24 unknown users
 Page :  1  2  3
Previous
[Photoshop tutorial] Make a shirt for your G2 Tux
n°111
vIcO
Posted on 10-08-2005 at 10:06:28 PM
Hi, this tutorial introduced how to make a trousers for your Tux G2 with Photoshop :smile:
You can find k-net 's original tutorial in french here  :smile:
1. First, save the trousers's pattern :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/patron_pantalon.png
2. Open this pattern with Photoshop, Selection>Select all and Edition>Copy.
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/02.jpg
3. Open your tux file which will wear the trousers, place you on the folder at the top (normally the tux one), create a new folder named "Trousers", and make Edition>Past. You will rename the tracing "Trousers's pattern".
Now, move correctly the trousers on the tux :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/03.jpg
Now that the trousers is placed, you have to choose a texture or color for it.
Some examples of textures :
-Jeans's texture http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/texture_jean.jpg
-Leather's texture http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/texture_cuir.jpg
-Checked texture http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/texture_petits-carreaux.jpg
-Checked texture 2 http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/texture_grands-carreaux.jpg
You can create yourself a texture from a clothe photo : the size can not be under 190px * 60px.
If you chose a color read the 4.a, or if you chose a texture, read the 4.b. I will continue the tutorial with the Jeans's texture.
4.a. Color for the trousers
Make Ctrl+clic on the tracing "Trousers's pattern", create a new tracing named "Trousers" and fill it of the color you want. Make Ctrl+d for unselect and delete the trousers's tracing.
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/04a.jpg
4.b. Texture for the trousers
Open the texture file, make Ctrl+a to select all and Ctrl+c to past. Place you in the tux folder, select the "Trousers's pattern" tracing, make Ctrl+v to past. Rename this new tracing "Trousers", and place it over the pattern, like it :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/04b.1.jpg
Make Ctrl+clic on the pattern tracing, and Ctrl+Shift+i to reverse the selection, and delete. The tracing which contains the texture has now the trousers form, and you can delete the "Trousers's pattern" tracing.
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/04b.2.jpg
5. You could notice that the Overlord59's G2 Tux has not visible legs. So, we have to create a crotch. Take the lasso tool, and draw a selection like that :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/05.1.jpg
Open the Tux folder, and clic delete this tracings : "Body", "Reflection 2 body", "White mark", "Reflection 2 white mark", "Intern shadow left foot", "Intern shadow right foot".
Look the result :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/05.2.jpg
6. Let's talk about the belt. Create a new tracing "Belt". With the circular selection tool, make a selection like this :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/06.1.jpg
Choose the gradient tool. The gradient has to be reflect type. For the first ground color, insert R:91 V:81 B:71 (#5B5147) and for the second R:62 V:55 B:48 (#3E3730). Draw your gradient from A to B.
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/06.2.jpg
7. Do not unselect and clic Selection > Transform the selection (Be careful : don't clic "Manual selection";). Delete 9 pixels (about, it depends of your future belt wide) into Y
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/07.1.jpg
Clic delete. Do alt+clic on the trousers tracing, do Selection > Modify > extend and put 2 pixels. Do Ctrl+Shift+i and Delete. You should have that :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/07.2.jpg
8. Now we'll work with the four straps which keep the belt :
Save the strap pattern :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/patron_sangle.png
Open it, do Ctrl+a (all select), Ctrl+c (copy), go in you tux file and do Ctrl+v (past).
Get back the selection of the new tracing (Ctrl+clic) and repeat the stage 4 but this time with the strap form, the tracing created will be called "Strap 1".
Put this tracing like that :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/08.jpg
9. Double clic on the tracing picture and a window appear. Go in Color Encrust, choose "Multiply" like fusion mode, put black on color and regulate opacity on 15%.
Look the result : the strap is a little bit more dark :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/09.jpg
10. Duplicate the  "Strap " tracing to "Strap 4". Do Edition > Transform > Horizontal Reverse. Move this tracing to the belt other side, on the opposite of "Strap 1".
