22 unknown users
Previous
[Photoshop Turorial] Make a Planet
n°2131
asmodeus999
Posted on 03-22-2008 at 05:21:45 AM
Step 1:
Creat a new (500x500px) image.
Step 2:
Select the brush tool and select a decent size. Go to the brushes palette and add a texture. I'm using a rocky texture, but it won't make a difference. Make sure the blending mode is set to 'Multiply.'
http://i81.photobucket.com/albums/j206/Asmodeus999/img1.png
Now brush all over your canvas.
Once you cover all your canvas, change the brush's texture to something different, then brush it over the canvas again. Do this a third time if you wish. You should have something similiar to this:
http://i81.photobucket.com/albums/j206/Asmodeus999/img2.png
Step 3:
Now your done with that, create a new 500x500px canvas (or the same size as the last one).
Step 4:
Make sure you have the defualt black and white colors selected. Then on the background layer, hit alt+backspace to fill it with black.
Now create a new layer and use the elliptical marquee tool while holding shift to click and drag a perfect circle. Leave about 40px on the edge for the atmosphere of the planet.
Hit alt+backspace to fill this selection with whatever color you want (I used magenta).
http://i81.photobucket.com/albums/j206/Asmodeus999/img3.png
Step 5:
Select the texture image you made in steps 1-2. Press 'V' or select the move tool to click and drag it onto the new image you made in step 3. Make sure it's covering the whole canvas.
Step 6:
This is a little bit tricky if your a newbie, it's hard to explain so i'll try my best. With layer 2 (the texture layer) selected, hold ctrl then click on layer 1's THUMBNAIL (the little image next to its name) this will create an elliptical selection.
Hit ctrl+shift+i then hit delete. Now hit ctrl+shift+i again. Don't deselect it yet.
Step 7:
Now go to filters>distort>spherize. Then use the defualt. Now hit ok, the ctrl+d to deselect the image.
Step 8:
Now Move layer 2 BELOW layer 1. Now we are going to make our atmosphere.
On Layer 1 double click it and apply these settings (make the glows whatever color you want your planet to be):
http://i81.photobucket.com/albums/j206/Asmodeus999/img5.png
http://i81.photobucket.com/albums/j206/Asmodeus999/img6.png
http://i81.photobucket.com/albums/j206/Asmodeus999/img7.png
Step 9:
Now on LAYER 2 (the texture layer) go to image>adjustments>hue/saturation.
In the bottom right of the dialog box is a check box that says 'colorize.' Make sure it is checked.
Now mess around with the settings until you get a color you like. Like this:
http://i81.photobucket.com/albums/j206/Asmodeus999/img8.png
Step 10:
Now you could be done with it and call this a planet. But it would look more realistic if you added a shadow to it. So create a NEW layer. Then use a black to transparent gradient. And click and drag it to where you want your light to come from. Then hit 'ctrl+t', right click, then select 'warp'.
http://i81.photobucket.com/albums/j206/Asmodeus999/img9.png
Step 11:
Move the gradient around a little and presto! Your done!
http://i81.photobucket.com/albums/j206/Asmodeus999/img10.png
I hope you learned something from this tutorial and incorperate it into your own ideas!
n°2132
Posted on 03-22-2008 at 08:02:14 AM
Wow, great tutorial! :loveit: Thanks a lot. I'm definitely going to try this one soon. And of course welcome to CrystalXP! :party:
n°2133
asmodeus999
Posted on 03-22-2008 at 04:18:21 PM
Thanks, glad you like it  :happy2:
n°2134
darklady
Posted on 03-22-2008 at 05:31:30 PM
I think I am going to have to try this one this evening.  Looks interesting :biggrin:  Will post results :wink:
Good tutorial, though I think it could have been written a little simpler.  Not a problem though :wink:
http://i165.photobucket.com/albums/u53/rene_kunert/CrystalXP/lightning.gif
n°2197
simplyfish
Posted on 04-11-2008 at 12:11:50 PM
I am a total noob to all this but I wanted to have a go, thank you for having something for begginers.
n°2250
Martian89
Posted on 04-22-2008 at 10:54:40 PM
It took me a litle while but I learned a lot of it! Here's my result :he:
http://www.marvin.johnvh.nl/artwork/planeet.png
n°2259
redfoxhound
Posted on 05-06-2008 at 11:51:00 PM
:idea: :idea: :idea:  Tnx a lot! I finally got it now! before i don't know how to do the shadow.
