| Aelitafan13 Profil: Penguin | Last message on previous page:
Gruzz wrote :
I'll try to. Usually step by step approach works best, so here we go. - Select layer 2, it will now turn blue on the layer window. - While holding Ctrl, click on the thumbnail of layer 1. This will make the area of layer 1 selected. Make sure that layer 2 is still blue, this is the layer you are actually going to work on! - Use Ctrl + Shift + I to inverse your selection. Now hit the delete key. This will delete a part of layer 2 if you did it correctly. - Use Ctrl + Shift + I again to inverse your selection back. Don't deselect it and continue with the rest of the tutorial.
Thanks. so simple. But, when I drag the texture layer on to the "circle" layer, and position it, it moves my elliptical shape I made | |
Gruzz Profil: Moderator | What do you mean with 'drag' the texture layer onto the circle layer? You are still working on step 6? | |
No, I backtracked because my friend interrupted me and I forgot where I was. Would u like to see screen shots? In step 5 I believe, he says to drag the texture layer you made onto the new layer (the circle you made). I did so and when I tried to cover the whole canvas, It cut off part of it. So I Ctrl-z(ed), and dragged the whole layer (texture) and it moved the elliptical circle. | |
Gruzz Profil: Moderator | Yes you can upload a screen shot if you want. I think that would be of help.  | |
Here , Here is my texture and my Circle:
 Here, I dragged it
 I moved it, It cut
 After I Ctrl-z(ed), I moved the layer. This happened
Gruzz Profil: Moderator | I now know what has probably caused the problem. You need to make sure that the white round you got is deselected (Ctrl + D) before you move the texture layer over to your newest canvas. | |
Ohh, your prob. right. Thanks  | |
