25 unknown users
 Page :  1  2  3  4  5  6  7  8  9  10  11  12  13  14  15  16  17
Previous
[Photoshop tutorial] Make a G2 Tux
n°85
k_millio
Profil: Modo
Posted on 08-21-2005 at 10:45:44 PM
As this tux is more complex than the first one, Overlord thought it would be better to give a PSD model with every shapes created.
So here's the model : Download the model
In this PSD, you can see two layer-groups, the top one is the group which will contain all the layers you will make by following this tutorial. The second one contains the models of every part of the tux.
Let's start with this long, very long, tutorial :great:
1. Click on the "Final tux" layer group, and create a new layer called "Body". Ctrl+Click on the thumbnail of themodel's "Body" layer to have its shape as a selection. Then fill your selection (on the final body layer) with black.
2. Create a new layer called "White stain" and Ctrl+Click on the model's stain thumbnail.
Put these colors:
Foregroud: R:208 j'ai:208 B:208 (or #D0D0D0)
Background: R:171 j'ai:171 B:171 (or #ABABAB)
Select the "Gradient tool", choose the "Foreground to background" gradient in a linear mode, and draw a gradient from the top of the selection to its bottom.
3. Create a new layer and name it "Left wing". Ctrl+Click on the model's one and fill your new selection with black. Repeat this step for the Right wing.
4. Create a new layer called "Left eye". Set these colors :
Foreground: R:230 j'ai:230 B:230 (or #E6E6E6)
Background: R:201 j'ai:201 B:201 (or #C9C9C9)
Use the gradient tool with the same setting as on step 2, and draw a gradient from the top of the selection to its bottom
5. Double-click on the layer's thumbnail,and then click on inner glow. There you can see a little square filled with light-yellow, double click on it and choose this color : R:141 j'ai:141 B:141 (or #8D8D8D). As for the blending mode, choose Multiply, and finally put the size on 16 pixels.
6. Repeat steps 4 and 5 for the right eye.
You should now see this :
http://overlord59.crystalxp.net/img/TG2-1.jpg
7. Click on the "Left eye" layer and create a new layer called "Left pupil". Ctrl+click on the model's left pupil layer, and fill your selection with black.
Repeat this step for the right pupil but click on the "Right eye" layer.
8. Create a new layer called "Left foot". Set these colors:
Foreground: R:224 j'ai:205 B:0 (or #E0CD00)
Background: R:223 j'ai:186 B:0 (or #DFBA00)
Draw a radial gradient from A to B like on the image :
http://overlord59.crystalxp.net/img/TG2-2.jpg
9. Double-click on the layer's thumbnail to open the layer style windows, then click on the Inner glow label, and doubleclick on the color square. Enter these settings :
R:235 j'ai:192 B:0 (or #EBC000).
Choose multiply as the blending mode, and put the size to 13 pixels.
Repeat steps 8 and 9 to make the right foot.
10. Create a new layer called "Beak". Ctrl+click on the model's beak. Then, set these colors :
Foreground: R:238 j'ai:227 B:0 (or #EEE300)
Background: R:234 j'ai:195 B:0 (or #EAC300)
Now, select the "Gradient tool" and choose a linear gradient. Then make one from A to B as shown below :
http://overlord59.crystalxp.net/img/TG2-3.jpg
Now you should obtain this :
http://overlord59.crystalxp.net/img/TG2-4.jpg
Now, we are only going to work in the "Final tux" group so you can collapse the "Model" one. (but don't delete it, we will need it for the eyelids :wink: )
11. Click on the "Body layer and create a new layer called "Body reflect 1". Use the elliptical marquee tool to make a selection like on the image :
http://overlord59.crystalxp.net/img/TG2-5.jpg
12. Set white as your foreground color and select the gradient tool. Choose the "foreground to transparent" gradient (be sure the linear mode is selected). Draw a gradient from the top of the selection to its bottom.