 :great: :cool:
:paf: :yipi: :didas:
n°2260
redfoxhound
Posted on 05-07-2008 at 06:25:33 AM
The only thing that bothhiners me is the shadow thingy. I got confused.
n°2261
redfoxhound
Posted on 05-07-2008 at 06:37:12 AM
Are you using photoshop cs? or cs 2?
n°2273
ianoob
Posted on 05-20-2008 at 04:05:57 PM
Hey, nice tutorial, i had a try at it here are my results  :great:  :mdr:
n°2405
KhainDesign
Posted on 06-11-2008 at 03:00:10 PM
Hahh! I did it! :biggrin:
It's awsome! I love this tuto :smile:  Here is my first result : the Planet Hell
http://mmoaddict.extra.hu/planet_hell.png
n°2406
KhainDesign
Posted on 06-11-2008 at 05:05:42 PM
:smile: I've made a whole picture based on this tuto and want you to  tell me your  opinion :smile:
http://mmoaddict.extra.hu/fantasy_space_png.png
It's better in full size :smile:
n°2409
Posted on 06-12-2008 at 09:23:20 AM
Pretty cool result you have there. :wink: I think that the 'glow' around the planets looks a bit weird in your image though. :oui: It's a bit too visible and isn't very realistic.
n°2411
earnur
Posted on 06-12-2008 at 11:04:01 AM
Yeah, Gruzz have a right. Try to decrease Spread and Size of Outer Glow :wink: And I think that mountains behind city are too much blured  :angel:
I like the city dome and reflections :great:
BTW below is my planet. I've made it couple months ago, not with that tutorial, byt by myself :smile:
http://img143.imageshack.us/img143/2399/space2kh9.jpg
n°2414
Krat0s_
Posted on 06-12-2008 at 12:34:30 PM
Great tutorial!!  :cool:
n°2415
KhainDesign
Posted on 06-12-2008 at 03:38:16 PM
i know.. but couldn't do anything special for the mountains...
you're right.. i'll correct the planets...
Can someone tell me how to create Textures? cuz i don't have so much presets, and the blue planet is a piece os s**t i think....
n°2422
earnur
Posted on 06-12-2008 at 07:45:41 PM
I've take my textures from Celestia3D program (virtual space). There is a lot of hi res textures :wink: Just look here
:ar: Link 1
or here
:ar: Link 2
n°2431
KhainDesign
Posted on 06-12-2008 at 09:56:18 PM
cool :smile: thanks! useful site :biggrin:
n°2433
earnur
Posted on 06-12-2008 at 10:30:35 PM
No problem bro :wink:
n°2453
codenamem2k
Posted on 06-14-2008 at 12:41:51 PM
Great work man!!! :boulay:
n°2487
techabhi
Posted on 06-22-2008 at 03:32:21 PM
awsm tut man...am kinda new here..but u all rock...thx a milln
n°2488
darklady
Posted on 06-22-2008 at 03:34:59 PM
That kind of speaking is not really allowed.  There are too many people that need to use online translators to read the posts.  SMS style language does not translate.
n°2523
Aelitafan13
Posted on 07-03-2008 at 07:35:47 PM
Step 6:
I don't really get this step. Can anyone tell it to me in a simple easier way?
n°2524
Posted on 07-03-2008 at 08:45:59 PM
I'll try to. :oui: Usually step by step approach works best, so here we go.
- Select layer 2, it will now turn blue on the layer window.
- While holding Ctrl, click on the thumbnail of layer 1. This will make the area of layer 1 selected. :smile: Make sure that layer 2 is still blue, this is the layer you are actually going to work on!
- Use Ctrl + Shift + I to inverse your selection. Now hit the delete key. This will delete a part of layer 2 if you did it correctly.
- Use Ctrl + Shift + I again to inverse your selection back. :oui: Don't deselect it and continue with the rest of the tutorial.
n°2525
Aelitafan13
Posted on 07-03-2008 at 08:49:05 PM
Thanks. :lol: so simple. But, when I drag the texture layer on to the "circle" layer, and position it, it moves my elliptical shape I made
Previous
Top
