23 unknown users
 Page :  1  2  3
Previous
[Photoshop tutorial] Create a 3D Vista avatar
n°1966
Posted on 01-27-2008 at 08:37:12 PM
This tutorial was made in French by cool-rabbits. You can find the original tutorial  here. :biggrin: Thanks for the good tutorial! :great:
My job in this was to translate it into English, I hope you enjoy it! :wink: Two things motivated me to put some hours in this. 1) the quality of the original tutorial and 2) the request of a pretty new and nice English forum member. Right, here we go, hold steady!
   Create an avatar/signature pack Vista 3D:
   A/ The base.
1) We’ll start with making the avatar. Create a new document with a size of 256 by 256 pixels, transparent background. Call the document « Avatar Vista3D ». Zoom in to 200%.
   2) To help you see the different effects (size of the shadow, external effects, etc.) fill layer 1 with a white color. Use Alt+Backspace to fill the layer fast. Create a new layer (Ctrl + Shift + N).
   3) We’ll use the rulers to center our avatar. First, show the rulers (Ctrl + R). Click on the left measure bar and drag to the right. Use the Shift key to the 4th little stripe on the ruler. Repeat this operation on the other rulers. You should obtain the following result (all previews are posted with a 100% zoom, so the rulers are a bit different!;).
 http://img357.imageshack.us/img357/712/1fx6.png
  4) Select the Rounded Rectangle Tool, with a radius of 10 px. Create a rectangle, with help of the rulers, just like this (use the 1st of the three options (Shape layers), and select black as your foreground color):
 http://img181.imageshack.us/img181/231/2hm8.png
 5) Select the Movement tool (V) and choose Edit -> Free Transform Path (or Ctrl + T). Use the Ctrl key to change the upper left and right corner. Apply a transformation like this:
 http://img181.imageshack.us/img181/3999/3rx8.png
 6) We are still in the Free Transform option. Now flatten the rectangle as in the picture (it doesn’t matter what edge you take (up or down), because you’ll have to hold the Alt key):
 http://img181.imageshack.us/img181/268/4ax0.png
 7) Without leaving the Free Transform option, use the Shift key and the up arrow to move the rectangle 10 pixels up. You can now click Enter to apply the transformation(s).
8 ) Now you’ll start seeing the 3D shape. Duplicate layer 1, and place the copy under the original layer. Hold the Shift key and move the duplicated shape 10 pixels downwards (make sure the movement tool is selected). Once you remove the rulers, you start to get a general idea of the shape in 3D. A small defect ruins the impression for us, it is circled on this picture:
http://img181.imageshack.us/img181/681/5yb4.png
 9) To correct this mistake, we’ll use the Pen Tool (P). But it’s necessary to rasterize the two shapes first. To do this, right click on a mask and select ‘Rasterize Vector Mask’. Do this for both layers. Once you are done, create a shape like this:
 http://img485.imageshack.us/img485/7091/6vc6.png
 10) Right click the path, and select ‘Make Selection’ (Anti-aliased, Feather radius: 0 pixels). Fill the selection with black (make sure your active layer is the original layer). Repeat this operation on the other side (right).
 http://img292.imageshack.us/img292/181/7wz4.png
 11) Select layer one and hold Ctrl while you click on its thumbnail (this will select the layers objects). Go to Select -> Modify -> Contract, contract by 15 pixels and hit delete. Do the same for the duplicated layer. If you select the first layer, you can clearly see the 3D shape:
 http://img485.imageshack.us/img485/8132/8ij4.png
 12) Before we begin with applying several effects (crystallization, shadow, etc.) select the duplicated layer. Ctrl + left click on the thumbnail of layer 1 to make this a selection and hit delete (you should have deleted something from the duplicated layer now). This will have influence if you apply a transparency effect.
   B/ The effects.
 1) We will start with the crystallization.
