Neil and 33 unknown users
Previous
[ImageReady tutorial] Create Animation
n°547
Neil
Everyday is a Countdown
Posted on 08-05-2006 at 08:52:06 AM
Well since I modified my avatar and signature last time, I saw that many people wanted to know how I did that :wink:
How I gave such lifeness? So here is the answer in a tutorial :cool2:
Okey lets start the resurrection of our Avatars and Signatures :ar:
First lets add some blinking stars in to our avatar.
Note :ar: To get the successful results, I recommend to use Adobe Imageready CS2
:info: Basically you can follow all this with only Image ready application but since I'm a much addict towards Photoshop I'll use both :mdr:
Hey I forgot to say, a nice music please :lol:
Ok first of all, find a better avatar to add blinking stars or just design one :wink:
http://img205.imageshack.us/img205/5558/allob9.png
http://img204.imageshack.us/img204/9986/1fw9.png
Then go to the layer at the top.
Press Ctrl+Shift+N to create a new layer at the top & name it 'Star 1'
Select a white to transparent gradient and from the gradient type, choose 'Diamond'
http://img204.imageshack.us/img204/9513/2gb2.png
Put a little star in the 'Star 1' layer like this,
http://img230.imageshack.us/img230/7974/3db2.png
Then Press Ctrl+Shift+N to build up anothe layer and name it 'Star 2'
Put another white star in that layer like this (not in the same place as 'Star 1' )
http://img204.imageshack.us/img204/2962/4gf6.png
So then, as for your desire, add many stars as you like, but remember, each star must have it's own layer (a layer must contain only one star)
As for mine, I created nine stars in nine layers
http://img207.imageshack.us/img207/1746/6vi1.png
but in the canvas, they look like this,
http://img204.imageshack.us/img204/7793/5cl2.png
Ok now it's the time to press the magic button :wink:
Switch to Image Ready now
http://img69.imageshack.us/img69/2039/7dz8.png   or just press Ctrl+Shift+M
When you oen the document in Image ready, make sure to open the 'Animation' window
http://img207.imageshack.us/img207/7075/8kr2.png
Let's start working :666:
:ar: First of all select the opasity of the all star layers (Star 1-Star 8) to 0% but Keep the last star layer (Star 9) opasity to 100%
http://img207.imageshack.us/img207/5306/9wq8.png
Go to the animation Window,
Hit Duplicate Current Frame and you'll have another frame
http://img207.imageshack.us/img207/5356/11ax2.png
Go to the Frame No 2 from the Animation Window and there, set the 'Star 9' Opasity to 0% and 'Star 1' Opaity to 100%
In the Canvas It'll look like this
http://img207.imageshack.us/img207/8120/12qi5.png
Now press the Tween Button in the Animation Window :oui: (With Frame 2 Selected)
http://img207.imageshack.us/img207/9747/13hq8.png
In the Tween Parameters, Set the number of Frames to add to 5 (the other parameters are not important to be discussed here)
http://img82.imageshack.us/img82/6789/14bc9.png
Hit 'OK' and you'll see new Five frames between the ones you've edited :smile:
http://img60.imageshack.us/img60/4146/15hy5.png
If you play the animation now,
http://img82.imageshack.us/img82/2607/16bo1.png
http://img209.imageshack.us/img209/3836/1tw8.gif
Ok now, enough with viewing a part :bad: let's finish this :mdr:
Go to the last frame from the 'Animation Window' (Frame 7) and there, hit to Duplicate the Frame.
In the new frame, set 'Star 1' Opasity to 0% and 'Star 2' Opasity to 100%
Tween them now ( :info: you'r previous parameters will be saved automatically. So you don't want to change the number of 'Frames to Add' )
Then Go back to the last Frame,
Set 'Star 2' Opasity = 0%
'Star 3' Opacity = 100%
Repeat this untill you change,
'Star 8' Opacity = 0%
'Star 9' Opacity = 100%
Now there should be 55 Frames in the Animation Window :oui:
If you play the animation now, you must obtain this
http://img204.imageshack.us/img204/5681/2de2.gif
And now Go to File>Save Optimised and give a god damn name to the gif :lol:
Ok It's over now. :smile:
Have some nice coffee till I continue this thread in telling how to get this
http://img204.imageshack.us/img204/7581/sig1dt3.gif
n°548
Draginol
Posted on 08-05-2006 at 09:41:58 AM
Thanks for this Neil, I appreciate this :loveit:
EDIT: I have done the tutorial and it looks mighty fine but it's too large to upload onto CrystalXP.
