27 unknown users
 Page :  1  2  3  4  5  6  7  8  9  10  11
Previous
[Photoshop tutorial] How to Create Signatures
n°1
ELIADEN
Posted on 11-11-2004 at 08:39:48 AM
I'll translate the two next parts as soon as possible...  :tongue:
I know two  :penguin:  that are going to be really happy about that, CrystalMSN and Aid  :mdr:
And a big thanks to vaksa who did the screenshot (english version)
Ok let's start  :he:
Before starting anything, your base
This forum has rules
So please use signatures that are no bigger than 250*50 pixels maximum
At the time I did this tuto those rules wheren't there yet
So here are few 250*50 pixels backgrounds:
http://eliaden002.free.fr/crystal/fond(original)mini-Log.png
http://eliaden002.free.fr/crystal/mini-bleu-Log.png
http://eliaden002.free.fr/crystal/mini-bleu02-Log.png
right click save as (png)
http://eliaden002.free.fr/crystal/fond-avatar.png
http://crystalxp.net/Fichiers/Autres/Fond-Signature.png
1/ How to resize an image, and keeping it ratio
insert the wanted image in the signature to resize it  :he:
click on the rectangular marquee tool (keyboard shortcut : M)
http://eliaden002.free.fr/crystal/tutoeng/pic1.png
Select the layers you are going to resize, then right click on it and select manual transform
http://eliaden002.free.fr/crystal/tutoeng/pic2.JPG
click and drag an angle to resize it as wanted, at the same time click on shift, this will  keep the ratio .
http://eliaden002.free.fr/crystal/tutoeng/pic02.png
Then, when done, click on the rectangle selection tool
Select Apply, if you want to do some more change select Cancel, or Don't Apply to cancel everything,
http://eliaden002.free.fr/crystal/tutoeng/pic3.JPG
This work with anything, tux, icons, any objects ...
You agree, nothing hard until now  :he:
2/ the text
Before you do anything download the Denmark font Here
to install it move it to the fonts folder
C:\Windows\Fonts\  (also accessible through the Control Panel)
So, select the horizontal type tool (keyboard shortcut : T)
http://eliaden002.free.fr/crystal/tutoeng/pic03.png
click on the image where you want to write (precision isn't needed yet) (a new text layer is created)
Select the font : Denmark
The color of the text is not important at all
And the text size is up to you
about 55pt for the pseudo alone
otherwise 36-40pt for the pseudo if you want to add one or two lignes of text below, and about 16pt for those small lignes
Select Crisp for the smoothing
and center the text
all those options are in the menu bar
http://eliaden002.free.fr/crystal/tutoeng/pic4.JPG
Type your text  :jap:
double click like on the following screenshot, and not on the text
http://eliaden002.free.fr/crystal/tutoeng/pic5.JPG
You should have somthing like that
http://eliaden002.free.fr/crystal/tutoeng/pic6.JPG
Go on Drop Shadow (click on the word)
Still as on the screenshot
Shadow color:
R:140 G:140 B:168
#8C8CA8
http://eliaden002.free.fr/crystal/tutoeng/pic7.JPG
Then like on the screenshot, still don't know the name in the english version
Do like on the screenshot
the color isn't important, because the value is 0%
http://eliaden002.free.fr/crystal/tutoeng/pic8.JPG
http://eliaden002.free.fr/crystal/tutoeng/pic9.JPG
And like on the screenshot
http://eliaden002.free.fr/crystal/tutoeng/pic10.JPG
Click on the color setting, the colored bar..
http://eliaden002.free.fr/crystal/tutoeng/pic11.JPG
click on the effect blue red yellow
http://eliaden002.free.fr/crystal/tutoeng/pic011.png
double click on the small square (0%)
to set the color
http://eliaden002.free.fr/crystal/tutorial/degrade4.png
change the color as:
R:218 G:217 B:234
#DAD9EA
same thing for the 2nd small square (placed at 50%)
R:192 G:192 B:219
#C0C0DB
and the third one (100%)
R:233 G:233 B:245
#E9E9F5
click once one the 2nd square (at 50%)
http://eliaden002.free.fr/crystal/tutoeng/pic09.png
notice the small rhombus on each side
http://eliaden002.free.fr/crystal/tutorial/degrade6.png
click once on the first one  :caution: the mouse should be a hand, not a arrow :caution:
be aware that the undo command works here, ctrl+Z
type 80 as on the screenshot
http://eliaden002.free.fr/crystal/tutoeng/pic0011.png
same thing for the 2nd on e but type 40 instead
close that window, by selecting the OK button
Finally like on the screenshot
http://eliaden002.free.fr/crystal/tutoeng/pic14.JPG
the color is
R:100 G:91 B:182
#645BB6
to center the text on the signature (if you want it to be centered)
Put it in the wanted height
select the signature backgroud layer
http://eliaden002.free.fr/crystal/tutoeng/pic15.JPG
then in the menu bar
Layer Menu / align the locked layer / horizontal center
You're Done !
