coutinho Windows Customization & Support : sambbk and 21 unknown users
[Photoshop tutorial] Make an Aqua Orb
n°1270
stas92
Posted on 04-05-2007 at 10:12:57 PM
http://www.youtube.com/watch?v=XHjIhzbo8QE
video explonation
1] new document 500X500 px
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/1.jpg
2] select elliptical marquee tool, then hold shift and draw a circle
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/2.jpg
3] create a new layer and fill it with baby blue color
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/3.jpg
4] goto select>modify>contract by 5
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/4.jpg
5] create a new layer and select gradient tool
6] make the gradient from the the baby blue color (the one you used before) to a navy blue color
7] fill the selection from up to down
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/5.jpg
8] create a new layer, select the elliptical marquee tool and while pressing alt, deselect most of the circle, just leave a smilly like selection on the botom
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/6.jpg
9] than goto select>feather by 15
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/7.jpg
10] fill the feathered selection with sky blue color
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/8.jpg
11] create a new layer and use the elliptical marquee tool to make a oval on the top part of the orb
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/9.jpg
12] select the gradient tool and fill the selection with white to transperent
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/10.jpg
13] set the opacity to 90% and add a filter>blur>gaussian blur
 to 0.5
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/11.jpg
14] delete the background
http://i72.photobucket.com/albums/i163/stas92/aqua%20orb%20tut/12.jpg
15] good luck
tell me wht u think
n°1271
Posted on 04-05-2007 at 10:21:21 PM
The video isn't very clear for me. Maybe you could better use images in your tutorial instead of a video!  :oui:
n°1272
stas92
Posted on 04-05-2007 at 10:26:37 PM
shure hold on let me update
n°1273
Posted on 04-05-2007 at 10:28:54 PM
Ok. I forgot: Welcome to CrystalXP! :smile: Thank you for your contribution!  :loveit:
n°1274
stas92
Posted on 04-05-2007 at 10:55:48 PM
updated
and thx ^^
n°2477
Jopaulussen
Posted on 06-19-2008 at 10:52:40 PM
very good tut.
good explaining
this is my result :meuh: :happy2:
n°2482
Posted on 06-21-2008 at 09:51:55 PM
Nice result. :oui: Welcome to CrystalXP. :wink: Please have a look at the rules. I will edit your avatar for you now though. I don't feel it's very appropriate for the forum. :smile:
n°2492
black1cat
Posted on 06-23-2008 at 02:16:05 PM
Nice tutorial :great:
My result:
http://www.crystalxp.net/forum/uploads/sm/monthly_06_2008/post-269682-1214223210_thumb.png
n°2502
techabhi
Posted on 06-28-2008 at 08:02:28 AM
vry nice explanation... :great: :great:
Thx:D
n°2514
Aelitafan13
Posted on 07-02-2008 at 04:57:46 PM
Very Nice tutorial. :wink:  How do I delete the Background??
n°2515
Posted on 07-02-2008 at 04:59:16 PM
I'm not sure either. Perhaps you can just start with a transparent background? :oui: It's an option to choose from when you create a new document. :smile: If you want a white canvas, just create a layer first and fill it with white.
n°2516
Aelitafan13
Posted on 07-02-2008 at 05:06:19 PM
I just figured it out... by accident ^^ What I did is I right clicked (with the move tool) on layer one and selected Background. Then I just deleted the new Background layer. Isn't that so strange??
Edit: Here's my result  :boulay:
http://i289.photobucket.com/albums/ll221/Aelitafan132/Orb.jpg
n°2517
Posted on 07-02-2008 at 05:37:30 PM
Nice result, but it's not transparent? :neutral: Well not sure if you where after that of course! :smile: I think your light blue outline could have been a bit better. :oui:
n°2519
Aelitafan13
Posted on 07-02-2008 at 05:56:07 PM
Well, it was transparent IN CS2.
n°2520
Posted on 07-02-2008 at 06:03:33 PM
Ah I see what the problem is. You saved the file as a .jpg file. :oui: To keep transparency, you will have to save in an other format. Preferably as a .png file. :wink:
n°2521
Aelitafan13
Posted on 07-02-2008 at 06:05:50 PM
Ahh, your quite right. Thankz for the info ^^ :happy2:
n°2551
yakashi
Posted on 07-09-2008 at 11:31:22 AM
Hi thanks for the useful tut  :loveit: here it my result  :great: hope you guys like it
http://img339.imageshack.us/img339/3755/tyakumo891au1.jpg
n°2576
KhainDesign
Posted on 07-12-2008 at 10:41:13 PM
Hi! cool tut :biggrin: and also useful. But i do near the same in Adobe Illustrator. I'lll upload one soon if i get to that compu. where i made them :smile:
cool results guys!
n°2577
Cerberus1991
Posted on 07-12-2008 at 11:32:20 PM
I'm sure I've seen this tutorial somewhere else before ...
Possibly this one?
[CLICK]
n°2589
Posted on 07-15-2008 at 09:33:12 PM
Cerberus1991, when I click that link, I get the message 'The URL contained a malformed video ID.'. There is already a link to a YouTube video on the top of the first post in this topic, however that link gives me this error 'This video has been removed by the user.'. Perhaps the link you posted here has been working once though. :neutral: Since the images are uploaded on Photobucket, there's no website (and this way, author) to get in touch with. That's why I think we'll just let this tutorial stay unless we find more information in the future. :smile:
Edit: And thanks for your help as always. :angel:
n°2590
Cerberus1991
Posted on 07-15-2008 at 11:08:04 PM
Righto ...
And no problem. :smile:
