| God Of Mana Profil: Penguin | Last message on previous page:
Great tutorial man!!
Nice, but the text reflection should be a little more transparent at the bottom. brush or erase tool maybe?
x3lumin8x Profil: Penguin | Neil wrote :
Ah! Just forgot to add something  You can also use 'Quick Mask' mode with the gradient to reflect any image in any sort of background   But what you present is easier lholmes
Your reflection is wrong. 1st-the surface is very shiny. 2nd-anything you put on a very shiny surface does not fade. You should turn down opecity between 40 and 60% and dont use gradient mask. Different surfaces reflect differently.
codenamem2k Profil: Big Penguin | Seems like you have got a point  | |
Asher Genius is not born , it is made.... Profil: Moderator | x3lumin8x Neil is inactive for a very long time for his medical studies , I think he's not going to edit his tutorial any sooner or even later  | |
ghostnatyphon Who Dares Wins Profil: Penguin Pro | I suspect he only used that as an example to show you could reflect any object on any background. Thankyou lHolmes, I've been looking for this for ages! | |
Frozzn Profil: New Penguin | Very nice and practical. I go to try this . So, here's my try :  The quality isn't good any more . | |
ggarcia30011 Only the ones who fight their whole life shall be Profil: New Penguin | | |
ggarcia30011 Only the ones who fight their whole life shall be Profil: New Penguin | Neil wrote :
hey how does that "quick mask" works?? can you explain how can i use it?? | |
Asher Genius is not born , it is made.... Profil: Moderator | Select the 'reflection' layer and click on the "Add layer mask" button :  With the mask selected , just stretch a white-black gradient on the layer , keeping black color at the bottom and white on top , the mask will cover the part of the layer that's colored black  | |
