coutinho Windows Customization & Support : sambbk and 24 unknown users
Previous
[Photoshop Tutorial] Liquefied radial effect
n°1481
cellblade
Posted on 06-21-2007 at 08:47:17 AM
:meuh: this is a tutorial response for sosoe222... he wanted the steps but i wanted to create a tutorial...
this is my first one...  :whistle:
so i`m hoping that you will like it... :great:
so let`s begin
1.create a new document in photoshop with a transparent background(any resolution 800x600, 1024x768, 1280x1024, even 1600x1200)
2.fill Layer 1 with any color you choose using the paint bucket tool (i used black)
3.go to Layer 1 blending options (double click on the layer thumbnail) and use the following settings
http://i201.photobucket.com/albums/aa287/cellblade/tut1.jpg
http://i201.photobucket.com/albums/aa287/cellblade/tut2.jpg
you should come up with this:
http://i201.photobucket.com/albums/aa287/cellblade/tut3.jpg
4.create a new layer, fill it also with black and make Layer 1 invisible by clicking the eye
5.go to filter->render->clouds.
6.then go to filter->render->difference clouds(repeat this step 10x/15x with ctrl+f)
you should obtain this:
http://i201.photobucket.com/albums/aa287/cellblade/tut4.jpg
7.now go to filter->blur->radial blur and use this settings(repeat it twice ... again with ctrl+f)
http://i201.photobucket.com/albums/aa287/cellblade/tut5.jpg
http://i201.photobucket.com/albums/aa287/cellblade/tut6.jpg
8.where are getting there just one final effect to add... go to filter->sketch->chrome
what settings and what you should obtain:
http://i201.photobucket.com/albums/aa287/cellblade/tut7.jpg
9.final step... go to Layer 2 and set the blending settings to Multiply
http://i201.photobucket.com/albums/aa287/cellblade/tut9.jpg
10.make Layer 1 visible again by clicking where the eye should be...
final result:
http://i201.photobucket.com/albums/aa287/cellblade/tut8.jpg
hope you enjoyed this tutorial... and hope you like it... :meuh: :great:
n°1482
Posted on 06-21-2007 at 09:10:31 AM
The tutorial is well explained, good job. Please make up a better title for the tutorial though. "Liquid something" won't do.
n°1484
Nagaya
Posted on 06-21-2007 at 09:31:36 AM
Good job cellblade
This tutorial is very good as your first attempt. :loveit:
n°1487
cellblade
Posted on 06-21-2007 at 12:44:57 PM
well a changed it to liqiuafied radial effect... although my English is a bit bad... so can somebody please post the correct form of the word "liqiuafied" ...
aw and do not forget to post your results...
@nagaya
thanks a lot... i hope more people will post their replies... and i sure want to see their results...
n°1488
sosoe222
Posted on 06-21-2007 at 01:17:41 PM
Glad you finally wrote a tutorial :loveit: I will later post my result! Thank you veeeeery much :loveit: :great:
n°1489
Nagaya
Posted on 06-21-2007 at 01:30:37 PM
@nagaya
Sure. here is my result + some tweaks.  :happy2:
http://i170.photobucket.com/albums/u248/nagayanobu/somethingliquidresultbynagaya.png
n°1491
sosoe222
Posted on 06-21-2007 at 01:36:09 PM
Cute :loveit: Your radial effect looks kinda better than cellblade's (no offense, cellblade). What did you do with it?
n°1493
Posted on 06-21-2007 at 01:38:24 PM
Liquefied radial effect? :wink: Liquefied is the natural gas, also known as LNG.
n°1494
Nagaya
Posted on 06-21-2007 at 01:38:49 PM
nothing particularly, it is based on cellblade tutorial and after that i added border and some gloss.
we are waiting for your result sosoe222  :whistle:
Liquefied radial effect? wink.gif Liquefied is the natural gas, also known as LNG.
hahaha...nice one Gruzz.  :meuh:
n°1496
sosoe222
Posted on 06-21-2007 at 01:50:17 PM
Ah, yes, my result. With some small tweaks, I made this :jap:
http://i18.tinypic.com/4p9hbgm.jpg
n°1498
Nagaya
Posted on 06-21-2007 at 02:04:32 PM
good one sosoe222.   :meuh:
n°1499
sosoe222
Posted on 06-21-2007 at 02:07:48 PM
Thank you very much, Nagaya :loveit: :great:
n°1500
sosoe222
Posted on 06-21-2007 at 02:13:20 PM
BTW a small correction for the tutorial.
Black isn't #FFFFFF, it's #000000 :wink:
n°1501
Posted on 06-21-2007 at 02:17:02 PM
That's right, #FFFFFF is completely white. :wink:
n°1504
cellblade
Posted on 06-21-2007 at 03:01:26 PM
ups... my mistake... i`ll get right on to it...
aw and btw... thanks Gruzz for the title... Liquefied radial effect
edit:
job done... the color code it good now...
@nagaya... very nice effect... i admit that i`m a newb in photoshop... how did you manage your creation?
@sosoe222... yours looks like mine... good job... i`m glad to see that i`m helping someone... feels gooood... :wink: :tongue:
n°1505
sosoe222
Posted on 06-21-2007 at 04:52:42 PM
Againl, thanks for the tutorial. I will try to make something new with your tutorial. Thanks again, neighbor :wink:
n°1506
Posted on 06-21-2007 at 05:18:08 PM
Very useful & helping tutorial cellblade :great: , here's my result with some changes:
http://img2.freeimagehosting.net/uploads/e3b1946c08.jpg
Keep it up  :wink:
n°1507
sosoe222
Posted on 06-21-2007 at 06:32:39 PM
Whoa!!!! Can you PLEASEEEEEEE post the steps??!!! Your image is best so far!!!
n°1508
Posted on 06-21-2007 at 06:44:53 PM
It's a combination of this tutorial and this one. :wink:
n°1509
cellblade
Posted on 06-21-2007 at 07:10:26 PM
well... i think ashar just added another radial blur after the chrome...
n°1515
Posted on 06-22-2007 at 11:09:28 PM
@ sosoe222 , the problem is that I forgot to save the PSD file  :frown: , I will try to post the steps if I get enough time .
@ Gruzz , you are absolutely right  :idea: .
@ cellblade , yes , I did add an extra radial blur after the chrome effect but believe me that's just a part of what I did as whole to achieve the result.
n°1530
cellblade
Posted on 06-25-2007 at 03:17:05 PM
nice job anyway... i would like it for you to post the steps... if you don`t mind...
aw and btw... sorry for the absence... my network adapter was blown by a storm...
n°1575
Sodaplayer
Posted on 07-08-2007 at 09:10:45 PM
Color burn also has a cool effect as the overlay.
http://img63.imageshack.us/img63/4215/liquidchromestarsa5.th.png
It looks kinda like star.
n°1576
cellblade
Posted on 07-08-2007 at 09:52:22 PM
nice one Sodaplayer... keep posting results...
n°1578
..doddles101..
Posted on 07-10-2007 at 01:15:10 AM
Here's my result :
http://img48.imageshack.us/img48/8320/wallpapershowes9.png
Looks quite good as my my background don't ya think  :happy2:
Thanks for the great tut :great:
Oh and sorry if I copied sosoe's border (I didn't even do it very well :tongue: , so I guess it dosn't matter  :glass:)
Previous
Top
