Windows Customization & Support : sambbk and 24 unknown users
Previous
[Photoshop tutorial] Make a Vista like graphic/picture
n°1705
Dansa
Posted on 09-23-2007 at 09:14:29 AM
Hey!
Hope this tutorial helps you in the way you wanted it too.
The result can be like this:
http://img388.imageshack.us/img388/3212/finalhz2.png
Section 1
1.First of all make a new file with the size of 500px by 300px.
2.Now make a rectangle using the Rectangle Tool to the size of the canvas (500px br 300px). If its not perfectly the right size then use the Move Tool to make it the canvas size.
3.Right click the Layer that the rectangle is on and click Blending Options. Now do these settings:
http://img368.imageshack.us/img368/640/30328096qb3.png
4.When you've done that is should look like this:
http://img368.imageshack.us/img368/2030/75171265qd4.png
5.Now, make a line using the line tool (see picture below for detail) and add an outer glow with the colour #00ff12.
When you have done that, it should look like this:
http://img520.imageshack.us/img520/4392/27788434tx1.png
6.Now make a new layer and using the Polygonal Tool do this (along the red line):
http://img368.imageshack.us/img368/7342/78735905ne6.png
7.When you have that, make a #00ff12 to transparent linear gradient using the Gradient Tool (from a to b):
http://img216.imageshack.us/img216/9193/62802242mb5.png
8.And when you've done that change the opacity to 30% and it should look like this:
http://img216.imageshack.us/img216/4816/89872224ig3.png
If you've got that, pat yourself on the back because you've done section 1!
Section 2
Now we've done that we have to do it again (yes i can hear you sighing!;)
1. Make a line using the Line Tool (see the picture below) and put an outer glow with the colour #00ff12. (You can modify it to the glow you want). It should look like this:
http://img368.imageshack.us/img368/8666/61994595aj7.png
2. Use the Polygonal Tool like you did in section 1 no.6.  On a new layer but along the line of the new line you made! (If you dont understand then just ask and ill explain in PM). When you've done that dont deselect, Just add a #00ff12 to transparent linear gradient using the Gradient Tool. If you followed corectly, it will look like this:
http://img216.imageshack.us/img216/874/50339042ke2.png
Section 2 is over! Take a break if ya wont too. If not then carry on!
Section 3
1. Make a line using the Line Tool (see the picture below) and put an outer glow with the colour #00aeff. (You can modify it to the glow you want).
http://img388.imageshack.us/img388/38/55637085dh8.png
2. Use the Polygonal Tool on a new layer but along the line of the new line you made! (If you dont understand then just ask and ill explain in PM). When you've done that dont deselect, Just add a #00aeff to transparent linear gradient using the Gradient Tool. If you followed corectly, it will look like this:
http://img181.imageshack.us/img181/7412/10xg8.png
Thats the end of section 3! I think you should be getting the hang of it by now. So it should be easier to follow, anyhow, last section now!
Section 4
1. Make a line using the Line Tool (see the picture below) and put an outer glow with the colour #9af795. (You can modify it to the glow you want).
http://img181.imageshack.us/img181/9687/11yu5.png
Yey! You've done it!!!
Feel free to post your ones!!!
Cya!
P.S If this tutorial has any problems at-all then just tell me.
n°1706
Posted on 09-23-2007 at 10:54:47 AM
Thank you for the tutorial, and so hopefully helping other members of the community. :smile: I think you should expand your tutorial to meet certain (unwritten) quality rules though. Especially step 8 can be more detailed, also, it's never wrong to give a final example at the end of a tutorial. :wink:
If you want to contact me, you can add me to Yahoo! or MSN. :angel:
Idea: perhaps we should clear up the tutorial section to maintain a good quality. Tell me what you all think.
n°1707
Draginol
Posted on 09-23-2007 at 11:10:44 AM
Agreed Gruzz, this tutorial does need to be improved a little.  Please fix it up and expand on a few steps.  I would also recommend showing a final result :smile:
n°1708
Dansa
Posted on 09-23-2007 at 11:37:13 AM
Sorry :frown:. I edited some parts of it. Can you understand it better now?
and the 'Idea: perhaps we should clear up the tutorial section to maintain a good quality. Tell me what you all think.'
