Windows Customization & Support : appleandios and 27 unknown users
 Page :  1  2  3  4
Previous
[Photoshop tutorial] Create a Good Radial Effect
n°880
Posted on 01-05-2007 at 12:48:15 PM
This tutorial has been designed in accordance with a request made by Damballa and I am sure it will be useful for others too  :jap: . The tutorial leads to a result similar to this image:
http://img341.imageshack.us/img341/9306/resultbo7.jpg
1. Open a 300 by 100 px transparent document.Fill Layer 1 with any color.
2. Go to the Blending Options of layer 1 and make these settings:
http://img237.imageshack.us/img237/4774/layer1gradientoverlaymf1.jpg
3. Load defaul colors (D) and create a new layer (Layer 2) , fill it with either black or white color (Alt+BackSpace).
3. With the Layer 2 selected , go to Filter->Render->Clouds.
4. Go to Filter->Render->Difference Clouds.Keep pressing Ctrl+F in order to repeat the filter untill u get a nice fusion of white and black color , something like this:
http://img341.imageshack.us/img341/3517/image1hw7.jpg
5. Copy Layer 2 (Ctrl+J) and make the copied layer invisible by clicking on the eye just beside it in the layers window.
6. Select Layer 2 and go to Filter->Blur->Radial Blur and apply these settings:
http://img341.imageshack.us/img341/2945/radialbluraf2.jpg
Press Ctrl+F to reapeat this filter with same settings on Layer 2.
7. Select Layer 2 Copy and go to Edit->Transform->Flip Horizontal.
8. Go to Filter->Sketch->Chrome and apply these settings:
http://img502.imageshack.us/img502/6853/chromeop4.jpg
9. With the Layer 2 copy still selected , go to Filter->Artistic->Plastic Wrap and apply these settings:
http://img523.imageshack.us/img523/6646/plasticwrapqi6.jpg
10. Go to Filter->Blur->Radial Blur and apply the same settings as directed in Step 6 and press Ctrl+F to reapply this filter on the same layer.
11. Finally , set the Blending Mode of of both Layer 2 and Layer 2 copy layers to Overlay.You should have an image somewhat like this:
12. Duplicate Layer 2 copy layer (Ctrl+J) and set its opacity to 50%.Here's my final result with the addition of some supplements:
http://img124.imageshack.us/img124/898/finalresultox7.jpg
Good Luck  :wink:
n°881
Posted on 01-05-2007 at 01:21:43 PM
Thank you very much Ashar! :smile:
n°882
Bumpy
Toi, je t'adore
Posted on 01-05-2007 at 01:26:37 PM
Nice work ASHAR  :great:
Simple, fast and great result (all I like)
n°883
ugurcuk
Posted on 01-05-2007 at 04:54:21 PM
Thank you Ashar! :smile:
n°884
Posted on 01-06-2007 at 03:22:31 AM
Thanks guys for appreciating.Would you like to share your results with others?
I am earnestly waiting for some results.
n°885
Draginol
Posted on 01-06-2007 at 09:34:53 PM
Excellent ASHAR!  I am on my PC now, but when I go on my Mac, I'll see if I can transfer it across.
n°886
dark-boss
Posted on 01-06-2007 at 09:43:27 PM
Nice work! :great:
n°959
C@L
Posted on 02-22-2007 at 11:52:49 PM
nice tut, will come in handy ^_^
n°961
v-nay
Posted on 02-23-2007 at 03:41:11 AM
I've made a similar Effect But i've made two layers, gave them a bit of TWIRL, Flipped the top layer & changed the blend mode to LIGHTEN
Here's the final result, but im new to crystallization, please someone teach me to crystallize the ball in the centre.
http://vinay.byethost33.com/images/photoalbum/21.jpg
n°962
banana.boy
Profil: Top Penguin
Posted on 02-23-2007 at 11:44:01 AM
This is the effect I've been looking for !!!
Thank you very much Ashar !!!
n°963
Posted on 02-23-2007 at 11:50:10 AM
I've seen that background effect before. It comes from another tutorial, if you know where I can find it, that would be nice!
If you want to learn how to crystalize, have a look in this, this, or this topic!  :great:
n°964
dadoux
Posted on 02-23-2007 at 02:58:08 PM
Great effect, and simply, good job :biggrin:.
n°978
Lukas54
Posted on 02-28-2007 at 08:18:14 PM
Nice effect.
Great Tuto  :great:
n°979
Posted on 02-28-2007 at 08:22:59 PM
Show us your results Lukas54! :smile:
n°989
Lukas54
Posted on 03-01-2007 at 05:59:30 PM
I do not arrive the stage 10.
When I merge copy 2 and trace 2 that copy do not walk
n°996
-Shift-
Posted on 03-02-2007 at 06:38:51 AM
great tut!
look at my sig and avtr!!
i love it
n°997
Posted on 03-02-2007 at 08:15:45 AM
It looks very nice! You've improved a lot since you joined CrystalXP. :smile:
n°999
Draginol
Posted on 03-02-2007 at 08:58:27 AM
Indeed. Great work Pirk :biggrin:
n°1017
sabchuphai
Posted on 03-03-2007 at 12:38:04 PM
Here is what I tried making...Looks Cute..! Ehm..! :loveit:
Thanks Ashar for the tutorial.  :oui:
http://i128.photobucket.com/albums/p169/sabchuphai/Sub-radial-effect.png
n°1019
Posted on 03-03-2007 at 03:53:58 PM
Yup, it looks very nice. Remember to use a transparent background!  :great:
n°1022
sabchuphai
Posted on 03-03-2007 at 04:07:17 PM
Oppsie....!   :neutral:
Here is the new one.
http://i128.photobucket.com/albums/p169/sabchuphai/Sub-radial-effect2.png
n°1030
-Shift-
Posted on 03-03-2007 at 08:20:53 PM
Great work sabchuphai!! :party:  :party:
Thanks Sparco and Gruzz! :mdr:
but its because of everyone in this forum that people improve :oui:
and more thanks to all of you that write the awesome tutorials of the english forum, like ASHAR, Sparco and many others, and i show apreciation in part of all us little penguins :penguin:
:jap:
n°1031
Posted on 03-03-2007 at 08:25:57 PM
Thank you! :smile: I wrote a little tutorial too.  :whistle:
n°1032
-Shift-
Posted on 03-03-2007 at 08:44:28 PM
yes sir :lol: ive seen it around but i havent tried it
but bare with me and i shall start this very instant :biggrin:
n°1072
Draginol
Posted on 03-04-2007 at 04:08:05 AM
:jap:
No worries, glad I can inspire you!  Good luck with Gruzz's tutorial.  And Sab that signature is off the scales :666:
 Page :  1  2  3  4
Previous
Top
