23 unknown users
 Page :  1  2  3  4
[Photoshop tutorial] Make a CD icon
n°1959
darklady
Posted on 01-21-2008 at 10:37:06 PM
Ah right, I didn't notice that before...
Thanks!  That's why I like this site :biggrin:
EDIT: fixed :wink:
n°1987
vijaykurup
Posted on 02-01-2008 at 08:38:21 AM
Hi ASHAR,
Thanks a ton for this tutorial... however I unable to download PSD file which you kept it for download :frown:
~Vijya
n°1991
Posted on 02-03-2008 at 04:03:55 AM
Welcome to CrXP vijya :smile: , you can get the PSD file from here :wink: , have a nice stay :party:
:ar: Link to the PSD in the first post has been fixed :angel:
n°1992
Mornothly
Posted on 02-03-2008 at 04:44:24 PM
wow, awesome!
n°1999
truth
Profil: Top Penguin
Posted on 02-08-2008 at 11:39:49 AM
Nice Tutorial ! Thanks. :loveit:
http://img206.imageshack.us/img206/8513/cdlargeanihy7.gif
n°2135
rolff56
Posted on 03-23-2008 at 09:16:35 PM
Wow this is an excelent tutorial! Thx a lot Asher :great:
I tried it and that's the result ^^
What do you think¿?¿? :neutral:
n°2138
Posted on 03-24-2008 at 05:37:10 PM
That's really nice :oui: , just decrease the size of inner-most ring and remove the part of reflection from it :wink: your outcome will be improved :jap:
n°2638
Kurama22
Posted on 07-28-2008 at 01:09:57 AM
thanks man, that realy cool tutorial .. and very .. veery useful :smile:
heres mine
http://i191.photobucket.com/albums/z160/kurama22-kun/th_Lina_album.png
n°2639
Posted on 07-28-2008 at 08:22:28 AM
Good outcome Kurama22 :great: and welcome to CrXP :mdr:
n°2640
Posted on 07-28-2008 at 08:53:30 AM
Nice outcome Kurama22, and welcome back to CrystalXP. :wink:
n°2641
ghostnatyphon
Who Dares Wins
Posted on 07-28-2008 at 01:34:43 PM
Well for some reason I can't see step 9's outer glow property picture.
I also don't get the selection I need to make with the rectangular marquee tool, where, waht size? I can't get the rainbow right because I can't get the rectangle right  :cry:
And also how did you get the pen tool path to become the selection? I can make the path, but I can't make it the selection...
Also for some reason I am getting a lot of anti-aliasing on the ring 2 and ring 3 layers, any idea why?
EDIT:
And is there some magical way of putting a selection, or layer centered on the canvas, by chnaging the x and y values? I've looked but I can't find it anywhere, so I'm centering them by hand and eye, so I know it wont be right that way  :frown:
n°2642
Posted on 07-28-2008 at 02:14:00 PM
I haven't got much time to look into your other questions at the moment, but I know the answer to your last question. :oui: If your selection is active, go to Select -> Transform Selection and change the x and y values. :wink:
n°2643
darklady
Posted on 07-28-2008 at 04:20:47 PM
About the selection:
With the pen tool still selected, right click on the path that you made and click "make selection" or something like that.
To center a layer (or many layers) on the canvas, select the layers that you want centered and then -
Layer > Align > vertical center and horizontal center (it should say something similar)
or
Edit > Auto-Align Layers
Choose Layer > Align or Layer > Align Layers To Selection, and choose a command from the submenu. These same commands are available as Alignment buttons in the Move tool options bar.
n°2644
ghostnatyphon
Who Dares Wins
Posted on 07-28-2008 at 10:58:35 PM
When I do that it just gives me two circles, as in it chose the space that would be filled for the path as the selection, as opposed to the path itself... if that makes sense, sorry if I'm not being clear.
n°2645
Posted on 07-29-2008 at 09:31:18 AM
Make it anywhere and of any size :wink:
Make sure that the path you make is a closed one , after doing so right-click on the path (with the Pen tool selected) and select 'Make Selection'
I use two ways for this:
1. Select the layer and pres Ctrl+T now give its co-ordinates as X= 1/2(Width of the canvas) , Y= 1/2(height of the canvas) in pixels.