Does that mean you'd delete the ones that arn't good, like mine?
n°1709
Posted on 09-23-2007 at 12:00:30 PM
I don't say I think your tutorial isn't good, it's just not complete. You don't really explain how someone is able to get this: http://img398.imageshack.us/img398/5914/finalsa5.png.
So I think you should add some extra steps after step 7. :smile:
For the clearing: Yes, this would mean some tutorials would get removed.
n°1710
Dansa
Posted on 09-23-2007 at 12:06:50 PM
Ok i understand, I'll completely change it :wink:
Edit: Ok done...
n°1711
Posted on 09-23-2007 at 02:09:58 PM
I think it's much better now, good job! :loveit:
n°1712
Dansa
Posted on 09-23-2007 at 03:50:14 PM
Thanks,  :boulay: .
n°1741
Aimee
Posted on 10-12-2007 at 05:31:46 PM
I was looking all day yesterday for a tut for this. Thank you for making it. I am going to try this later tonight :happy2:
n°1742
Posted on 10-12-2007 at 05:40:43 PM
It's very nice to hear that you like the tutorial :smile: we are waiting for your results Aimee :jap:
n°1753
Kameroon
Posted on 10-16-2007 at 10:22:35 AM
Looks Like an interesting effect.
n°1756
onadb_02
Posted on 10-20-2007 at 03:01:17 AM
Thanks for the tutorial... can you please help me to understand the use of different effects and how to use layers... i am new in photoshop... thanks for your help. I know how to use other software like Macromedia fireworks so please help me to understand Adobe photoshop. Thanks...
n°1757
Posted on 10-20-2007 at 11:00:46 AM
Welcome to CrXP onadb_02 :smile:
You can learn PS easily from the very beginning , the web is full of PS tutorials , Good-Tutorials offers a separate section for tutorials regarding Basics techniques , Click here to browse through it :wink:
Have a nice stay :party:
n°1758
GuniibOy
Posted on 10-23-2007 at 05:01:33 PM
Nice tutorial!
Wich programme do you you to make this?
Greetz!
n°1761
Dansa
Posted on 10-24-2007 at 11:46:51 AM
GuniibOy wrote :
Nice tutorial!
Greetz!
Photoshop CS2  :great:
n°1791
SoNKkK
Posted on 11-03-2007 at 10:45:55 AM
Could you post a tutorial wich you explain how to do this, please? (Sorry for the English, i'm Italian :°D )
n°1792
Posted on 11-03-2007 at 03:10:51 PM
Basicly it's the same as this tutorial, but here you are using straight lines, while at the image you want to make has curved lines. :biggrin: If you don't understand it, please ask us a question. :smile:
n°1830
.drago.
I am ALIVE!
Profil: Top Penguin
Posted on 11-19-2007 at 05:17:15 PM
wow nice pics and nice tutorial thx sooooooo much its very usefull
n°1876
TheVestel
PHP Programmer
Posted on 12-10-2007 at 01:54:09 PM
Nice tutorial! Thank you :wink:
n°1886
Phrozen
Posted on 12-16-2007 at 07:16:58 PM
Nice tutorial, took me 5 min to do it, and makes a great effect. Keep it up,  here's my final image (really close I think)  :boulay:
n°1887
Posted on 12-16-2007 at 07:25:10 PM
Yes it is indeed very close. :biggrin: Now try to make your own variations! :wink:
n°1946
.drago.
I am ALIVE!
Profil: Top Penguin
Posted on 01-17-2008 at 09:19:21 PM
thx for the idea and i didn't see the realy i just made when i saw the idea
and i always have my own design and here is my pic.
http://img249.imageshack.us/img249/6628/dragologovistalightsds3.png
n°2388
KhainDesign
Posted on 06-08-2008 at 11:21:03 PM
Cool tuto!
It must be easy... i'll try it now, and i'll post my results :smile:
P.s.
Drago: How did u make the effects of your logo and singature?
Sorry for the off :smile:
n°2389
KhainDesign
Posted on 06-09-2008 at 12:10:45 AM
http://mmoaddict.extra.hu/vista_look_bg.png
I've made this in a few minutes :smile:
I hope you'll like it :smile:
n°2390
cradłe
Cradle-desktop@ubuntu:~$ whatis windows
Posted on 06-09-2008 at 12:24:38 AM
I like it :tongue:
Previous
Top
