coutinho Windows Customization & Support : sambbk and 20 unknown users
[Photoshop Tutorial] Terminal Window Icon
n°2167
i542
Posted on 04-04-2008 at 09:04:34 PM
Hi everyone!
I am i542 and this is my first post (and first tutorial here). Hope it's not last! :smile:
I will be creating a Terminal Window icon. This is the result I got:
http://www.i542.net/tutres/cmd_line_icon/Result.png
Section I. Creating icon
1. Bring up new document [CTRL+N], sized 256 x 256 pixels with transparent background
2. Use Rounded Rectangle Tool [U] to made a base...here:
http://www.i542.net/tutres/cmd_line_icon/Step2.png
3. Now double-click on layer with rounded rectangle (that will bring up the Layer Style dialog) and use these settings as Gradient overlay:
http://www.i542.net/tutres/cmd_line_icon/Step3.1.png
...and Drop Shadow.
http://www.i542.net/tutres/cmd_line_icon/Step3.2.png
4. Create new layer. Use Rectangle Marquee Tool [M] to select a rectangle in rounded rectangle. Fill it [SHIFT+F5] with black color.
5. Double click on layer with rectangle and use these settings as Stroke:
http://www.i542.net/tutres/cmd_line_icon/Step4.png
6. Type text [T] in terminal with some coolish font and in white color. I used Stencil Std.
Section II. Adding Gloss
1. Create new layer, name it „Gloss“.
2. Select white [FFFFFF] as your foregrounding color. Select Gradient tool and use settings below:
http://www.i542.net/tutres/cmd_line_icon/Step2a.png
3. Use Round Marquee Tool to select part where you want for gloss to appear.
4. Draw a gradient from top to half of image. Then control-click on layer with black rectangle. Select Inverse [CTRL+SHIFT+I] Make sure the gloss layer is selected, then press Delete button.
You are done. Any criticism/compliments are welcome :smile:
i542
n°2168
Posted on 04-04-2008 at 09:06:36 PM
Pretty good tutorial! :biggrin: I think the shadow isn't looking that good, but the rest looks very good. :great: Welcome to CrystalXP and thanks for your contribution! :party:
n°2169
i542
Posted on 04-04-2008 at 09:16:24 PM
Thanks :great:
n°2170
smashman
Posted on 04-04-2008 at 09:34:10 PM
Nice Effect!
I like it :biggrin:
Might try it later.
Umm...
Could I ask you to make your signature smaller though.
It's bigger than my screen width! :redface:
n°2173
i542
Posted on 04-05-2008 at 11:40:51 AM
smashman wrote :
Nice Effect!
I like it :biggrin:
Might try it later.
Umm...
uhm.... sorry ^^ doing it now.
Thanks on your comment :smile:
n°2174
darklady
Posted on 04-05-2008 at 04:33:36 PM
Interesting tutorial.  Will have to try this one tomorrow.  Thanks! (will post results :wink: )
EDIT:  Heres my go at it.
http://i165.photobucket.com/albums/u53/rene_kunert/CrystalXP/TerminalWindow.png
n°2192
Cerberus1991
Posted on 04-09-2008 at 08:43:24 PM
Cool Tut
5/5
Result:
http://i148.photobucket.com/albums/s12/kingorgg/Untitled-1-6.png
n°2212
i542
Posted on 04-15-2008 at 11:25:30 AM
Nice results :smile: Thank you for trying out my tutorial!  :great:
n°2213
Krat0s_
Posted on 04-15-2008 at 02:19:33 PM
Thanks for this nice tutorial, i542!  :wink:
n°2214
sosoe222
Posted on 04-15-2008 at 03:09:19 PM
HR :ar: Pozdrav! :smile: Odličan tutorijal :wink:
EN :ar: Hello! :smile: Great tutorial :wink:
n°2216
Posted on 04-15-2008 at 06:35:42 PM
Very useful tutorial indeed :smile: here's my outcome :
http://img178.imageshack.us/img178/7768/twzk4.png
n°2277
dura007k
Posted on 05-20-2008 at 09:51:41 PM
Thnx for this great tutorial
My result:
http://www.photoserver.ws/files/4bs8g8rg9402kw72qanj.png
n°2279
Posted on 05-22-2008 at 07:56:09 AM
Nice result dura007k! :oui: Why don't you try to crystallize it a bit? :biggrin:
n°2280
dura007k
Posted on 05-22-2008 at 05:39:26 PM
Because I don't know how to do it :neutral:
n°2281
Posted on 05-22-2008 at 06:16:13 PM
Perhaps have a look here. :oui: You can easily put a crystal look on the object with the round selection tool. Just make a selection and fill it with a white color or gradient. :happy2:
n°2282
coker
T : y = f'(a)(x-a) + f(a)
Profil: Top Penguin
Posted on 05-22-2008 at 06:48:26 PM
a little command box for me
I traced to your  tutorial, but, I made a 3D Command Box :mdr:
http://img232.imageshack.us/img232/2310/commandbox01by6.png
(sorry if my english isn't perfect)
n°2288
Posted on 05-23-2008 at 08:13:41 AM
I like your result. :oui: The 3D effect is looking good, and I like the color work as well. :biggrin: Don't worry about your English, no problems understanding you. :wink:
n°2289
Kyro
Posted on 05-23-2008 at 05:46:50 PM
i find your box a little bit to high, it looks like a square :err:
n°2290
coker
Profil: Top Penguin
Posted on 05-23-2008 at 07:01:38 PM
I begin in 3D with Photoshop, I forgot to resize my CommandBox for 3D effect
n°2295
dura007k
Posted on 05-24-2008 at 08:51:23 AM
How did you do it 3D with Photoshop, because I don't know :neutral:
n°2296
coker
Profil: Top Penguin
Posted on 05-24-2008 at 12:07:55 PM
with layer :mdr:
n°2297
swapnil0545
Posted on 05-24-2008 at 02:42:56 PM
Goto Tutorials Section You will get a "3dText Tutorial".
And you will learn to make it
n°2300
Posted on 05-24-2008 at 08:13:40 PM
You might get some useful tutorials here :wink:
n°3721
Posted on 01-24-2009 at 09:22:39 PM
Looks pretty good. :)