13. Ctrl+click on the "Body" layer, then go to Select > Modify > Contract, and enter 2 in the dialog box. Create a new layer called "Body reflect 2".
Use the gradient tool to make a gradient from A to B :
http://overlord59.crystalxp.net/img/TG2-6.jpg
14. Use the elliptical marquee tool to select a shape like this one :
http://overlord59.crystalxp.net/img/TG2-7.jpg
Then hit delete and reduce the layer's opacity to 79%
15. Click on the "Left eye" layer and create a new layer named "Left eye reflect 1". Ctrl+click on the "Left eye layer", then go to Select > Modify > Contract, and enter 2 pixels in the dialog box.
16. Use the gradient tool to draw a White to transprent linear gradient from the top of the selection to its middle.
17. Use the elliptical marquee tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-8.jpg
Then press delete.
n°86
k_millio
Profil: Modo
Posted on 08-21-2005 at 10:46:02 PM
18. Create a new layer called "Left eye reflect 2". Ctrl+click on the "Left eye" layer, then go to Select > modify > contract and enter 2 in the dialog box. Use the gradient tool to draw a gradient from the bottom of the selection to its top.
19. Use the elliptical marquee tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-9.jpg
And hit delete. Then put the layer's opacity to 38%.
20. Click on the "Right eye" layer and create a new layer. Name it "Right eye reflect 1". Ctrl+click on the "Right eye" layer and contract the selection by 2 pixels.
21. Use the gradient tool to make a gradient from the top of the selection to its middle. Then use the elliptical marquee tool to select a shape like this one :
http://overlord59.crystalxp.net/img/TG2-10.jpg
Hit delete.
22. Create a new layer called "Right eye reflect 2". Ctrl+click on the "Right eye" layer and contract the selection by 2 pixels. Then use the gradient tool to draw a ... gradient from the bottom of the selection to its top.
23. Use the elliptical marquee tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-11.jpg
Now press delete and reduce the layer's opacity to 30%.
24. Click on the "Left pupil" layer and create a new layer called "Left pupil reflect 1". Then ctrl+click on the "Left pupil" layer and contract the selection by 1 pixel.
25. Now use the gradient tool to draw a gradient from A to B, as show below :
http://overlord59.crystalxp.net/img/TG2-12.jpg
26. Use the elliptical marquee tool to select a shape wich ressembles to this one :
http://overlord59.crystalxp.net/img/TG2-13.jpg
And press delete.
27. Use the polygonal lasso tool to draw a selection like on the image :
http://overlord59.crystalxp.net/img/TG2-14.jpg
Hit delete
28. Create a new layer called "Left pupil reflect 2", Ctrl+click on the "Left pupil" layer and contract the selection by 1 pixel.
29. Draw a gradient from the bottom of the selection to its top. Then use the elliptical marquee tool to draw a selection like on the image :
http://overlord59.crystalxp.net/img/TG2-15.jpg
Hit delete, and reduce the layer's opacity to 38%
30. Duplicate the "Left pupil reflect 1 and 2" layers, rename them "Right pupil reflects 1 and 2", and place them over the "Right pupil" layer and use Ctrl+T to move and resize them.
You should olbtain this :
http://overlord59.crystalxp.net/img/TG2-16.jpg
We're going to create the eyelids.
31. Click on the "Right wing" layer, and create a new layer called "Left eyelid". Ctrl+click on the model's left eyelid and fill your selection with black. Repeat this step for the right eyelid.
32. Click on the "Left eyelid" layer, Ctrl+click on it, go to Select > Modify > contract and enter 2 pixels in the dialog box. Then create a new layer called "Left eyelid reflect".
Now draw a gradient from A to B in this selection :
http://overlord59.crystalxp.net/img/TG2-17.jpg
33. Use the elliptical marquee tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-18.jpg
34. Then hit delete, go to Filter > blur > Gaussian blur, and enter 0.7 pixels in the dialog box. Now reduce the layer's opacity to 73%
35. Click on the "Right eyelid" layer, ctrl+click on it, contract the selection by 2 pixels, and create a new layer called "Right eyelid reflect".
