militoh and 32 unknown users
 Page :  1  2  3  4  5  6  7  8  9  10
Previous
[Photoshop tutorial] Make a porthole !
n°191
k_millio
Profil: Modo
Posted on 12-29-2005 at 10:24:24 PM
Hi everybody :meuh:
In this tutorial (First written by Symon in french), I'm going to show you how to create a beautyfull porthole like this one with Adobe Photoshop :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/Final-result.jpg
And you can find the french version of the tutorial in this topic :wink:
Let's start :mdr:
1. Create a new 250x250 pixel document and use the vectorial ellipse tool to draw a black shape like on the image :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/1.jpg
2. Double-click on the thumbnail of the layer to open its blending options window. Enter these settings :
Drop shadow:
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/2.jpg
Bevel and emboss :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/3.jpg
Gradient overlay :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/4.jpg
Using this Gradient :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/5.jpg
Stroke :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/6.jpg
Using this gradient :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/7.jpg
You should obtain this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/8.jpg
3. Use a Ctrl+Click on the thumbnail of the "Layer 1" to have its shape as your selection. Then go to Select > Modify > Contract, and enter 7 in the newly appeared window.
Now create a new layer (Ctrl+Shift+N), and fill your selection with black. Then deselect (Ctrl+D). You should obtain this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/9.jpg
4. Then, double-click on the thumbnail of the layer to make its blending options window appear. Then, enter these settings :
Inner shadow :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/10.jpg
Outter glow :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/11.jpg
Inner glow :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/12.jpg
Bevel and emboss :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/13.jpg
Gradient overlay :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/14.jpg
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/15.jpg
Stroke :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/16.jpg
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/17.jpg
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/18.jpg
5. Ctrl+Click on thumbnail of the "Layer 2", then contract the selection by 4 pixels (Select > Modify > Contract) and choose the gradient tool. Then set white as your foreground color, and select the "Foreground to transparent" gradient. Now, draw a gradient in a new layer (Ctrl+Shift+N) as shown bellow :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/19.jpg
6. Create a new layer and fill the same selection with white :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/20.jpg
7. Use the elliptical marquee tool to draw a selection like on the image, and press delete. Reduce the opacity of the layer to 40%. You should obtain this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/21.jpg
8. Then Ctrl+Click on "Layer 2"'s thumbnail, and contract the selection by 4 pixels. Create a new layer, and fill your selection with white. Now use the elliptical marquee tool to draw a selection like on the image and press delete :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/22.jpg
9. Deselect (Ctrl+D), and reduce the opacity of the layer to 20%. You should obtain this :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/23.jpg
10. Put an image between layers 2 and 3, and reduce its opacity to 50% to 70%. Here's the final result :
Here are two other examples of what you can do by following this tutorial :
http://kmillio.crystalxp.net/Tutorials/Photoshop/Porthole/Examples.jpg
n°192
Hora
Posted on 12-29-2005 at 10:27:00 PM
This is a very good translation for this tutorial :loveit:
Thank you Kmilio!
n°193
memomeo
Posted on 12-31-2005 at 11:43:24 AM
i have not finished :frown:
send you me psd file ? thanks :smile:
n°194
Djtux
gribouilleur
Posted on 12-31-2005 at 03:02:47 PM
Great translation thank you k_millio :smile:
n°223
McTell
Posted on 01-23-2006 at 10:02:38 PM
I've some troubles to finish that tut. Is it possible to upload the psd?
Thanks...
n°224
Profil: Modo
Posted on 01-23-2006 at 10:39:35 PM
It's so beautiful ! I like it so much ! :great:
n°225
Funny Monkey
Posted on 01-24-2006 at 12:52:43 PM
:wink: Beautifull
n°227
McTell
Posted on 01-24-2006 at 08:09:34 PM
^^Yeah really nice... can someone upload the psd??
Thanks...
I wana also do good looking stuff...
n°228
luigi
Posted on 01-24-2006 at 11:09:18 PM
great work.
thanx
n°243
Draginol
Posted on 02-10-2006 at 07:25:15 AM
That was the best! :happy2:
I used Rol's Mushroom Graphic Image... Thank you!
n°244
Draginol
Posted on 02-10-2006 at 07:48:12 AM
I also made this a little later on using your Glass Icon Tutorial... :cool:
n°245
Profil: Admin
Posted on 02-10-2006 at 08:09:23 AM
Good  :cool:
n°246
vIcO
Posted on 02-10-2006 at 11:50:33 AM
I think it'll be better with the pic under the crystalisation  :oui:
n°247
Draginol
Posted on 02-11-2006 at 03:12:38 AM
Thanks for the feed back but what exactly do you mean because I will give it ago?
n°248
Franatix
http://franatix.free.fr/
Posted on 02-11-2006 at 10:15:37 AM
well thank you for your tuto  :cool:
n°250
Draginol
Posted on 02-15-2006 at 06:37:58 AM
Thank's dlb for your feedback :loveit:
n°254
zohair
Posted on 02-21-2006 at 05:08:44 PM
Damn that is so nice!
n°284
Duque
Posted on 04-05-2006 at 10:25:18 PM
That's a really nice icon, I'm newbie and I'm trying to made a porthole like this, but I can't, can you upload the psd file please?
n°288
find3r
Posted on 04-11-2006 at 03:05:24 AM
Cool!! Worked for me!
Thankss!!
http://img158.imageshack.us/img158/4525/portholetuxfind3r0wa.png
n°304
Konimotsinui
Posted on 05-17-2006 at 04:52:56 AM
That's awesome. I'm not sure if I have a use for it, but I might try it later.
I wonder why I haven't seen these tutorials on Good-Tutorials yet. :happy2:
n°350
Phactor
Posted on 06-08-2006 at 10:46:37 PM
Great Tuto! :great:
Heres my go at it:)
http://img.photobucket.com/albums/v233/BigJim101/9c110433.png
n°351
k-net
Posted on 06-08-2006 at 11:03:34 PM
Cool icon, Phactor :great:
n°352
Phactor
Posted on 06-08-2006 at 11:10:40 PM
Thanks K-net!
n°353
Neil
Everyday is a Countdown
Posted on 06-08-2006 at 11:27:03 PM
Fantastic work Phactor, :loveit:
And a Brilliant tutorial K-millio :love:
n°354
k_millio
Profil: Modo
Posted on 06-09-2006 at 01:53:13 AM
Oh, it's not my tutorial, it's Symon's :wink:
I've only translted this tut from Symon's french version :oui:
Previous
Top
