color put the background color of the forum (do screenshot of it, and use the tool that catch color)
This is only if you save it in JPG (which I also use), because if you save it in PNG 24 you'll just have to delete the  white background layer, but the sig or the image will weight a lot more.
NOW about the reflection, the screen's reflection looks great, it's more the kind like the one I have done for Aid's sig then What did Drak in his, but you got it.
On the magician it looks like the feet are more erased then the body. But What you got is still a very good jod.
It look likes a different kind of reflection, whitch is OK.
I found one way to make those and I explained it in the tutorial.
But there are thousands of way to do different kind of reflection.
If you want to redo it just start the reflection of the tux all over again (no big deal)
and try to make the selection a close As you can from the tutorial's images
Or if you have the same result make you selection little bet further down
(you understand about what selection I'm talking about ?  there is only a main one for that part of the tutorial)
SO what I actually mean  is that it's a bit different from my tuto (on the tux only), but I like it very much the way you had it done (even if you used my tutorial).
And the screen's reflection looks like a strait result from my tutorial  :great:
However, your doing a great job  :great:  :great:  :great:  :great:
n°61
crystalmsn
Profil: Top Penguin
Posted on 11-29-2004 at 05:58:12 PM
Thanks for the comments :smile: Let me know more ways. Could you tell me how to make the base from scratch?
n°62
ELIADEN
Posted on 11-29-2004 at 06:06:55 PM
OK
try first (or at least now, because I have to go) to use the third part of the tuto
and then I'll help you on MSN one day
n°63
crystalmsn
Profil: Top Penguin
Posted on 11-30-2004 at 08:06:36 AM
Is it possible to have reflections for text?
n°64
ELIADEN
Posted on 11-30-2004 at 08:11:54 AM
yes
create a new empty layer
duplicate the text layer (this is for a backup) make it invisible
then clic on the original text layer and link it to the new empty layer
press CTRL+E
this will delete all the style options
but you have now the text as a tux
So from this you do like in the tuto
n°65
crystalmsn
Profil: Top Penguin
Posted on 11-30-2004 at 03:38:16 PM
How is this Eliaden?
http://members.lycos.co.uk/tamizh/images/Fond-Signature_text_reflec.jpg
I hope this is not 100% good :frown:
Let me know what to do?
n°66
ELIADEN
Posted on 11-30-2004 at 05:23:02 PM
I don't know, your results are strange
to you make the selection at the bottom of the signature
large and not so high
n°67
crystalmsn
Profil: Top Penguin
Posted on 11-30-2004 at 07:45:18 PM
Help me out with a example psd file :smile:
n°68
ELIADEN
Posted on 11-30-2004 at 08:33:33 PM
Here
I've just redone the text and it reflection
n°69
crystalmsn
Profil: Top Penguin
Posted on 12-01-2004 at 08:13:08 AM
Thanks a lot GG  :he:  :happy2:  :great:
n°70
ELIADEN
Posted on 12-01-2004 at 04:21:39 PM
n°71
Furtygaga
Posted on 04-18-2005 at 09:50:56 AM
thx but i dont know how to do the reflection with the matix guy how do i do ??
thx!! :smile: :penguin:
n°72
syntax010
Posted on 07-03-2005 at 10:05:47 AM
Is there some way that someone could and would update this guide for the English version of Photoshop CS2? Following the steps for making the text in the sig still works very well with CS2 version of Photoshop, but the instructions for creating the reflection are a bit confusing.
Perhaps a screenshot for what is meant by this --> Go in the menu Edit / Transformation / vertical Symmetry
(could someone give me the exact english version text) <-- part of the tutorial would be very helpful.
It goes from creating the duplicate layer to moving its order in the list of layers and has no screenshot for where or how you access the edit/transform/vertical symmetry?? for the purpose of making the relfection.
It's also not completely clear where the --> clic on the feather reflection (It should be hidden by the tux)  <-- part of the tutorial is referring to, as far as where exactly to click.
I realize i'm a noob and probably just making some simple mistake in not seeing what to do or where to do these steps, but it would be helpful for me and other "noobs" if that part of the guide could include a slightly better description and/or also include a few more screenshots of each step so a beginner could easily follow the screenshots for what to do and when and where to do it.
It is a great guide and I very much appreciate the hard work that went into putting it together, it could just use a little refining so people with less photoshop experience could follow it more easily.
n°147
TVL!_Corp
Posted on 11-01-2005 at 04:21:00 PM
it worked! good tutorial Eiladen!! :great:  :great:  :great:
http://i4.photobucket.com/albums/y106/tvledden/TVL_Corpsignaturekopie.jpg
n°148
Profil: Admin
Posted on 11-01-2005 at 04:39:34 PM
Good TVL!_Corp :wink:
But now our signature should not be more than 250x50 pixels  :penguin:
n°149
TVL!_Corp
Posted on 11-01-2005 at 05:46:37 PM
if i do that my luxs will be tiny...
Top