You should have something like this (Hopefully )
http://eliaden002.free.fr/crystal/toto2-Log.jpg
If you have any questions feel free to ask
PS: Sorry but I have a French version of Photoshop, so I do not know the english version option names  :tongue:
n°2
ELIADEN
Posted on 11-11-2004 at 07:02:06 PM
One way to create reflections under an object
This is an example of a image were we want to add one kind of reflection
You'll need to have at least a layer for the tux, for this tutorial we'll call it TUX:
http://eliaden002.free.fr/crystal/tuto2eng/totolog1.jpg
Duplicate the TUX layer, by doing a right click on the layer
http://eliaden002.free.fr/crystal/tuto2eng/duplik.jpg
This layer should be called TUX copy
Go in the menu Edit / Transformation / vertical Symmetry
(could someone give me the exact english version text)
Move the TUX copy layer under the TUX layer with a click and drag (out of the text)
Before / AFTER
http://eliaden002.free.fr/crystal/tuto2eng/deplacalk.JPGhttp://eliaden002.free.fr/crystal/tuto2eng/deplacalk2.JPG
click on the Move tool (keyboard: V)
http://eliaden002.free.fr/crystal/tuto2eng/outildeplas.JPG
clic on the feather reflection (It should be hidden by the tux) and move it ( while pressing SHIFT in order to have a rectangle move ) move it down until the bottom of each feet touch the other feet (you could make the image bigger for more precision)
http://eliaden002.free.fr/crystal/tuto2eng/dplacreflet.jpg
Select the magic wand tool (keyboard: W)
then as the screenshot
http://eliaden002.free.fr/crystal/tuto2eng/bagette.jpg
then click on the shadow
you should have something like this
http://eliaden002.free.fr/crystal/tuto2eng/slect.jpg
Delete button to delete the reflection shadow (We'll leave the tux shadow but you could also delete if you'd prefere, I'm leaving it)
http://eliaden002.free.fr/crystal/tuto2eng/selection.jpg
and click anywhere to unselect (and out of the actual selection)
with this tool still in use
do a selection pretty much like on the screenshot
http://eliaden002.free.fr/crystal/tuto2eng/selectrect.jpg
right click in the selection, and feather
http://eliaden002.free.fr/crystal/tuto2eng/contourprogr.JPG
the selection will change his shape
this is an exemple
http://eliaden002.free.fr/crystal/tuto2eng/aprescontour.gif
feather radius 10
http://eliaden002.free.fr/crystal/tuto2eng/rayon.JPG
Finally, press the delete button as much as wanted to get the final result
then click out of the selection to unselect
do a selection to delete the extra reflection that goes above the edges, even if not much visible
http://eliaden002.free.fr/crystal/tuto2eng/suprsurplu.gif
and press delete
and this is what you should get:
http://eliaden002.free.fr/crystal/TOTO-Log4.jpg
You can of course apply this to any object
n°3
ELIADEN
Posted on 11-11-2004 at 07:04:02 PM
How to create the signature background
This tutorial will be shorter you'll have to use the psd (photoshop extention) and those explanation to understand
so here is the background (click on the image to download the .psd):
http://eliaden002.free.fr/crystal/fond(bleu)-Log.png
and the avatar
http://eliaden002.free.fr/crystal/avatar(bleu).png
To make it I have used:
the rounded rectangle tool
http://eliaden002.free.fr/crystal/tuto3/outilrect.gif
I used it twice for the 2 rectangle (see psd)
every thing else is in the layer style
double click on the layer (not on the text)
http://eliaden002.free.fr/crystal/tuto3eng/stylecalque.jpg
http://eliaden002.free.fr/crystal/tuto3eng/stylecalque1.JPG
the third layer, is the same color as the the forum backgroud