   2) Create a new layer. Then Ctrl + left click on the thumbnail of layer 1. Go to Selection -> Modify -> Contract, and contract by 1 pixel. Select the Gradient Tool (G) (make sure the gradient color is white to transparent) and make a gradient like this:
 http://img485.imageshack.us/img485/195/9vt9.png
 3) Now select the Rectangular Selection Tool, and make a selection like in the image. Then hit delete.
 http://img181.imageshack.us/img181/4836/10xy9.png
 4) Reduce the opacity to 40%. Select layer 1 and contract with 1 pixel again. Create a new layer and apply a new gradient from white to transparent, like in the picture:
 http://img183.imageshack.us/img183/84/11qj5.png
 5) Make a selection as in the image below. Hit delete and set the opacity to 40%.
 http://img358.imageshack.us/img358/981/12xw2.png
 6) You should have something like this:
 http://img183.imageshack.us/img183/8627/13jd2.png
 7) Create a new layer. Ctrl + left click on the 1st layer and fill with white. Click on Select -> Transform Selection. Hit the up arrow twice (this will move the selection upwards by 2 pixels), then hit delete. Reduce the opacity to 70%, we now have something like this:
 http://img183.imageshack.us/img183/4083/14ez0.png
 8 ) Now to the lower part. Place a vertical ruler in the centre of the image (at 180 pixels). Control + left click on the thumbnail of layer 1, and create a new layer above layer 1. Select the Gradient Tool  (from white to transparent). Trace a gradient to arrive at the central indicator. Reduce the opacity to 30%. (I am not 100% sure about this translation, hopefully the image helps you a bit!;)
 http://img358.imageshack.us/img358/8131/15nh0.png
 9) Select the duplicated version of layer 1 and create a new layer. With the Gradient Tool, draw 2 small layered gradients as seen on the picture below. After this, hit Ctrl + Shift + I (invert selection) and hit delete. Now all gradient parts are inside the avatar. Reduce the opacity to 65%.
 http://img456.imageshack.us/img456/4518/16jk6.png
 10) At the finish, we’ll add a drop shadow. Create a new layer above layer 1. While holding Ctrl and Shift, click on both the thumbnail of layer 1 and duplicated layer 1. Fill with any colour you like and lower the opacity to 0%. Open the Layer Style box and apply a shadow as seen below:
 11) To achieve the Aero look of Vista, we have to apply a light transparency to the framework. To do this, lower the opacity of layer 1 and duplicated layer 1 to 70%. Hopefully you’ll see something like this:
 http://img246.imageshack.us/img246/4136/18nh9.png
  C/ Apply a background.
 1) To do this, start with opening the picture that you wish to have in your framework (Windows Vista wallpapers  will do great, as well as most landscapes). With the Movement Tool, slip it into your .psd document.
 PS: I recommend you to create a group called ‘Background’ underneath the lowest layer, where you will put all the following (as well as the first step).
 Place the background in the folder and transform and place it in a nice position.
 http://img358.imageshack.us/img358/8518/19ai7.png
 2) Reduce the opacity of the first layer and the duplicated first layer to match the dominating colour in the background, I chose 65%.
   3) To restore the Aero style of Vista, it is necessary to apply a Gaussian Blur  to the picture that is located under the now transparent borders. To do this, first duplicate the background picture (Ctrl + J). Now apply the Gaussian Blur of around 3 pixels (Filters -> Blur -> Gaussian Blur). Now Ctrl + left click on the thumbnail of the layer above the group called background (if this is the layer where all shapes are on, so you select everything). Hit Ctrl + Shift + I (invert selection) and then hit delete. Now hit Ctrl + E to merge it with the other background image.
4) To cut the background to the size of the framework, we have to make a new selection. Use Ctrl + left click on the layer where all shapes are on. Select the Lasso Selection Tool (L) and, while holding Shift, make sure the selection looks like this:
 http://img237.imageshack.us/img237/9640/20ce8.png
 5) Still at the background layer, use Ctrl + Shift + I (invert selection) and hit Delete.
 http://img237.imageshack.us/img237/5389/21qr1.png
 6) As you can see on the previous picture, the result looks pretty well (for those who want, you can find the wallpaper here). We will finish this avatar by applying a small text. Create a new layer above all layers and select the Text tool and write your text where you want it. I chose to corner it on the bottom right. I used the font ‘Segoe UI’ (standard with Windows Vista), with a size around 30 points. I applied a white external glow and a drop shadow, but you can choose your own style.
