| Asher Genius is not born , it is made.... Profil: Moderator | Last message on previous page: Welcome to CrXP Diamond , this site has got plenty of tutorials but the number of French ones is greater than that of English , but the English section too has a bunch of them to teach and to help I hope you will enjoy your stay here  | |
dura007k Profil: New Penguin | Thnx for this great tutorial My results, It is Ok ?
Gruzz Profil: Moderator | Yes it looks pretty good! Welcome to CrystalXP.  | |
dura007k Profil: New Penguin | Look another:
Asher Genius is not born , it is made.... Profil: Moderator | The second result is good too but I think it will look better if you put same color on the shape and the steel frame  | |
dura007k Profil: New Penguin | Like this :
Asher Genius is not born , it is made.... Profil: Moderator | In my opinion it looks better  | |
Gruzz Profil: Moderator | Pretty good! Try to work on a larger document next time though, at the moment a bit of the red is falling off in the bottom. | |
Martian89 Profil: New Penguin | Well, I had a well spent evening! This is my result:  But I don't understand why the shiny part at the left top won't expand like the example  | |
KylianG Profil: New Penguin | nice i made one | |
Martian89 Profil: New Penguin | Other icon's then a cat print and an other color    I still can't find out why the shiny part won't do his work properly  | |
Welcome to CrystalXP! Pretty cool results. Can you tell me what step of the tutorial gives you problems?
Martian89 Profil: New Penguin | Thank You  I believe my problem is in the second black spot layer, in the example the reflection that's made at the top left of the image is bigger than mine. And I have no clue why mine stay's small  | |
Gruzz Profil: Moderator | Did you unhide/hide all the correct layers? Pay attention to where you have to hide and unhide in the tutorial. Also check all blend modes + opacity's of all the layer styles. Probably something went wrong there.  | |
I checked everything... About three times now I believe, and I can't find it Shall I upload my .psd file? | |
Gruzz Profil: Moderator | Yes please. I won't say that any of us will be able to find what's wrong, but I promise to have a look for you.  | |
Here's a link to the .PSD File Thanks in advance  | |
Gruzz Profil: Moderator | I found some small mistakes in your .psd file. They changed the gloss slightly and the outer border pretty much. I have added the edited .psd file to this post. The mistakes where found in the layer called 'Layer 1 Copy 2'. You forgot to uncheck 'use global light', it changes the light source drastically if you uncheck it. To get a bigger gloss, change the dept in 'Bevel and Emboss' in 'Layer 1 copy 1'. I don't think that it looks any better if you change it though. Hope that you've learned a bit by this.  Kattenpootje_v2.1.psd | |
Martian89 Profil: New Penguin | | |
unleashjithu Profil: New Penguin | j nice work man
MAGALI_013_CORRALON Profil: New Penguin | hello I am new to this photoshop and would like to know what kind of fotoshop I have to do? ________________________________________________________________________________ ___________ M A G A L I
sosoe222 Profil: Penguin Pro | Hi, Andrea!  Welcome to CrystalXP. I think Photoshop 7 will be enough for this tutorial. Have fun  | |
nynja-penguin Profil: New Penguin | Ok, i ran across this forum years ago when the first tux came out and thought it was great, havent thought about it since lol. I ran across it again last night while looking for some photoshop help, well.. heres what i did.
codenamem2k Profil: Big Penguin | By the way, great result Martian  | |
Gruzz Profil: Moderator | That's a very nice result there. The brown shadow is a bit cut in the bottom though. I love your highlight work though! Especially in the upper left corner. | |
