22 unknown users
 Page :  1  2  3  4
Previous
[Photoshop tutorial] Make a CD icon
n°1310
Posted on 05-02-2007 at 01:24:23 PM
I have written this tutorial in accordance with the request made by simonxp but I am sure that it will come in handy to others also .
This tutroial leads to a result similar to this image:
http://img299.imageshack.us/img299/5662/finalresultbr2.png
1. Open a 256 by 256 px transparent background document.Select the Shape Tool (U) and make these settings in the Options bar:
http://i36.tinypic.com/5yi5tt.jpg
2. Create a circle covering about 90% of the canvas , place it at the center (X:128 , Y:128) and name this circular shape layer as Base.
3. Go to the Blending Options of Base layer and set these settings in their respective options:
http://i33.tinypic.com/2n04i2p.jpg
http://i34.tinypic.com/10n9mr7.jpg
4. Keeping Ctrl key pressed , click on Base layer in the layer palette to load its selection and then create a new layer (Ctrl+Shift+N) , name this layer as Shine.Fill the selction on the Shine layer with any color.
5. Set the Fill Opactity of Shine layer to 0% then go to its Blending Options and make these settings:
http://i35.tinypic.com/2v19j0y.jpg
6. Create a new layer (Ctrl+Shift+N) and name it Rainbow.Get the Rectangular Marquee Tool (M) , draw a rectangular selection and place it at the center , fill the selection on Rainbow layer with any color.
7. Go to the Blending Options of Rainbow layer and set these settings:
http://i34.tinypic.com/29qcxn7.jpg
Tip: With the Move Tool (V) selected , you can adjust the position of certain Blending Options which include Drop Shadow , Inner Shadow , Bevel & Emboss and Gradient Overlay .
For the Rainbow layer , adjust the postition of Transparent Rainbow gadient for the colors you prefer.
8. Create a new layer (Ctrl+Shift+N) and merge it with the Rainbow layer.With the merged (Rainbow) layer selected , go to Filter-->Distort-->Pinch and make these settings before applying the effect :
http://img406.imageshack.us/img406/7205/pinchgw3.jpg
Press Ctrl+F two times to apply the Pinch effect twice on the Rainbow layer.
9. With the Rainbow layer selected , go to Filter-->Blur-->Gaussian Blur , before applying make these settings :
http://i35.tinypic.com/qsrq5f.jpg
8. Reduce the Opacity of Rainbow layer to 35-45% . Press Ctrl+T and rotate the layer to an angle of 45 degrees . With the Rainbow layer still selected , Ctrl+Click on the Shine layer and press Ctrl+Shift+I to inverse the selection , press Delete key to delete the selected part of the Rainbow layer . Now your document would look somewhat like this:
http://i83.imagethrust.com/i/1077921/result1.jpg
9. Create a circle about 45% the size of the Base layer with Circular Shape Tool (U) having any color and name it Ring . Place the Ring layer at the center of the document, set its Fill Opacity to 0% , go to its Blending Options and make these settings in the respective options :
http://img168.imageshack.us/img168/6619/ringouterglowoy0.jpg
http://img363.imageshack.us/img363/8474/ringcoloroverlaydq3.jpg
http://i84.imagethrust.com/i/1077733/ringstroke.jpg
10 . Create a circle about 80% the size of the Ring layer with Circular Shape Tool (U) having any color and name it Ring 2 . Place this Ring 2 layer at the center of the document, reduce its Fill Opacity to 0% , go to its Blending Options and set these settings in the respective options :
http://i84.imagethrust.com/i/1077739/ring2coloroverlay.jpg
http://i84.imagethrust.com/i/1077740/ring2stroke.jpg
11. Create a circle about 75% the size of the Ring 2 layer with Circular Shape Tool (U) having any color and name it Ring 3 . Place this Ring 3 layer at the center of the document, reduce its Fill Opacity to 0% , go to its Blending Options and set these settings in the respective options :
http://i84.imagethrust.com/i/1077741/ring3stroke.jpg
12. Create a circle about 50% the size of the Ring 3 layer with Circular Shape Tool (U) having any color and name it Ring 4 . Place this Ring 4 layer at the center of the document, reduce its Fill Opacity to 0% , go to its Blending Options and set these settings in the respective options :
http://i37.tinypic.com/14xf7e8.jpg
http://i35.tinypic.com/nfmwc0.jpg
13. With Pen Tool (P) ,  make a selection like this :
http://i33.tinypic.com/2a4y7nk.jpg
Create a new layer (Ctrl+Shift+N) and name it Gloss , keeping Ctrl+Alt+Shift keys pressed , click on the Base layer to select only that part of the selection which overlaps the Base layer , fill the selection on Gloss layer with any color.
