jeppeview and 40 unknown users
 Page :  1  2  3  4  5  6  7  8  9  10
[Photoshop tutorial] Make a porthole !
n°2268
marexz
Posted on 05-19-2008 at 05:26:02 PM
Man its chillin!!!!
n°2346
dura007k
Posted on 06-04-2008 at 10:23:25 PM
Huuuuhh At last I do it :tongue:
My result:
http://www.photoserver.ws/files/3nus1iwaor9cg98dzi.png
n°2350
Posted on 06-05-2008 at 09:17:19 AM
Good job. :oui: You're the thousand person with cut shadows, but the rest of the work looks pretty good. :wink:
n°2355
darklady
Posted on 06-06-2008 at 07:08:02 PM
There is a small trick on getting better shadows (not being cut off)
The shadows are hard to see when you have got no background layer.  Try adding a background layer in white or other lighter color and then when you are ready to save it, simply hide that layer.
If you cannot tell the shadow is cut, chances are, you should scale it down a little bit.
n°2365
earnur
Posted on 06-07-2008 at 08:15:54 AM
Why don't you can't change canvas size? :wink: Just go to Image -> Canvas Size or press ALT+I+S :wink:
n°2374
Rimorox
Posted on 06-07-2008 at 05:39:45 PM
Thank you great Tutorial
here's my result:
http://i249.photobucket.com/albums/gg225/rimorox/Metaknightporthole-1.png
and this one has no bachground:
http://i249.photobucket.com/albums/gg225/rimorox/Metaknightporthole-2.png
n°2543
Aelitafan13
Posted on 07-07-2008 at 06:28:02 AM
Here's my result:
http://i289.photobucket.com/albums/ll221/Aelitafan132/LyokoIcon-1.png
Also, I found a way to make a EXISTING Background transparent :lol::
In the Layers palette, double click the background layer
The New Layer dialog box appears.
In the Name text box, verify that it reads Layer 0
In the Opacity field, drag to 0%.
Save as .PNG.
Your Background is now transparent
n°2544
Posted on 07-07-2008 at 11:18:02 PM
Your outcome is quite impressive :oui: keep it up :wink:
n°2545
Aelitafan13
Posted on 07-08-2008 at 07:17:03 AM
Thank you very much. ^^ :happy2:
n°2546
ghostnatyphon
To die would be a great adventure.
Posted on 07-08-2008 at 01:00:05 PM
Nice outcome Aelitafan, but one thing, the little pink haired one is missing its shadow!
n°2570
fabo92
Posted on 07-11-2008 at 07:49:08 PM
Thanks man, this help me a lot for my website logo (beta) :biggrin:
http://img225.imageshack.us/img225/5943/logo3mt2.png
n°2581
2_7
Posted on 07-14-2008 at 11:29:36 AM
Really usefull and Kool tutor :boulay:
n°3543
jceggbert5
Posted on 11-13-2008 at 05:58:58 AM
Mad in PhotoShop CS3
I tried my best, but here it is:  http://h3ouka.bay.livefilestore.co [...] d?download
It is on my skydrive acount...
it has no image inside, but most of it is there.
n°3544
Posted on 11-13-2008 at 08:51:34 AM
Welcome here jceggbert5. :) Your result looks pretty good. :D The outer glow appears a bit strong to me, but good result anyway. ;)
n°3620
bonceypineapple
Posted on 12-09-2008 at 06:23:25 PM
will you emalil me a psd of cs4 because you cant do this with cs4
n°3632
Posted on 12-12-2008 at 08:26:05 AM
You can do this with Adobe Photoshop CS4 just as easy as with CS3. :neutral: Can you specify your problem?
n°3683
maquire202
I never think of the future. It comes soon enough.
Posted on 01-11-2009 at 12:10:17 AM
here is my result :he:
http://www.crystalxp.net/forum/mesimages/310958/blue_pothole.png3..pnghttp://www.crystalxp.net/forum/mesimages/310958/green_porthole.png3..pnghttp://www.crystalxp.net/forum/mesimages/310958/orange_porthole.png3..png
http://www.crystalxp.net/forum/mesimages/310958/purple_porthole.png3..pnghttp://www.crystalxp.net/forum/mesimages/310958/red_porthole.png2..pnghttp://www.crystalxp.net/forum/mesimages/310958/yellow_porthole.png2..png
Message edited by maquire202 on 01-11-2009 at 09:20:41 PM
http://www.crystalxp.net/forum/mesimages/310958/signature2.png
n°3684
uttaresh
The Penguin Master
Posted on 01-11-2009 at 02:19:48 AM
Very cool, but I see a lot of aliasing on the lightning bolt. ;) Try to make one yourself instead of pasting it ... should get better results. :yes:
Oh, and the shadow's cut off at the right and bottom.
One forum at a time.
n°3685
maquire202
Posted on 01-11-2009 at 02:26:49 AM
Thanks, too bad i noticed your message a little late--> i have already done 6 different ones. by the way will gaussian blur help? :frown:
Message edited by maquire202 on 01-11-2009 at 09:20:02 PM
n°3687
uttaresh
The Penguin Master
Posted on 01-11-2009 at 04:10:33 AM
I think so, a slight Gaussian Blur of about 0.3 to 1 pixel should help.
n°3688
maquire202
Posted on 01-11-2009 at 04:58:44 AM
thanks, can you please check the images and tell me if anything is wrong? :lol:
n°3689
uttaresh
The Penguin Master
Posted on 01-11-2009 at 05:04:55 AM
They look fine, though I think you should apply a transparent to white gradient for the shine; that is to say, transparent near the centre and whiter at the edges. ;) Makes it look more "spherical" -- especially since you're using such a plain background.
Message edited by uttaresh on 01-11-2009 at 05:05:44 AM
n°3714
kenryuakuma
Posted on 01-24-2009 at 09:36:15 AM
well...I am just wondering how you do it and I followed the instruction precisely step by step. However, when I was working on the gredient overlay apply the effects to it my oval circle just changed to the square block. No matter how hard or with whatever methods I have tried and used, it just kept getting the damn square block.
This is how I did this: I first created a new document and set the size as told and then I set the background with white color as a background for the image and then I used vectorial elliptical tool to draw a circle on it and apply black color from the foreground before I started working on the gredient and effect.
n°3827
mainmukit
Posted on 03-22-2009 at 07:43:20 PM
Well I gave it a shot, with a few changes =)
http://img10.imageshack.us/img10/6554/draftqak.png
Message edited by mainmukit on 03-22-2009 at 07:47:11 PM
n°3828
Posted on 03-22-2009 at 07:55:10 PM
Looks good mainmukit! :D Welcome to CrystalXP. ;)
n°3829
shanky
Posted on 03-23-2009 at 09:35:06 PM
10. Put an image between layers 2 and 3, and reduce its opacity to 50% to 70%. Here's the final result :
http://kmillio.crystalxp.net/Tutor [...] result.jpg
Here are two other examples of what you can do by following this tutorial :
http://kmillio.crystalxp.net/Tutor [...] amples.jpg
can u plzz tell me how to put an image between two layers in photoshop ty  :smile:
I am stuck at step 10  :biggrin:
Top
