29 unknown users
 Page :  1  2  3  4  5  6  7  8  9  10  11  12  13
[Photoshop tutorial] Steel and glass icon tutorial
n°1538
simon.maildude@gmail.com
Posted on 06-28-2007 at 01:34:59 AM
ArcticWolf wrote :
Ok I am so new to Photoshop that I do not know how to merge all the 3 layers together, can anyone help me out, and how to save it... Thanks
Hit Ctrl-E :wink:
n°1539
ArcticWolf
Posted on 06-28-2007 at 01:47:56 AM
Hit Ctrl-E :wink:
Guh, perhaps I messed up because CTRL-E didn't work or perhaps maybe it's because I'm using Photoshop 7
n°1540
Posted on 06-28-2007 at 02:06:36 AM
Oh. Layer->Merge Layers, then. :mdr:
n°1541
ArcticWolf
Posted on 06-28-2007 at 04:00:45 AM
Hmmm I didn't do a bad job, but something with the glass is wrong although the settings are correct :ouch:... 1st attempt is not bad, second one is better.
n°1542
Posted on 06-28-2007 at 07:24:58 AM
If you hold the Shift button, you can click multiple layers. If you then right-click one of the layers, you're able to merge them. You can also use Ctrl + E to merge them (but the layers should be selected). Good luck! :great:
n°1545
ArcticWolf
Posted on 06-29-2007 at 11:16:16 PM
Alright I noticed that whoever did this tutorial didn't come out with an icon that looks like the original by k_millio with such a nice glass effect and I have gone over the settings 3 times over..... perhaps k_millio wouldn't mind sharing that extra secret,lol .... but i noticed something in the tutorial that is missing.... in each section of the "contour" area you can see the "anti-alias" is turned on..... but you can never see the range it is set at. Perhaps that can be included.
Thanks
n°1556
kstor
Posted on 07-02-2007 at 05:23:12 PM
the mortal kombat logo
http://mgonzalez1kin.googlepages.com/chapamkcopia.png/chapamkcopia-full.jpg
n°1557
Posted on 07-02-2007 at 05:48:03 PM
Nice one kstor. Try to use a transparent background next time though.  :wink:
n°1581
des99
Posted on 07-10-2007 at 04:53:39 PM
Wow!! k_millio what a great tutorial, have not used photoshop before as my work mate said it was a little daunting  :beurk: to tackle so i am really greatfull for the easy to follow tutorial :great: My creation never came out like the original but it gives me a good step in the right direction thank you :loveit:
Ps love how you guys helped out with the buttons for Zoozee
n°1606
rolff56
Posted on 07-26-2007 at 07:21:09 AM
Well.... Tha's my result!!! :neutral:
What do you think????
n°1607
Posted on 07-26-2007 at 10:11:17 AM
Welcome to CrystalXP! :loveit: Your result looks nice, but the image is cut of at the sides. You should try to start with a bigger canvas next time (or make a smaller round). :wink:
n°1614
Megazrael
Posted on 07-31-2007 at 05:50:49 PM
Nice one!
Look what i've get in the first try :biggrin:
http://img65.imageshack.us/img65/9915/sinttulo1copiatj6.png
(sory about my english)
n°1615
Posted on 07-31-2007 at 06:31:44 PM
Nice result! :biggrin: Why don't you try to use a transparent background next time?
n°1618
rolff56
Posted on 08-03-2007 at 12:11:56 AM
Ok! :great:
I tried again and this is my result :loveit:
What do you think now? :happy2:
n°1619
zonzio
Posted on 08-03-2007 at 01:37:13 AM
nice dude  :great:
n°1627
xevash
Posted on 08-05-2007 at 06:32:00 PM
Wow, thanks! Here was my result:
n°1628
Posted on 08-05-2007 at 07:21:15 PM
That's very creative! Welcome to CrystalXP! :wink: Your image is cut a bit on the bottom too, but the total image looks nice. :biggrin:
n°1629
xevash
Posted on 08-05-2007 at 08:22:54 PM
Thanks for the welcome :smile:
Better?
n°1630
..doddles101..
Posted on 08-07-2007 at 03:39:33 AM
Yea I think putting the Firefox guy in the middle of the icon is a good effect, looks great :great:
n°1632
Posted on 08-07-2007 at 08:52:35 AM
I think it looks better indeed! :oui:
n°1633
teddyrised
Posted on 08-11-2007 at 03:56:36 PM
Hey there thanks for sharing this wonderful tutorial! After several tries I've finally made a decent looking glassy icon :loveit: here is mine... heh!
http://img403.imageshack.us/img403/875/steelandglassiconsmallnq5.png
How is it?
n°1634
Posted on 08-11-2007 at 03:58:33 PM
It's great! :biggrin: I hope you like this tutorial as much as I do. :wink: You should try to create your work on a transparent background next time. Perhaps your claw should a little smaller too, it's hitting the edges at the moment. :great:
n°1635
Nuwanda
Posted on 08-12-2007 at 12:04:19 AM
how can I use this icon in windows view?how can you save .ico format with photoshop?
n°1636
Posted on 08-12-2007 at 08:17:29 AM
You can't save .ico files in Photoshop without a plugin. You can find some .png to .ico transforms on the internet though. :wink:
n°1637
rolff56
Posted on 08-12-2007 at 06:50:44 PM
Hi!!!  :happy2:
If you want to transform .png files to .ico; go to this web site. They do it for free Punk Software - Projects  :great:
n°1638
Posted on 08-13-2007 at 05:13:22 AM
Welcome to Crystal XP Nuwanda and Rolff
You can also use ToYcon which is a free and easy-to-use program :oui: (just drag & drop the png file in the box :wink:)
Top