Now draw a gradient from A to B, as shown below :
http://overlord59.crystalxp.net/img/TG2-19.jpg
36. Use the elliptical marquee tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-20.jpg
37. Hit delete, deselect and press Ctrl+F (it will reapply the last filter you used with the same settings), and reduce the layer's opacity to 73 %
Tip: pressing Ctrl+Alt+F will open the settings window of the last effect you used (or it will apply the filter if it cannot be set up)
38. Double-clickon the "Beak" layer and click on the inner glow label. Choose this color : R:235 j'ai:192 B:0 (or #ECB000).
As for the blending mode, choose multiply and set the size to 13 pixels.
39. Be sure you're working on the "Beak" layer and create a new layer. Call it "Beak reflect 1". Ctrl+Click on the "Beak" layer and contract the selection by 2 pixels. Then draw a white to transparent gradient from A to B in the selection :
http://overlord59.crystalxp.net/img/TG2-21.jpg
n°87
k_millio
Profil: Modo
Posted on 08-21-2005 at 10:46:20 PM
40. Use the elliptical marquee tool to draw a selection like on the image :
http://overlord59.crystalxp.net/img/TG2-22.jpg
Hit delete.
41. Now create a new layer named "Beak reflect 2". Use a Ctrl-Click on the "Beak" layer and contract the selection by 2 pixels. Now draw a gradient from A to B :
http://overlord59.crystalxp.net/img/TG2-23.jpg
42. Ctrl-Click on the "Beak" layer then go to Select > Transform selection to move the selection so that it is at the same place as on the image.
http://overlord59.crystalxp.net/img/TG2-24.jpg
Now, hit delete.
43. Click on the "White stain" layer and cretae a new layer called "White stain reflect 1". Then use the elliptical marquee tool to draw a selection like on the image :
http://overlord59.crystalxp.net/img/TG2-25.jpg
44. Draw a white to transparent gradient from A to B :
http://overlord59.crystalxp.net/img/TG2-26.jpg
Now, Ctrl+Click on the white stain layer, press Ctrl+shift+i and then delete.
45. Create a new layer called "White stain reflect 2", Ctrl+click on the "White stain" layer and contract the selection by 2 pixels.
Then draw a gradient from A to B :
http://overlord59.crystalxp.net/img/TG2-27.jpg
Now reduce the layer's opacity to 40%.
46. Click on the "Left foot" layer and create a new layer called "Left foot reflect". Then use the elliptical marquee tool to make a selection like on this image :
http://overlord59.crystalxp.net/img/TG2-28.jpg
47. Draw a gradient from the top of the selection to its bottom. Now deselect and duplicate the layer, rename it "Right foot reflect", and place it over the "Right foot" layer. Now move the reflect so that you obtain something like that :
http://overlord59.crystalxp.net/img/TG2-29.jpg
48. Click on the "Left wing" layer and create a new layer called "Left wing reflect 1". Ctrl+click on the "Left wing" layer and contract the selection by 2 pixels. Now draw a gradient from A to B :
http://overlord59.crystalxp.net/img/TG2-30.jpg
49. Ctrl+click on the left wing layer, then go to Select > Transform selection and move the selction so that it is on th same position as on the image :
http://overlord59.crystalxp.net/img/TG2-31.jpg
Now hit delete and reduce the layer's opacity to 76%
50. Dupliacate the "Left wing reflect 1" layer and place over the "Right wing" layer. Reaname it "Right wing reflect 1", then Ctrl+A and go to Edit > Transform > Flip horizontal, and if the reflect isn't on the same position as on the left wing, move it so that it is.
51. Click on the "Left wing reflect 1" and create a new layer named "Left wing reflect 2". Now Ctrl+Click on the "Left wing" layer, contract the selection by 1 pixel, fill the selection with white.
52. Now, contract the selction by 2 pixels, and press delete.
53. Use the polygonal lasso tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-32.jpg
Then press delete.
