Windows Customization & Support : sambbk and 20 unknown users
[Photoshop Tutorial] Oil Effect for text
n°1326
Nagaya
Posted on 05-02-2007 at 02:35:45 PM
Hi All,
This is my first try as to write a tutorial. I hope this comes useful in some way. :oui:
We are going to make a text effect like this:
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/OileffectByNagaya.png
1. Open up a fresh document with any resolutions you like. (mine is 600*200). Make sure you keep the background transparent.
2. Click the text tool, and select the font "MAGIC MUSHROOM". Type in any text you like. Download the font here.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide1.jpg
3. Name it text layer.
4. Ctrl + Click on the text layer to select it.
5. Make a new layer (Ctrl + N) and fill the new selection with a nice grey color (I used #4b4b4b), name it Oil Layer.
6. Ctrl + D to deselect.
7. Go the channels tab and create new channel. It will be named Alpha 1.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide2.jpg
8. With you foreground color as white and background color as black go to filter > render > clouds.
9. Ctrl + F to repeat the same effect to clearly define the clouds.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide3.jpg
10. Still keeping yourself in the channel palette, go to Image > Adjustments > threshold.
12. Set the value like this.
*You can change the setting according to the size of the image. the whole point is the clearly demarcate the white and the black portions.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide4.jpg
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide5.jpg
11. Go back to layers palette. Select Oil layer. Go to Select > Load selection. From the drop down menu select Alpha1.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide6.jpg
12.
Now select a new foreground color that matches the greenish blue color of oil. (I choose #098f7a).
13. Go to Edit > Fill and set the setting like this. Be sure to have a check mark at Preserve transparency box.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide7.jpg
14. Ctrl + D to deselect.
15. Now again go to the channels palette and make one more new channel "ALPHA2".
16. Repeat steps 8 and 9.
17. Still keeping yourself in the channel palette, go to Image > Adjustments > threshold. Set the value as 100 (as in my case). You can set a different value as per the size of the image. See what comes out best for you.
18. Go back to Layers palette. Click on Oil layer and its time now to load your selection again. Go to Select > load selection.
19. This time load the Alpha2 from the drop down menu of channels.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide8.jpg
20. While keeping the selection active go to Image > Adjustments > Hue / Saturation. And set the following settings.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide9.jpg
21. Ctrl + D to deselect.
22. Now, we are over with the coloring part.
23. Right click on the Oil layer to go to blending options and choose the following settings.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide10.jpg
24. So now you should be having something like this.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide11.jpg
25. Go again to the blending options > Satin > and set the following.
* make sure to set the contour settings.
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide12.jpg
26. Go to image > adjustments > brightness contrast. Set brightness = +20, contrast = +50
27. Phew...are we getting tired?? :tongue:  Just a little bit more and we are done. Dont loose the GUTS as yet!
28. To add a real effect we now go to filters > artistic > plastic wrap. Accept the default settings.
29. Crtl + F to repeat the process. We have something like this. Are you near? Dont worry!
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide13.jpg
30. The final step. Go to Oil layer > right click > blending options > drop shadow
31. Now ladies and gentlemen we have a terrific (?) oil effect.
32. Be sure to post your results here. Cheers!
http://i170.photobucket.com/albums/u248/nagayanobu/oil-tut/slide14.jpg
n°1328
Posted on 05-02-2007 at 03:31:36 PM
Thank you for the tutorial. As for most tutorials, I promise to do this one in the next few days! :loveit:
A small help for you since you did this huge job for the community:
Correct spelling is "terrific". :wink:
n°1329
Nagaya
Posted on 05-02-2007 at 03:40:05 PM
Hahaha...Thanks for the spelling mistake pointer. Corrected it.
This tutorial I learned from my good friend. He is very good in Photoshop but he doesn't have time to explain things to me. Very busy man!  :cry:
n°1357
Posted on 05-17-2007 at 11:25:01 AM
I think this tutorial is underrated by the community. No-one has posted their results yet. :frown: common everyone, show Nagaya that we're thankful for the tutorial! I'm working on a new signature at the moment and I can really use this tutorial to make stamp like part! :loveit:
n°1358
simon.maildude@gmail.com
Posted on 05-17-2007 at 03:40:34 PM
Maybe instead of colors, it should be black with some kind of crystal/outline?  :neutral: :he:
n°3598
Xylar
"eaeaeaewwww FOLLOWING time!"~LAMP
Posted on 11-27-2008 at 09:33:30 PM
i'm gonna spill the damn BEANS and give my creation.(to my knowledge first one here :wink: )
HERE:http://i255.photobucket.com/albums/hh145/Projectus/Oilyxylar.png
n°4620
bpdbpd
Posted on 03-07-2011 at 05:20:56 AM
hey can you like put a download of the magic mushrooms font up or somethin bc when i try to download it to do this tutorial it says the page isnt requested..i need this effect for a centennial logo..please help soon!!
thanks!
n°4621
Tanshin
Posted on 03-07-2011 at 11:06:58 PM
I found this one: http://www.abstractfonts.com/font/6613
It's not exactly the same, but it's pretty close.
http://i15.photobucket.com/albums/a398/saladbar1/mystbar_cxp.png
n°4729
minins
Posted on 01-09-2012 at 01:57:21 PM
I'm working on a new signature at the moment .http://www.bosin.info/g.gif
n°4756
zxc1233
Posted on 02-09-2012 at 03:34:22 AM
The stu San Francisco Escort you San Francisco Escorts from seven  to three days of the attack. Parcircumstances at the time, and how they felt. To find out whether the San Francisco Asian Escort memories formed would be lasting ones, the group [url=http://sfasianescorts.com]San Francisco Asian Escorts
[/url] participants again
