| darklady Just remember, art saves lives. Profil: Big Penguin | Last message on previous page: Just resize the image. Edit > Image size. Though sometimes this will leave aliasing that you will need to clean up manually. Also, I like your tuxes, but you have the shadow at the bottom cut off a bit. | |
~Andy Profil: New Penguin | Cool the second one! I like it. To enlarge you tux you can try to create a new document (for ex 800x800). Then open your .PSD tux file, press CTRL+A, edit==>Copy Merged and paste on the document. Now CTRL+T and resize it. I'm not sure about the quality of the result but it can works  lol this is easiest than mine
pc_for_me Profil: New Penguin | Than the quality is not the same. | |
earnur Profil: Penguin | If you enlarge your tux you will always lose the quality. The best choice it would be make vectored tux  | |
earnur Profil: Penguin | HEY!! For those who want to make bigger tux I made vector tux model  I hope you like it  If k_millio wants, he can add my file to his first topic  Here is my big tux
pc_for_me Profil: New Penguin | I downloaded the vector Tux, but how can I make it bigger? | |
earnur Profil: Penguin | I couldn't find it so I made by my own  | |
pc_for_me Profil: New Penguin | If found how to make it bigger: Look at the result(I made some extra special effects ) | |
earnur Profil: Penguin | Nice outcome freakkie  | |
pc_for_me Profil: New Penguin | Thanks, It was quite easy. Is it possible to make a tutorial about it? | |
pc_for_me Profil: New Penguin | Thanks, I will do that  | |
pc_for_me Profil: New Penguin | Can you give me the exact place where I can find it?  | |
earnur Profil: Penguin | Here you have Wallpaper Box Topic link  | |
pc_for_me Profil: New Penguin | Thanks. Take a look, it's right there | |
simoes03 Profil: New Penguin | | |
Gruzz Profil: Moderator | Nice result, but not of the correct tutorial. You placed your result in the wrong thread.  | |
headbuster Profil: Penguin | Hello guys, First of all nice tut I tried to make it but....no result It is pretty difficult for me...tried 100 times....read carefully the tut but...still Is there a ready .psd because I want to see ho you do it because obviously I can't make it! Thanks in advanced | |
earnur Profil: Penguin | headbuster you can show us screenshots where you stack and we will try to help you. That's better way to learn something than copy it from ready job  | |
headbuster Profil: Penguin | First: CODE2.Create a new layer called "White stain" and Ctrl+Click on the model's stain thumbnail Ctrl+Click on the model's stain thumbnail whre is this? | |
earnur Profil: Penguin | Thumbnail is here:
 If you download psd model of tux you must find in Model group layer called "White stain" and Ctr+Click (just press Ctr and click your left mouse button) on thumbnail  BTW I'm leaving on holidays for two weeks to place without any Internet So, I will miss you and hope to see a lot of your good work when I back
Gruzz Profil: Moderator | Have a nice holiday earnur! headbuster, Ctrl + left clicking on a layers thumbnail will make a selection of the objects in that layer.  | |
soonerdude13 Profil: New Penguin | here is my attempt at the tux. This tutorial rocks | |
headbuster Profil: Penguin | soonerdude13 Nice Tux! But I advice you to make the background gradient(blue and dark blue for example) or like Gruzz said transparent!