2. As you create ny new document , fill a layer with any color and select the 'Move Tool (V)' , enable 'Show Bounding Box' option from 'Options Bar', this will bring a cursor at the center of the document , no press 'ctrl+R' and bring a vertical and a horizontal ruler at the center of the canvas (view this ) :wink:
You should use 'Shape Tool' for making the circles :oui:
n°2649
ghostnatyphon
Who Dares Wins
Posted on 07-30-2008 at 02:18:31 PM
Well after some toil and trouble, I managed to finish it, and I'm fairly happy with the result:
http://i184.photobucket.com/albums/x1/darthsmall9/CDPNG.png
I did however not use the gloss layer, as I found that actually made the CD darker, and I didn't get the rainbow right as I just ended up with a vaguely coloured blur... I drew the rectangular selection as just a box on the cd, and then after the pinch and gaussian blur I ended up with a dark splodge... ah well. But other than that... not bad :tongue: And I had to guess the outer glow on the ring layer as I still can't see the picture for it :frown: But it didn't seem to work anyway :err:
n°2650
Posted on 07-30-2008 at 04:00:29 PM
Nice outcome :smile: , I explained as clearly as I could in the last reply :oui: , if you still have some problems then you can download the PSD file :wink:
n°2651
ghostnatyphon
Who Dares Wins
Posted on 07-30-2008 at 04:16:21 PM
Thanks for the PSD Asher, that makes you the second person to have to give me one because I didn't quite get a tutorial :tongue:
Still I think having to adapt mine to get the outcome probably helped me in some ways, having to mess around to get effects and such ^^
I'll have to make some icons and post soon.
Brilliant tutorial btw, cheers  :great:
n°2654
design maker
don''t waste time, be active!
Posted on 08-03-2008 at 12:49:57 PM
Nice & easy tutorial :great:
n°2658
ghostnatyphon
Who Dares Wins
Posted on 08-05-2008 at 10:14:43 PM
And yet, no result :wink:
n°2659
design maker
Posted on 08-06-2008 at 02:21:59 PM
Ghost :he: , actually i make cd only in illustrator :smile:
n°2718
iraqia
Posted on 08-20-2008 at 04:44:48 PM
:party:  nice tutorial
thanx  :happy2:
n°2803
Tanvir2020
Posted on 09-15-2008 at 01:52:58 PM
Nice Tut.............. :great:
n°2805
ghostnatyphon
Who Dares Wins
Posted on 09-15-2008 at 10:16:24 PM
No results? :frown: You're all so boring :tongue:
n°2806
x3lumin8x
Posted on 09-16-2008 at 12:44:49 AM
:whistle:
http://i241.photobucket.com/albums/ff94/x3lumin8x/cd.png
n°2807
Tanshin
Posted on 09-16-2008 at 01:03:14 AM
Nice one x3lumin8x, very realistic. However it looks like the bottom is cut off a touch.
I tried a few modifications on mine:
Basic Disk:
http://i15.photobucket.com/albums/a398/saladbar1/Disks/Basic.png
Blue-Ray:
http://i15.photobucket.com/albums/a398/saladbar1/Disks/bray.png
CD-R:
http://i15.photobucket.com/albums/a398/saladbar1/Disks/cdr.png
DVD-R:
http://i15.photobucket.com/albums/a398/saladbar1/Disks/dvdr.png
DVD-RAM:
http://i15.photobucket.com/albums/a398/saladbar1/Disks/dvdram.png
The lost HD-DVD:
http://i15.photobucket.com/albums/a398/saladbar1/Disks/hddvd.png
 Page :  1  2  3  4
Top