54. Ctrl+Click on the "Body" layer and press delete, then reduce the layer's opacity to 47%.
55. Duplicate the "Left wing reflect 2" layer and place it over the "Right wing reflect 1" layer, rename it "Right wing reflect 2". Select the canvas (Ctrl+A) then press Ctrl+T (it will reapply the last transformation you used, in this case, it will use the Flip horizontal transformation) and move the reflect so that it is on the same position as on the left wing.
We have finished making the reflects, we are now going to make the shadows to give even more relief to our tux :great:
You should see that :
http://overlord59.crystalxp.net/img/TG2-33.jpg
56. Click on the "White stain reflect 2" and create a new layer called "Left foot inner shadow". Use the ellipticall marquee tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-34.jpg
Now fill the selction with black and deselect.
57. Go to Filter > Blur > Gaussian blur, and enter 7.1 as the value.
58. Move the sahdow down, and Ctrl+Click on the "Body" layer. Press Ctrl+Shift+i and then delete. Reduce the layer's opacity to 70%.
You should now see that :
http://overlord59.crystalxp.net/img/TG2-35.jpg
59. Duplicate the layer and rename it "Right foot inner shadow". Then press Ctrl+A and Ctrl+T. Move the shadow so that you obtain some thing that ressembles to that :
http://overlord59.crystalxp.net/img/TG2-36.jpg
n°88
k_millio
Profil: Modo
Posted on 08-21-2005 at 10:46:36 PM
60. Click on the "Right foot reflect" and create a new layer called "Left foot shadow". Ctrl+click on the "Left foot" layer and go to Select > Modify > Expand and enter 5 pixels in the dialog box. Now fill the selection with black.
61. Use the elliptical marquee tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-37.jpg
Hit delete and then, deselect.
62. Press Ctrl+Alt+F (to open the gaussian blur settings window) and set the radius on 7.1 pixels.
63. trl+Click on the "Left foot" layer and press Ctrl+Shift+i, then hit delete. Deselect and reduce the layer's opacity to 29%.
64. Duplicate the "Left foot shadow" layer, rename it "Right foot shadow", select the canvas, and press Ctrl+T, then move the shadow so that it is on the same position as on the left foot.
65. Click on the "Body" layer and create a new layer called "Drop shadow" and put it under the "Body" layer.
66. Use the elliptical marquee tool to draw a selection like this one :
http://overlord59.crystalxp.net/img/TG2-38.jpg
Fill it with black, and deselect.
67. Press Ctrl+Alt+F and set the Gaussian blur's radius on 5.8 pixels. Then set the layer's opacity on 50%.
68. Click on the "White stain reflect 1" layer and create a new layer called "Beak shadow", then use the polygonal lasso tool to select a shape like this one :
http://overlord59.crystalxp.net/img/TG2-39.jpg
69. Set black as your foreground color, and use a "Foreground to transparent" linear gradient to draw a gradient from the top of the selection to its bottom. Deselct and press Ctrl+Alt+F and set the radius on 3.6 pixels.
70. Here's the last step, double click on the "Left eye" layer and click on drop shadow in the layer styles window. Put these settings :
Color: black
Blending mode: Multiply
Angle: 90°
Opacity: 63%
Distance: 4 pixels
Repeat this step for the "Right eye" layer.
If you followed this tutorial correctly, you should obtain this :
http://overlord59.crystalxp.net/img/TG2-40.jpg
Not bad eh ?
