| ElipHant Profil: New Penguin | Last message on previous page: Awesome tutorial, this is my first time trying to make the tux but its about the 100th go at using photoshop so i was already pretty good so here you go:
currently in editing can't show yet will repost when its finished
im really proud of it but it took about 2 hours to make so that was a bit annoying but i think it was well worth the boredom  Message edited by ElipHant on 08-06-2009 at 08:24:03 PM
uttaresh The Penguin Master Profil: Penguin Pro | Very nice outcome, ElipHant. But what is that black thing coming out from above the left foot? ---------------
One forum at a time.
if you mean outside the body and it looks like a slight smudge or something im not sure its probably just some shadow left over from the feet or something but if its not that then im not sure what your seeing sorry.. | |
uttaresh The Penguin Master Profil: Penguin Pro | Yes, that's what I mean. You should always check your work before submitting ... and now that I've mentioned it, you should correct it before anyone else sees it.  ---------------
yea i'll edit it now and hopefully have it back on here in a few hours (i've got other stuff to do aswell) | |
anjali Profil: New Penguin | Hello, i am new here and its my 1st try to make Tux. I couldnt make wing refletions... i think that its not so bad try
 Message edited by anjali on 08-18-2009 at 11:26:00 AM
uttaresh The Penguin Master Profil: Penguin Pro | | |
Gruzz Profil: Moderator | Welcome to CrystalXP anjali! Very nice first result. Keep on going like this!  | |
custotux Profil: New Penguin | thanks it really helped me a lot !!!!!! [#ff3800] | |
philipaliscious Profil: New Penguin | WHAT!? SO you need photoshop?! | |
HandyBob Profil: New Penguin |
Nope.
Here's one I did in Paint.Net
I posted the tutorial on Instructables (spreading the knowledge and all)
But I do think photoshop or The Gimp would get a better result. | |
Gruzz Profil: Moderator | Nice work HandyBob. I am impressed with your Paint.Net work. Of course there's room for improvement, but overall look is good.  | |