Now duplicate "Strap 1" in ""Strap 2" and "Strap 4" in "Strap 3". Put "Strap 2" and "Strap 3" like that :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/10.jpg
11. Position yourself on "Strap 4" tracing (which is the highest) and create a new tracing called "Buckle".
With the Rectangular Selection tool, draw a selection like this :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/11.1.jpg
Put theses values for the first ground color : R:171 G:171 B:171 (#ABABAB) and for the 2nd ground : R:132 G:132 B:132 (#848484). With the gradient tool, in reflect type, draw a gradient from the selection center to the right border. Result :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/11.2.jpg
Forms are now finished, let's talk about reflects :
12. Select "Trousers" tracing, do Ctrl+clic on it, and create a new tracing named "Trousers Reflect". Put white in the 1st ground color. Make a gradient (linear type) (foreground to transparent) from the low to the top of the trousers. Regulate "Trousers Reflect" opacity on 30%.
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/12.jpg
13. Create a new tracing "Trousers shadow". Do a selection medium and move it, its right border has to be in the middle of the trousers :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/13.1.jpg
Put black in 1st ground color, take the Gradient of Reflect Type (foreground to transparent), and fill reverse case.
Make the gradient from A to B :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/13.2.jpg
Press Ctrl+Shift+i and do the same thing for the other leg. Do Ctrl+clic on "Trousers" tracing, and Ctrl+Shift+i and Delete.
Drop "Trousers shadow" tracing opacity at 50%. This is what you shoud have :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/13.3.jpg
14. Select "Belt" tracing, do Ctrl +clic and create a new tracing "Belt reflect". Do Selection > Modify > Contract and put 1 like value. Put white in foreground color. Take linear type gradient, foreground to transparent, unfill Reverse and draw like this
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/14.jpg
Regulate tracing opacity at 20%.
15. Double clic on "Buckle" tracing. A window appears, clic on Internal Shadow. Unfill "Use total lighting" and regulate that : opacity: 50% ; angle: -90° ; distance : 2px ; Size : 3px.
16. Create a tracing named 'Buckle reflect". With the circular selection tool, draw a selection like this :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/16.1.jpg
Make a gradient from white to transparent from the top of the buckle to the low of the selection. Do Ctrl+clic on "Buckle" tracing, and Selection > Modify > Contract and write 1 in the value. Do Ctrl+Shift+i and Delete. Put 75% in the tracing opacity.
This is the result you have to obtain if you didn't make mistakes :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/16.2.jpg
17. Select "Strap 4" and do Ctrl+clic on "Strap 1". Create a new tracing "Strap 1 Reflect". Go to Selection > Modify > Contract and put 1 pixel like contracting value.
Make a gradient from A to B :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/17.jpg
Unselect (Ctrl+d) and reduce this tracing opacity at 25%.
18. Duplicate "Strap 1 reflect" in "Strap 2 reflect". Move it on the 2nd strap. Duplicate it one more time in "Strap 3 reflect". This time, go to Edition > Transform > Horizontal Reverse. Move it on the 3rd strap and duplicate it in "Strap 4 reflect" to put it on the last strap.
:zzz: Don't sleep now, you have finished the trousers!!  :oh:
If you did the Tee-shirt in Overlord59's tutorial, you'll have to cut it (not Overlord :wink: ) according to the trousers size you would like.
19. To cut the Tee-shirt bottom, do a selection like that :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/19.jpg
Press Ctrl+Shift+i to reverse the selection, and Delete (always selecting) one by one "Body clothe", "Body clothe shadow area" and "Body clothe reflect".
Do again operation if the Tee-shirt is already too low (hide tee-shirt folder to see better where the trousers stop).
Finally, you should obtain something like this :
http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/final.png http://www.knet.free.fr/crystalxp.net/2005/07/tuto_pantalon/final_t-shirt.png
Now, personalize yourself your trousers!!
Again much thanks to K-net for his tutorial and his authorization.  :biggrin:
n°144
bakayoko
Posted on 10-31-2005 at 11:11:02 PM
http://forum.crystalxp.net/style_images/1/folder_post_icons/icon13.gif thanx for this nice tutorial "k-net" :wink:
it's so useful ! :great:
good translation "vIcO"
n°145
Profil: Admin
Posted on 11-01-2005 at 01:49:23 PM
Welcome bakayoko  :great:
n°168
James 004
Posted on 11-18-2005 at 10:44:59 AM
yo!very nice i so envy u!