 7) Now nothing more rests to save the picture as .png, reduce the image size to 128 by 128 pixels and use it as an avatar on CrystalXP!
   My final result:
 http://img181.imageshack.us/img181/7159/22fp3.png
 With a little bit of variation, results like these are possible too:
http://img58.imageshack.us/img58/3729/23mk6.pnghttp://img58.imageshack.us/img58/6361/24db5.pnghttp://img143.imageshack.us/img143/1889/25zi3.png
You can of course use your own background picture, different opacity, thickness, color, etc! :biggrin:
If you want to create a signature, it is smart to create a document with the double size of the size of the image you want it to be (560 by 140 for CrystalXP). :wink:
I hope that this tutorial has motivated you to do more. You can post your opinions, critics or congratulations here. :happy2: Do not forget to post your realized creations! Thanks again to cool-rabbits for the tutorial! :great:
n°1967
Clarkieboy
Posted on 01-27-2008 at 09:14:51 PM
Wow. Very good tutorial you got there Gruzz. :smile:
Thanks for translating. I will try to make this icon.
n°1968
YaniV.O.D
Posted on 01-28-2008 at 09:01:08 AM
Nice tutorial it's pretty cool
n°1969
TheVestel
PHP Programmer
Posted on 01-28-2008 at 04:49:57 PM
This tutorial is very good, Gruzz! Did you create it by yourself? Because I think this is really cool to make. I will try to make it when I have a little bit more time, because it is a very long tutorial!
n°1971
darklady
Posted on 01-28-2008 at 05:25:24 PM
Thank you so much for the translation!!!  I will get on this one in the morning as soon as I get home!
Much Much appreciated!
n°1972
Posted on 01-28-2008 at 05:57:43 PM
I believe I stated pretty clear that this is a translation from a French tutorial by cool-rabbit. :neutral: Thanks everyone for the positive comments so far, to see these comments.. it makes it worth the trouble. :smile: Don't be afraid to jump in and show everyone your results! :great:
n°1976
Damballa
Posted on 01-29-2008 at 05:30:17 AM
Thanks you ! :biggrin:!
ive waiting this !
PS: you wrote "ill layer 1 with a white color. Use Shift+Enter to fill the layer fast." you mean Alt+Backspace?
another thing D:
"6) We are still in the Free Transform option. Now flatten the rectangle as in the picture (it doesn’t matter what edge you take (up or down), because you’ll have to hold the Alt key):"
flatten or razterise?
cause if i do flatten the rectangle mix with the white background :err:
rasterizing.. you get the rectangle with transparent background... i think is rasterize or im wrong?
n°1977
Posted on 01-29-2008 at 08:25:19 AM
That's right! Mistake fixed. :great:
With flatten we just mean that the rectangle becomes more 'flat'. If you compare the pictures from step 5 and 6 you'll be able to spot the difference! :wink:
n°1978
darklady
Posted on 01-29-2008 at 01:34:02 PM
I have a small question... How can I get rid of the aliasing on the sides?  (without having to turn completely to the pen tool)
http://i165.photobucket.com/albums/u53/rene_kunert/Untitled-1-1.png
I feel honoured! :biggrin:
n°1979
Posted on 01-29-2008 at 01:41:26 PM
A tactic often used is to begin with a bigger document. Then when you are done, resize it and there will be less/none aliasing. :wink: But, why don't you try if you can fix it with the pen tool? :smile:
n°1980
darklady
Posted on 01-29-2008 at 01:51:05 PM
Yeah for some reason resizing did not come to mind... o.0
Anyway, I actually suceeded with the pen tool after all lol
http://i165.photobucket.com/albums/u53/rene_kunert/Untitled-1-2.png
n°1982
Damballa
Posted on 01-29-2008 at 05:07:56 PM
I want to do it but because of my poor english its hard for me xD
Here I die..