14. Reduce the Fill Opacity of Gloss layer to 0% , go to its Blending options and set these values :
http://i84.imagethrust.com/i/1077763/glosscoloroverlay.jpg
http://i84.imagethrust.com/i/1077764/glossgradientoverlay.jpg
With the Gloss layer selected , Ctrl+Click on the Ring 4  layer and press Delete key.
Here is my result:
You can download the PSD file from here.
Hope you all like it
I am anxiously waiting for your results.
n°1311
Posted on 05-02-2007 at 01:27:14 PM
Wow thank you ASHAR! :great: I'll try it later for sure. :wink:
n°1312
Azzurra
Posted on 05-02-2007 at 01:33:40 PM
Nice tutorial, thanks. :great:
n°1313
Tatice
Borsalino Gang
Posted on 05-02-2007 at 01:36:37 PM
Nice result. :love: :smile:
n°1314
cisoun
Pingouin libre
Posted on 05-02-2007 at 01:36:48 PM
Nice result! :loveit:
But you forgot to cut the reflection on your Cd's hole!  :boulay:
(excuse for my bad english!  :wink: )
n°1315
CustMax
Posted on 05-02-2007 at 01:38:50 PM
Good  :great:  but I havn't got Photoshop  :cry:
I think you should write it is a photoshop tutorial in the title :wink:
n°1316
Posted on 05-02-2007 at 01:44:47 PM
Why don't you download a trail at Adobe's website, then you're able to decide if you like it good enough to but it.  :great:
Topic title edited.
n°1317
Youkaïdi, youkaïda.
Profil: Animateur
Posted on 05-02-2007 at 01:47:54 PM
Topic title edited.
But not free ! :whistle:
Thanks for this tutorial ASHAR :great:
Nice job :wink:
n°1318
Posted on 05-02-2007 at 01:49:41 PM
Cisoun: Thanks for reminding me , I have edited the tutorial.
Gruzz: Thanks for making corrections.
7 replies and no any result  :ouch: .
n°1319
Youkaïdi, youkaïda.
Profil: Animateur
Posted on 05-02-2007 at 01:51:47 PM
6 replies and no results cry.gif .
Sorry, but I don't got time to make an CD icon :oups:
Tomorrow, School :cry:
n°1320
negaca17
Profil: Top Penguin
Posted on 05-02-2007 at 01:52:49 PM
realy great tutorial !!! i need that one to make a itunes icon !!  :great: thanks !
n°1321
CustMax
Posted on 05-02-2007 at 01:53:33 PM
Topic title edited.
+1  it is not free and I have already download the trial version and that is expired  :ouch:
It is too expensive for me and especially I am bad in graphism
n°1322
Posted on 05-02-2007 at 02:03:10 PM
You can easily learn it! :smile: You can download and find more information about The GIMP here, it's 100% free. :smile:
n°1323
CustMax
Posted on 05-02-2007 at 02:05:51 PM
Thank you but it is in English  :ouch:  too many english  :mdr:
PS: I'm french  :biggrin:
n°1324
Youkaïdi, youkaïda.
Profil: Animateur
Posted on 05-02-2007 at 02:06:18 PM
Yeah, but for this tutorial...? :mdr:
Stop flood :whistle:
n°1325
Nagaya
Posted on 05-02-2007 at 02:12:19 PM
WOW...ASHAR strikes again. Thank you very much!  :great:
n°1327
Posted on 05-02-2007 at 03:28:29 PM
I know you're French. There's a French The GIMP site, visit it here! :smile:
n°1330
Bumpy
Toi, je t'adore
Posted on 05-02-2007 at 03:54:10 PM
Great tut ASHAR.  :great:
n°1331
simon.maildude@gmail.com
Posted on 05-02-2007 at 04:10:03 PM
Thanks ASHAR!! Maybe someone should  :lock: the topic in Graphics Novice Corner? :neutral:
n°1332
Posted on 05-02-2007 at 04:11:38 PM
Nah, people can have more questions regarding the same subject. Topics are only closed when the discussion should be stopped.  :great:
n°1338
troyenne
Loubna
Posted on 05-03-2007 at 07:59:39 PM
Good job, I will do it later !
n°1339
Posted on 05-04-2007 at 12:17:25 AM
ARRRGH!  :cry: I don't know the pen tool!!!  :cry:  :cry:  :cry:  :cry:
n°1340
Posted on 05-04-2007 at 08:55:55 AM
The Pen Tool might be hard to understand at first sight, but it's actually easy and very clever. You can find a good tutorial about it here, it covers all the basics!  :great:
n°1341
Nagaya
Posted on 05-04-2007 at 09:22:55 AM
hi i tried to make the CD icon.
this is the result::::!  :happy2:
http://i170.photobucket.com/albums/u248/nagayanobu/CDICON-ByNagaya.png
n°1342
Posted on 05-04-2007 at 09:27:01 AM
Looks nice Nagaya! The only thing that you've to work on is the inner circle. You can see there's a lot of aliasing there. :great:
 Page :  1  2  3  4
Previous
Top
