| jas_28 Profil: New Penguin | Last message on previous page: hey, ya i did this and didnt get exactly what i hoped can anyone help? thnx here is what i got.. | |
jas_28 Profil: New Penguin | i dont no what im doing wrong i am following that exact thing. | |
Asher Genius is not born , it is made.... Profil: Moderator | Welcome to CrXP jas 28 , try downloading this PSD of mine , it will help you to understand the mistakes which you might have done while making your own icon | |
jas_28 Profil: New Penguin | thnx very much, i think ill try some other tutorials too | |
vakho123 Profil: New Penguin | | |
ady20079 Profil: New Penguin | cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool cool | |
dilip_singh111@yahoo.com Profil: New Penguin | hi i am dilip singh you say me which software help to devloping that
Gruzz Profil: Moderator | Welcome to CrystalXP. This tutorial was made for Adobe Photoshop, this program is not free though. You can try an other image editing program like The Gimp or Inkscape. Good luck!  | |
blak zero Profil: Penguin | hey thx you but i dont know do it i will still traying | |
m.magdi Profil: New Penguin | thank you so much for the tutorial but my result was a little odd so i added an animation to it to make it look better look
X-Ception Profil: New Penguin | looks good E-M@GDI - great tutorial, will have to give this tutorial a go at some point. | |
Mornothly Profil: Penguin | Thanks, but just like the porthole tut, I cannot make it for some strange reason....can someone please upp the PSD file? | |
lemasd00 Profil: New Penguin | Wohoo!! I'm a total noob-ass-idiot, but I MADE IT!!! TY xP | |
lallik1 Profil: Penguin | Then post the result by the way no one is considered noob on crystal xp  | |
shindong Profil: New Penguin | So beautiful!! You're so brilliant. Thanks for the tutorial. | |
byHeart Profil: New Penguin | I am lost!!! Please somebody tell me what version of photoshop are you using for this 'cause i have Ps CS2 and i get stucked on step12. it doesnt activate the option of rasterizing. and it doesnt seem to be doing anything about drawing the shape!!! Please Help!!!!  | |
Asher Genius is not born , it is made.... Profil: Moderator | Hi byHeart  Only a vector layer can be rastersized , you must make sure that you are making the paw-shape by using Shape-Tool , after that just right-click on the paw layer in Layers-Palette and select 'Rastersize' from the menu (see this image ) , you can also achieve the result without rastersizing the layer  Have a nice stay  | |
byHeart Profil: New Penguin | Thanx but i guess this is bad cuz this is the best i could get. Still dont undestand the drawing and rasterizing part, but thanx anyways i had fun!!! Guess practice makes perfection.
BrahimX Profil: New Penguin | Yo =D I just work with Photoshop a month, so i'm looking for some good Tut's and found really good tuts here where i downloaden Inspirate. ^^ What do you think about this one? =D
BrahimX Profil: New Penguin | Strange, it's cut a little. =/ | |
byHeart Profil: New Penguin | Look at this one  | |
byHeart Profil: New Penguin | oops i got into this I really like it, hope you like it too. getting better...  | |
Gruzz Profil: Moderator | Definitely! I still think the text can be improved a lot. Also, why don't you create something on a transparent background? At the moment all your works are on a white background which looks a little bit silly. Enjoy CrystalXP!
byHeart Profil: New Penguin | can you explai step by step like i am a 5 year old??? pls cus i try but it always goes out white!!!  | |
Gruzz Profil: Moderator | Ok I'll try to explain. It depends on the software you are using. I assume you are using Adobe Photoshop in this message.  - Go to 'File' menu and select 'New...'. A window will now appear. - Here you can change the name, size resolution and some more. - Search for 'Background Contents:' and make sure this option is set to ''Transparent' instead of 'White'. Hopefully this helped you a bit!  | |