Maybe someone want to do a spanish translation O_O :biggrin: haha
n°1994
Damballa
Posted on 02-08-2008 at 02:05:50 AM
Please help me with the item 10)
Dont understand what is the objetive of that pen :frown:
I think fix the border but dunno how :ouch:
n°1997
Posted on 02-08-2008 at 09:09:21 AM
There'll always be a little aliasing. Step 10 will remove this aliasing by using the Pen Tool. :wink: You'll just draw a bit of extra pixels to cover the aliasing. I hope you'll understand now! :happy2:
n°2002
Damballa
Posted on 02-08-2008 at 07:18:40 PM
Thanks for answer..
I see the point more clear now of the point 10)
but definitely I need a video.. thanks for the effort anyways xD
Look:
http://xs224.xs.to/xs224/08065/dibujo413.pnghttp://img181.imageshack.us/img181/681/5yb4.png
I see that img's are different.. mine doesnt have like cuted in the corners o.O
anyways, i know my image need fix.. cause isnt smooth in all the borders (right, left sides)
n°2047
pironic
Posted on 02-25-2008 at 06:58:33 AM
yay for my first post... i've been following quite a few of the tutorials and it really does help to have these for us newbies that want to get into the area. Thanks so much for taking the time to translate... i can't speak french so this really helps.
n°2048
Posted on 02-25-2008 at 07:58:40 AM
Welcome to CrystalXP! :biggrin: We would appreciate if you would post your result here. :wink: Perhaps we can give you tips to improve yourself as well.
n°2049
pironic
Posted on 02-26-2008 at 04:59:27 AM
Thanks for the welcome Gruzz, its actually my avatar for now...
http://members.writhem.com/michael/logos/vistavatar.png
I've also made the sticky'd tux's but i havn't put them on my site yet. I'll have to do that as soon as i get home!
by the looks of it, its such a warm community here... i think i need to do some more tutorials on how to crystalize before i feel comfortable enough on doing my graphic from start.
n°2051
Posted on 02-26-2008 at 08:00:06 AM
We do the best we can to help each other. :happy2: Not only Team members but also normal members who are actively participating. :great: About your avatar result, I think it's looking good. I see that you have added some text as well, including a shadow. I don't really like the shadow which is under the text though. Have you thought of any other ways to implant the text into the avatar? :smile: For example you can put it in one of the borders, put on a black stroke and then reduce the opacity of the layer in the Layer Style dialog. This way you can only see the black stroke, which sometimes gives great results. :biggrin: Try it out when you've got time for it. :wink:
n°2052
TheVestel
PHP Programmer
Posted on 02-26-2008 at 05:01:59 PM
Nice! :great:
n°2054
pironic
Posted on 02-27-2008 at 06:53:59 AM
Hey Gruzz, thanks again for the advise, i've tried a few things. Here are a couple ideas. I really like that effect you mentioned regarding the stroke, i think i'll have to find a use for it in the future. Not sure this really works in this case though. Thoughts?
#1 http://members.writhem.com/michael/logos/crystal/vistavatar_clear.png #2 http://members.writhem.com/michael/logos/crystal/vistavatar_clear2.png
n°2056
darklady
Posted on 02-27-2008 at 07:37:57 AM
I think adding a slight inner shadow to the #2 name would make it really stand out (or rather in) :wink:
n°2058
pironic
Posted on 02-27-2008 at 08:05:28 AM
right you were... it stands 'in' quite nicely. *chuckle* thanks for the tip, DarkLady
http://members.writhem.com/michael/logos/crystal/vistavatar_clear3.png
n°2064
Posted on 02-27-2008 at 09:14:08 AM
Nice outcome and good idea DarkLady. :great:
n°2069
darklady
Posted on 02-27-2008 at 02:35:22 PM
Very nice for sure!
My pleasure :wink: That's what I'm here for :biggrin:
 Page :  1  2  3
Previous
Top
