| uttaresh The Penguin Master Profil: Penguin Pro | Last message on previous page: Here's my try ...
ghostnatyphon Who Dares Wins Profil: Penguin Pro | Nice one  | |
Tanshin Profil: Penguin Pro | I like it, I should try ghost's next | |
Neil Chances are not had but gained....... Profil: Penguin Pro | Samiwieciekto wrote :
Personally I prefer using Inkscape for such purposes - it's faster and You can easily reuse any object You made.
It's true In photoshop every one can have his own way to do the same work It's just a matter of desire & ..... more  | |
Tanshin Profil: Penguin Pro | Happy new avatar Ghost!
ghostnatyphon Who Dares Wins Profil: Penguin Pro | Cheers  | |
Tanshin Profil: Penguin Pro | Wow, you actually are using it... didn't know that would happen. | |
Frozzn Profil: New Penguin | Practical. And the picture with the mushroom is very cool . | |
codenamem2k Profil: Big Penguin | Great tutorial man I'll post my result soon  | |
Frozzn Profil: New Penguin | So, here's my try .
Tanshin Profil: Penguin Pro | There is something with that curl color. Did you change the gradient or add a color effect? | |
Haha, heck why not? It would seem to be a waste otherwise It'll be gone soon I feel like a change. Good try Frozen, but I think the reds on the curl should be darker, both of them  | |
Gruzz Profil: Moderator | There's a small shadow error in .Ghost.'s avatar. Frozzn, I agree that you've to darken up the curl.  | |
Frozzn Profil: New Penguin | I think I need an other gradient for the curl  | |
Tanshin Profil: Penguin Pro | Don't add the color in the gradient. Just use the gray to white one I showed, then use the color effect (Hue/Saturation doesn't work here). Try different blending modes of the color settings to try and get what looks best.  | |
Frozzn Profil: New Penguin | Yes, I try this later because I made this picture in school and I haven't the psdversion anymore . | |
codenamem2k Profil: Big Penguin | I worked on my own page curl... And here is my result:  Hows it??? And I think there is a correction in the tutorial, It is that: It should be Flip Vertical for the curl in the right corner, and Flip Horizontal for the curl in the left corner Look into it  | |
dura007k Profil: New Penguin | Thnx for this great tutorial bro Here is my result
Gruzz Profil: Moderator | Pretty nice, but I think the drop shadow on the normal icon ruins it a little bit. However, the curl looks pretty good.  | |
codenamem2k Profil: Big Penguin | Yeah... Great work dura007k  | |
Tanshin Profil: Penguin Pro | Great job both of you. And I will make that correction. | |
Frozzn Profil: New Penguin | It looks very realistically. Great . | |
codenamem2k Profil: Big Penguin | Thanks dude  | |
Frozzn Profil: New Penguin | I've made an other try :
Tanshin Profil: Penguin Pro | Kind if like aluminum foil if you ask me but, it still looks really good. I might say to increase the amount of white but, it looks fine already. | |
sensational_one Peace Keeper Profil: New Penguin | Very Good Tutorial ! Nothing more to say about it. Though I already Stumbled across another Tutorial on the net , also made some for myself but I've seen some Interesting Results here. Cheers. | |
