| headbuster Profil: Penguin | Last message on previous page:
soonerdude13 Nice Tux! But I advice you to make the background gradient(blue and dark blue for example) or like Gruzz said transparent!  | |
soonerdude13 Profil: New Penguin | not sure what happened..... it was on a transparent background until i changed it to a jpeg and posted it here, the background became black. It is not black on my computer! But i agree that black is not the best background color. | |
Gruzz Profil: Moderator | For something to be transparent, you will probably have to save it as a .png file. .jpeg/.jpg doesn't recognize transparency and auto converts it to black or white (usually white).  | |
ghostnatyphon To die would be a great adventure. Profil: Penguin Pro | Well I followed the tutorial and made the Tux, and I'm pretty happy because I got nearly all of it. Bit that I didn't get was making the inner shadow for the feet with the black fill and then using the gaussian blur. All I got was a grey circle that was black in the middle, but it didn't got to transpaent and wasn't smooth. So instead I just used a black to transparent gradient and messed sround with that till I got the result I was after ^^ I changed the colours a bit, and I'm going to have to add some accessories soon!  Hows it looking? | |
headbuster Profil: Penguin | Maan nicee! I have to make the g2 soon!  | |
ghostnatyphon To die would be a great adventure. Profil: Penguin Pro | Thanks Gruzz for the psd, hopefully that might help. I did change the opacity though, I tried it at different opacities, layer modes, and I redid it a few times, but all I got was the black fading to grey, and then it stopped at this grayish colour that was really sharp against the white. I'll have a look at the psd, cheers  | |
Zohan Profil: New Penguin | This tutorial is awesome!!! Thx! Here's my try: It's from the new movie "Don't Mess With The Zohan".  best regards Simeon | |
Asher Genius is not born , it is made.... Profil: Moderator | Welcome to CrXP Zohan  You have come up with a very promising result I really like the hair-work  Have a good stay  | |
Zohan Profil: New Penguin | Gruzz wrote :
You saved your Tux with a white background, a white background would have looked better.
I assume you mean transparent bg. I edited that. Gruzz wrote :
One question, why did you put the text 'head admin' in your avatar?
This was just a joke. I also use this avatar in another Forum. In the other, they use this graphic for their overall Admins. Thought this is funny.
headbuster Profil: Penguin | Nice result! I really like the hair
 --- btw is the film good?
iraqia Profil: New Penguin | It's so nice wonderful tutorial thanx | |
Asher Genius is not born , it is made.... Profil: Moderator | Welcome to CrXP Ryosh if you have followed the tutorial and you have a result then don't be shy to show it  | |
soonerdude13 Profil: New Penguin | Got a quick question. I made a tux that i submitted and it has been waiting for validation since july 26. Anyone know whats up with this? | |
Gruzz Profil: Moderator | soonerdude13, are you talking about your Canadian Tux? I just checked and it is still waiting for validation. I am sorry that it takes such a long time to validate submissions sometimes. | |
acepilot_not Profil: New Penguin | I am kinda new at creating the G2 tux, so thaanks for the tutorial!:great:
Gruzz Profil: Moderator | Welcome to CrystalXP acepilot_not. You got any result of this tutorial to show us?  | |
Frozzn Profil: New Penguin | Very cool, I go to try this ^^ | |
ValHolla Profil: New Penguin | I followed the "http://forum.crystalxp.net/index.php?showtopic=6606&hl=gimp+tutorial" "translate.google.com" Rocks attached is my xcf Feel Free to use it as you wish. ValHolla G2_Tux.xcf | |
CycloneZ Profil: New Penguin | Hello, im CycloneZ and i need help xD.
For some reason when im following the selection steps i can't get them.
The step is, make a new layer then ctrl-click the other one which is alike and i do it.
Then t says fill in your new selection.
How do i make the new selection? Can someone help me please xD | |
Hi, im still a bit confused xD
I did what you told me but nothing happen. Only that after i few times i push Shift + Backspace the layers get deleted. xD
What is suppose to happen? Is the shape suppose to get selected which it is but it doesnt on my photoshop xD.
EDIT: never mind i got it now for sure. Thanks for your help XD Message edited by CycloneZ on 11-09-2008 at 04:07:38 PM ---------------
butaq Profil: New Penguin | i just dont understand it.... | |
maquire202 I never think of the future. It comes soon enough. Profil: Penguin | | |