 :smile:
n°170
vIcO
Posted on 11-18-2005 at 07:04:02 PM
Sorry, I don't have many time to translate the tutorial end, if anybody wants, you can!  :smile:
n°180
k-net
Posted on 12-17-2005 at 12:51:11 PM
Thanks for that great translation vIcO :great: :jap:
PS: "[TUTORIAL] Make a trousers for you Tux G2"
I don't think the a is really useful :wink:
n°207
CoF
Posted on 01-16-2006 at 03:53:29 AM
Hmmm...nice :smile:
n°208
Didas
Profil: God of Penguins
Posted on 01-16-2006 at 03:54:39 AM
xelcome to CrystalXP, CoF :meuh:
n°238
r4zR
Posted on 02-05-2006 at 08:57:53 PM
Awesome tutorial, thanks!  :cool:
n°239
Linon
Posted on 02-05-2006 at 09:14:43 PM
CoF wrote :
Hmmm...nice :smile:
 CoF  of graphique-design? It's you?
Good tutorial vIcO :wink:
n°269
Draginol
Posted on 03-21-2006 at 10:25:46 AM
Fantastic tutorial!
Keep up the great work!
n°309
coolguy
Posted on 05-18-2006 at 09:14:53 PM
thanxs 4 the tutorial ...really amazing.....i also think if i could be sum how gud like u guys...posting tutorials ..but still i am beginner not knowing anything..i.e basic...so itwould be hard not imposssible to strive 4 success from the path of basic to advance....but wouldtry ma level best to try ur tutorials n hav success on them n post ma tutorials so as to share knowledge with u all guys....
Just know ma exams r on the corner so would not try to do any tutorials..but wen i hav free time i would try it..n if i get any problem...hope u guys help me.....
thanxs
n°312
Franatix
http://franatix.free.fr/
Posted on 05-21-2006 at 03:52:35 PM
Greats vIc0 for the transcription :great:
n°313
k-net
Posted on 05-21-2006 at 05:29:33 PM
One says translation :wink:
n°374
Miso
Posted on 06-28-2006 at 04:15:22 PM
Thanks for the tut - very helpful!
Here's my tux with trousers:
http://img.photobucket.com/albums/v337/XMisoX/Tux/tux-g2-huh.png
n°387
alyxxs
Posted on 07-05-2006 at 09:07:41 AM
this is what i've got:
http://i14.photobucket.com/albums/a348/alyxxs/tuxvestitocopy.png
thanks for this tutorial :lol:
n°926
Cabo1994
Posted on 02-01-2007 at 02:15:25 AM
Oh, Thanks for the Tutorial, but you can give me The T-Shirt's model, because I have it but I Can't Transform the t-shirt
Sorry foy my English
n°927
Draginol
Posted on 02-01-2007 at 03:39:53 AM
Welcome here, what exactly do you mean, it's a little hard to understand :party:
n°928
Cabo1994
Posted on 02-01-2007 at 05:52:26 PM
Sorry, I want the model (T-Shirt Or Shirt ) of the vest of the tux g2, Do you understand me now?
Sorry, I know speak english, but a little :mdr:  :neutral:
n°929
-Shift-
Posted on 02-01-2007 at 08:22:39 PM
what you want is the *.psd file for the shirt of your Tux. which is found in another tutorial :jap:
lo que tu quieres es el *.psd para la camisa, que se encuentra en otro tuto en esta pagina :jap:
n°930
Cabo1994
Posted on 02-01-2007 at 08:50:54 PM
Ok, but the psd. File For shirt (Or T-shirt) of the tux G2?
Si, ¿pero el psd. para la camisa(O camiseta) para el tux G2?
n°931
-Shift-
Posted on 02-01-2007 at 09:19:36 PM
you'll find it here
lo encontraras aqui
:great:
n°932
Cabo1994
Posted on 02-01-2007 at 09:40:13 PM
Ok, But I want It for my Tux G2
si pero yo quiero esa (Camisa) para el tux G2
PD: Thanks for the fast answers :mdr:  :mdr:
      gracias por las respuestas rapidas :mdr:  :mdr:
EDIT:I Found It, Thanks for the tutorial, and the answers
        Lo encontre!, gracias por el tutorial y las repuestas
To see my result, go to graphic release
Para ver mi resultado, ve a exposicion grafica
 :biggrin:  :biggrin:
n°965
kirth
Posted on 02-25-2007 at 04:55:42 PM
Realy nice tutorial!
But some of your images don't show up (broken links / images deleted / ect..)
n°966
Posted on 02-25-2007 at 04:57:53 PM
Welcome to CrystalXP Kirth. All images seem to work at me.  :neutral: It does take some time to load them though. Also, try to close any P2P software like Kazaa, Limewire etc. If that doesn't work, try to hit F5 and Ctrl + R.  :great:
 Page :  1  2  3
Previous
Top
