| truth ------------------------- Profil: Big Penguin | Last message on previous page: Photoshop supports animations. just slide a reflection layer left to right over any image in consecutive frames. And my sig. and avy. , I did them with Photoshop , not with Imageready.
The-Rabbit Profil: New Penguin | sry but can you tell me what program you are using i was always using paint.net but i've deleted my .net framework and i can't repear it
racterman Profil: New Penguin | | |
the0kenster Profil: New Penguin | can u show me how to do more than stars plz like a penguin playing a video game | |
Asher Genius is not born , it is made.... Profil: Moderator | Welcome to CrXP the kenster  The animation you want is possible in ImgeReady if you use it ingeniously but that would be much different from this tutorial since you will have to make different frames for tux with different arrangements of his body parts involved in the activity  Have a nice stay  | |
KimberleyJo Profil: Penguin | I can get it to make each frame and I can save it with no problem...with one small problem...it dithers real bad and changes the colors on one of the images, what are the optimal settings to use for making a gif with Image ready?
darklady Just remember, art saves lives. Profil: Big Penguin | Best way to do it is create a color table for it to optimize to. (I normally build one by the image in photoshop and save it. then import it into Imageready) By default it uses the last one that was used. | |
Selene Profil: New Penguin | hi! im new in this hole new "crystal xp world"..im completely lost i dont know where and how create animations...mascotas (pets)...icons...wallpapers....etc...is there a program that hasent been downoladed in my pc that camed whith bricopack ??...is there a program i must have to create them????? please somebody help!!! thanx Selene | |
Nope you haven't missed anything from the Bricopack! The Bricopacks don't have to do anything with these tutorials at all. Most of these tutorials are written for Adobe's Photoshop, you can find a 30 day trail on their website. You can also try to use an open source program, for example The Gimp. Welcome to CrystalXP!
Just a bit confused...can you explain that in a bit more detail, I have no clue how to go about this. The image gif I am trying to create is 38 frames long. I know a bit big, but it's for a web site. I'm CS2 stupid, but trying to learn. | |
Ravenheart Profil: New Penguin | | |
darklady Just remember, art saves lives. Profil: Big Penguin | Quote :
In photoshop, go to Image > Mode > Indexed color. Make sure you have it set to 255 colors and hit ok. This will merge all layers. Dont worry about that. After that Image > Mode > Color Table. There is an option on the right side of the little window to save. Remember where you saved it to. Hit undo (making sure you have your layers again) and import back to Image ready. There you can load your color table. (see image) | |
KimberleyJo Profil: Penguin | [citation][nom]DarkLady a écrit[/nom]In photoshop, go to Image > Mode > Indexed color. Make sure you have it set to 255 colors and hit ok. This will merge all layers. Dont worry about that. After that Image > Mode > Color Table. There is an option on the right side of the little window to save. Remember where you saved it to. Hit undo (making sure you have your layers again) and import back to Image ready. There you can load your color table. (see image) Thanks! You're awesome for the help! I'll try again tonight.
bajt Profil: New Penguin | Neil great tut, thanks mate. | |
God Of Mana Profil: Penguin | Hm... the colours are a bit off setting. (yay first post! | |
dura007k Profil: New Penguin | Thnx for this great tutorial Hey Guys look my results, are they good ?
earnur Profil: Penguin | Hey, Yo! That's my first post here. I'm very glad to all of you for these greats tuts guys! Oh, and these are my first projects from couple of Yours tuts   and  Thanks so much 1 more time  Edited: SRY  | |
Rimorox Profil: New Penguin | Thx Niel Great tut it helped me alot  | |
Asher Genius is not born , it is made.... Profil: Moderator | | |
Rimorox Profil: New Penguin | I made both of em here they are:   | |
Gruzz Profil: Moderator | Very nice results Rimorox!  | |
Rimorox Profil: New Penguin | why thank you very much Gruzz!  | |
Aelitafan13 Profil: Penguin | I hate to sound like a noob, but I can't seem to find the Gradient tool in ImageReady CS2. Any Help? | |
Gruzz Profil: Moderator | There's no such thing as a Gradient Tool in ImageReady I believe. You'll have to make it in Adobe Photoshop, and then switch to ImageRaedy. In Adobe CS3, ImageReady no longer exists so I'm not 100% sure.  | |
yakashi Profil: New Penguin | | |