PS: and thanks to didas who helped me correct some mistakes :jap:
PPS: and thanks to overlord for his awsome tutrial :great:
n°89
Didas
Profil: God of Penguins
Posted on 08-21-2005 at 11:19:25 PM
you've made an incredible work :xeyes:
great translation, K-millio, one more time :great: :jap:
n°90
k_millio
Profil: Modo
Posted on 08-21-2005 at 11:55:55 PM
Thanks Didas :jap:
n°91
Profil: Admin
Posted on 08-22-2005 at 08:05:04 AM
+1  :jap:
n°92
Lémurien
Posted on 08-22-2005 at 09:54:48 PM
An incredible tutorial and a great translation k_milio :great:
However, I note a mistake at the step 55:
I think it should be Maj+Ctrl+T :wink:
I didn't note other mistakes :great:
I precise, I made this tuto whereas i'm french :he: because I didn't find the French tuto when I made it :tongue:
But I nevertheless succed to do this G2 Tux, I show you:
http://jvlimours.free.fr/Tux/G2-tux-model-base-Perso.png
PS: Excuse my English :wink:
n°93
k_millio
Profil: Modo
Posted on 08-22-2005 at 10:34:34 PM
Thanks Lémurien, but I don't think that this is a mistake, because on the version I'm using (currently CS2) you only have to press Ctrl+T and not Ctrl+Maj+T.
PS: and thank you to dlb :jap:
PPS: the french tutorial is HERE :wink:
n°96
Sophal
Posted on 09-06-2005 at 09:17:02 AM
thanx for your hardwork....
it's very useful for me...
n°98
voureleven
Posted on 09-16-2005 at 03:06:25 PM
hey....GREAT. I'll try :smile:
n°99
Didas
Posted on 09-16-2005 at 03:10:33 PM
Welcome voureleven :great:
I hope to see your Tux G2 here :wink:
n°100
vaksa
Profil: Top Penguin
Posted on 09-20-2005 at 06:58:56 PM
Really great work k_millio!!! :great: :great: :great: Thanks for this :smile:
n°104
abuaziz
Posted on 09-26-2005 at 04:53:21 PM
cool  i love it
n°105
k_millio
Profil: Modo
Posted on 09-26-2005 at 05:19:40 PM
Thanks :mdr:
n°106
s1mon
Posted on 09-28-2005 at 10:19:20 PM
Yay! After many trials and failures I've made it!
What do you think?
n°107
k_millio
Profil: Modo
Posted on 09-28-2005 at 10:40:54 PM
I think that you've forgotten step 33 and 34 for the left eyelid :wink:
Anyway, that's good :great:
n°108
s1mon
Posted on 09-29-2005 at 10:09:11 AM
I had problems with that part - thats the best i could do  :frown:
Do you have a tutorial on making shirts for the G2 tux?
n°115
Squ1rr3l
Posted on 10-16-2005 at 04:08:44 PM
I don't see the pictures on this tutorial  :ouch:  :frown:
n°117
k_millio
Profil: Modo
Posted on 10-16-2005 at 04:22:13 PM
DNS problems ...
As we've changed our server last week, some problems like this one occurred.
To see the images go to your Windows repertory then System32\Drivers\ect and edit your hosts file (with notepad) and enter the folowing line :
213.251.138.20  overlord59.crystalxp.net
Then restart your browser, and you'll normally see the images :wink:
n°119
Squ1rr3l
Posted on 10-16-2005 at 08:58:21 PM
k_millio wrote :
DNS problems ...
But i don't see the pictures even using the ip adres.
http://213.251.138.20/img/image.jpg
Maybe a typo in the IP adres ? :smile:
n°122
k_millio
Profil: Modo
Posted on 10-16-2005 at 10:09:49 PM
No, it is the right one.
You have to modify you hosts file to see the images, or you'll have to wait untill we've suppressed the DNS problems :jap:
n°142
Life Sea
Posted on 10-31-2005 at 02:19:19 AM
Thanx 4 Da Cooool Topic
n°153
PyroTux
Posted on 11-01-2005 at 10:39:10 PM
Awww, i wanna do that, but i hardly have the time any more... :frown:
n°154
Didas
Posted on 11-02-2005 at 01:57:51 AM
Welcome, PyroTux :jap:
should I ask you to the forum rules :ar: http://crystalxp.net/_images/v1/bt_en_rules_h.png :
your sig is much too big, 250x50px max, please :jap:
Previous
Top