so you won't have horrible white angles
If you want to use a signature to another forum
this is for JPG kind of signature
If you want to save it in PNG
you can simply delete this layer
About the stroke
In my case, the stroke color is the same as the darker color of the border
To show you on this screenshot, the red color will become the dark blue above it
You can change the color in the layer style and click on Stroke
http://eliaden002.free.fr/crystal/tuto3eng/prcontour.gif
Voila, I hope this will be enough for this part
if you need more detail on one point just ask for it ....  :great:
n°4
vaksa
Profil: Top Penguin
Posted on 11-11-2004 at 07:06:50 PM
Wow :eek:  Thanks ELIADEN :great:  :smile:
n°5
Aid
Posted on 11-11-2004 at 07:12:56 PM
Yay, I read you fab tuto and made my 1st sig.  :happy2:
http://img64.exs.cx/img64/4020/Tryoutsig.gif
It's abit plain but oh well.  :err:
n°6
crystalmsn
Profil: Top Penguin
Posted on 11-11-2004 at 07:14:19 PM
Thanks Eliaden and good work Aid.  :great:
n°7
ELIADEN
Posted on 11-11-2004 at 07:20:11 PM
http://img67.exs.cx/img67/4020/Tryoutsig.gif
It's abit plain and demented but oh well.  :err:
Very nice one
but you should save them in jpg or png (if it's still under 30Ko)
So you'll have a nice shadow
n°8
Aid
Posted on 11-11-2004 at 07:27:41 PM
ELIADEN wrote :
Very nice one
Lol, yes I realised that.  :tongue:
And thanks crystalmsn.  :smile:
n°9
Skunkie
Posted on 11-11-2004 at 08:15:19 PM
Wow, excellent tutorial!  Thank you ELIADEN  Aid, nicely done!  Maybe this tutorial can even help me :wink:
n°10
ELIADEN
Posted on 11-11-2004 at 08:35:02 PM
Thanks Skunkie  :great:
n°11
vaksa
Profil: Top Penguin
Posted on 11-11-2004 at 10:16:33 PM
If you want I can send you screenshots from english Photoshop CS :jap:
n°12
Aid
Posted on 11-11-2004 at 10:24:17 PM
I want to.  :frown:  :frown:  :frown:  :frown:  :frown:  :frown:  :frown:  :frown:  :frown:
n°13
ELIADEN
Posted on 11-11-2004 at 11:26:21 PM
If you could do the same screenshot, that could be just great, for everyone
If you do so send those to me by PM
 and I'll edit the tuto with your screenshot
:great:
n°14
vaksa
Profil: Top Penguin
Posted on 11-12-2004 at 02:00:12 AM
Done. Check your PM inbox :smile:
n°15
ELIADEN
Posted on 11-12-2004 at 06:40:16 AM
Now the screenshot are from an english version of photoshop
at least for the first part
BIG thanks to vaska who did those
n°16
vaksa
Profil: Top Penguin
Posted on 11-12-2004 at 06:50:16 AM
You are welcome
 :he:  :great:
to be continued...
n°17
slogan
Posted on 11-12-2004 at 07:32:27 AM
THANKSSSSSS MUCH ELIADEN and VASKA !
You have done a great job :smile: :biggrin: !
n°18
ELIADEN
Posted on 11-12-2004 at 07:34:14 AM
:great:  :great:  :great:  :great:
I'm happy you like it  :wink:
n°19
vaksa
Profil: Top Penguin
Posted on 11-12-2004 at 07:39:00 AM
:winktongue:  :great:
n°20
Aid
Posted on 11-12-2004 at 06:52:25 PM
Yay, I made my 2nd Sig, I think it's ok for my 2nd time making one.  :tongue:
n°21
batux
Posted on 11-12-2004 at 06:54:56 PM
geat job! :smile:
n°22
Aid
Posted on 11-12-2004 at 06:58:47 PM
batux wrote :
geat job! :smile:
Thank you.  :happy2: Making Avatar now.  :tongue:
n°23
Aid
Posted on 11-12-2004 at 07:33:06 PM
Can anyone tell me why it wont let me have this is an Avatar?
http://img28.exs.cx/img28/152/AidAvatar3.jpg
n°24
Aid
Posted on 11-12-2004 at 07:34:59 PM
Ah never mind, it's done now.  :happy2:
n°25
ELIADEN
Posted on 11-12-2004 at 10:19:39 PM
Aid  :great:
Now it's getting a lot more better about the shadow :mdr:
good job for your signature and avatar  :great:  :great:  :great:
Previous
Top
