jonagt, Tanshin Graphic Tutorials : antonious and 36 unknown users
 Page :  1  2  3  4  5  6  7  8  9  10  11  12  13
[Photoshop tutorial] Steel and glass icon tutorial
n°2038
Posted on 02-22-2008 at 04:28:13 PM
Ok I'll try to explain. :smile: It depends on the software you are using. I assume you are using Adobe Photoshop in this message. :wink:
- Go to 'File' menu and select 'New...'. A window will now appear.
- Here you can change the name, size resolution and some more.
- Search for 'Background Contents:' and make sure this option is set to ''Transparent' instead of 'White'.
Hopefully this helped you a bit! :biggrin:
n°2039
darklady
Posted on 02-22-2008 at 04:40:30 PM
Though you will still need to save it as as .png file instead of a .jpg.
When saving your file, there is a drop down menu called "format".  There you should choose the PNG (*.PNG) option.  GIF also saves transparency, but it will make your image look pixelated if you do not set the background color (matte) from the saving options.
Best bet would be a .png file.
Hope that helped as well :smile:
n°2040
Posted on 02-22-2008 at 07:18:32 PM
Yup that is definitely true. :great: It is argued to only use .jpg for photographs. :wink:
n°2041
byHeart
Posted on 02-23-2008 at 05:44:07 AM
How bout now??? But still dont know how to work with the letters. Thanx!!! :party:
n°2042
darklady
Posted on 02-23-2008 at 08:31:49 AM
Ah that is better.
Though you may want to increase the canvas size so it does not cut of small pieces of the edges.  The very bottom of it has just a tiny bit cut off.
MUCH better for sure! :biggrin:
n°2043
rahul123
Share Well to Make Well
Posted on 02-24-2008 at 02:30:26 PM
Nice tuto. very helpful. Created my avatar and some other things i m attachingpure_glass.png[attachment=232
7:fyfyfy151451fyfy.png]gyugyugugug.png[attachment=23289:fyfyf
fyfy.png]
n°2044
rahul123
Posted on 02-24-2008 at 02:56:54 PM
:frown: please tell me how to upload signature, when i go to edit signature there is no option for upload so how to upload sig
n°2045
Posted on 02-24-2008 at 03:11:15 PM
You'll have to upload your signature on an image upload server (or your own server). :smile: Just search for 'image host' on Google. :wink: Welcome to CrystalXP and enjoy your time here! :biggrin: Please read the rules as soon as possible as well. :angel:
n°2046
rahul123
Posted on 02-24-2008 at 08:50:07 PM
thanks 4 the help man. :happy2:
n°2050
pironic
Posted on 02-26-2008 at 07:13:59 AM
i've got two renditions of them... thoughts on my own variation of it?
http://members.writhem.com/michael/logos/pibutton.png
and the customized one, i added an extra layer to darken the center and add a bit of gloss over it. thoughts?
http://members.writhem.com/michael/logos/pibutton_gray.png
and of course, me and the red thing goes much beter than blue ;-)
n°2053
Posted on 02-26-2008 at 05:25:06 PM
Very nice pironic :great: I like the second one more
n°2055
Bobyoby
Posted on 02-27-2008 at 07:11:38 AM
sweet thanks, im kinda new so dont blame  me if i dont get this:
during the first ctrl d step it doesent do anything
is it to do with the fact that i have cs3?
n°2057
Posted on 02-27-2008 at 08:01:48 AM
Ctrl + D will deselect, if you followed the tutorial right, you would have a selection at that point. :wink: In step two you have to choose for the round selection tool. Now you have to fill the selection with black (I believe Shift + Backspace helps you with this). Once you've done that, you use Ctrl + D to deselect. Welcome to CrystalXP and I hope that this has helped you a bit! :biggrin:
pironic, pretty cool! :biggrin: Adding your own variations is often the best way to improve. :happy2:
n°2072
rahul123
Posted on 02-27-2008 at 05:44:36 PM
:aww: SIGNATURE is still not working, i've uploaded it on windowslive skydrive. Please tell a better image host. thanks in advance :oui:
n°2073
Posted on 02-27-2008 at 05:50:41 PM
ImageShack.uk is pretty popular. :wink:
n°2123
alex_darkfox
Posted on 03-16-2008 at 06:43:21 PM
I've made many of these but....how can I use them as an icon for windows?!?!?   :neutral:
n°2124
Posted on 03-16-2008 at 08:19:46 PM
Have a look here! :great: Welcome to CrystalXP. :biggrin:
n°2125
alex_darkfox
Posted on 03-16-2008 at 09:08:16 PM
thank you!!!! and excuse me if i make any language mistakes!!
n°2126
alex_darkfox
Posted on 03-17-2008 at 08:08:40 PM
I would ask you another thing.....there is any photoshop plug-in to create .cur and .ani cursors for windows?
n°2127
alsjaad
Posted on 03-20-2008 at 02:17:53 PM
thank's for the hard work, and this what i got
Click to see the picture
n°2128
Posted on 03-21-2008 at 02:56:24 AM
HI alsjaad and welcome to CrXP :smile:
Your outcome is quite precise :great: , keep it up :wink:
Have a nice stay :party:
n°2129
alsjaad
Posted on 03-21-2008 at 01:45:44 PM
Thank's for your reply...
and if you please, can you give me un idea or a simple picture in order to make these two words together as a logo or as a brand ( EVERHARD , 006) .
 and thank's in advance    :happy2:
n°2157
bajt
Posted on 03-30-2008 at 03:23:42 PM
I tryed 2-3 times and always look like this .... where do i misstake ? ;\
n°2164
myzani
Posted on 04-04-2008 at 10:53:17 AM
wow, you are great!
n°2193
.Diamond.
Posted on 04-10-2008 at 07:29:35 AM
:loveit: I just wanted to tell everyone that I absolutely love this site! As for this tutorial being sooooo longgggg lol I have had great results with it. I just wanted to say thanks for this great tutorial and this great site! Much appreciation to everyone that contributes to translation of tutorials, tutorials of their own and the ones that help others like me when it just isn't turning out right. The hospitality on this site is much appreciated by me and I am sure a lot others. :loveit:
n°2194
Posted on 04-10-2008 at 08:43:42 AM
Welcome to CrXP Diamond , this site has got plenty of tutorials but the number of French ones is greater than that of English , but the English section too has a bunch of them to teach and to help :oui: I hope you will enjoy your stay here :party:
Top