:loveit:
n°549
Neil
Posted on 08-05-2006 at 09:56:20 AM
You're Welcome Draginol :mdr:
and I hope most of others will also like this :oups:
I'm working with the sig animation :oui: I'll post it soon here :wink:
n°551
Draginol
Posted on 08-05-2006 at 11:00:15 AM
:loveit:
n°552
Neil
Posted on 08-05-2006 at 06:35:38 PM
Good work :great:
n°553
sexbox
Posted on 08-05-2006 at 07:50:50 PM
That is a really nice tutorial.
I liked it.
Actually, I loved it. :smile:
I will post an outcome soon.
n°554
Neil
Posted on 08-05-2006 at 08:07:37 PM
I liked it.
Thanks NanOme, of course I have also used your techniques here :wink:
I'll be looking forward to your result
Off topic :ar: Thread re-named
n°555
Draginol
Posted on 08-06-2006 at 02:19:22 AM
Got any suggestions on how to reduce the size of the .gif?
n°556
Neil
Posted on 08-06-2006 at 09:48:02 AM
Why? what's the problem? :xeyes:
n°557
Draginol
Posted on 08-06-2006 at 10:17:32 AM
Well you see I couldn't upload it as my avatar because it was too large, but I fixed it now.
:wink:
n°564
Neil
Posted on 08-06-2006 at 08:19:07 PM
Nice Avater reflections Draginol and please excuse my delay :oups: I'll post the way how to reflect your signature soon :oui:
n°577
Draginol
Posted on 08-07-2006 at 09:02:49 AM
Great, looking forward to it.
n°585
acdcrocks
Posted on 08-07-2006 at 01:20:49 PM
this is a great tutorial Neil... :great:
I'll post my result soon.... :oui:
BTW...I think it will be better if someone edit the topic title to :" Make animated refl......"
Edit*: My result is my avatar :oui:... The image size got a little too big :cry: , so i had decrease the quality of the image...
n°588
Neil
Posted on 08-07-2006 at 08:26:16 PM
Nice outcome [acdcrocks[/b] :great:
'Give Animated Reflections' is a similer topic :lol:
Well, the size limitation 30KB is for files you're using for avaters from your machine :oui:
Edit*: My result is my avatar .. The image size got a little too big , so i had decrease the quality of the image...
If you have an avater a little more than the mentioned (should be 128x128) you can upload the avater in to the web and then give the link
n°595
Draginol
Posted on 08-08-2006 at 11:15:49 AM
TIP: If you want an excellent quality .GIF it is going to be big :oui:   So what I did was used a service like ImageShack hosting to upload an image and then use the 'URL' option in the avatar settings to use it from there :wink:
Enjoy :happy2:
n°601
de lioncourt
Posted on 08-08-2006 at 01:25:14 PM
ok... i couldnt resist myself to try this.. lol... :lol:
please not that its still done with image ready 7 .. (Crap)..  :he:
and please continue with the tutorial about the bar effect, im done with my coffee  :lol:
n°602
acdcrocks
Posted on 08-08-2006 at 02:51:02 PM
Great outcome de lioncourt :great:  :oui:
I'm shure Neil is sweating over his keyboard to finish the next part of the tutorial...  :lol:
n°603
Neil
Posted on 08-08-2006 at 08:03:41 PM
Nice animation de lioncourt
Quite right acdcrocks but it keeps enlarging :lol:
you see I had this nice idea of getting another nice animation specially got signatures which I saw from a local TV program
So I'm trying to make a tutorial to show how to do both of them :oui:
n°610
Draginol
Posted on 08-09-2006 at 10:25:50 AM
Can't wait for this :jap:
n°624
Neil
Posted on 08-09-2006 at 07:53:52 PM
Post Edited :ar:
Ok this is one way to add a reflecting line in to your Signature :smile:
First, Select your signature or userbar.
http://img198.imageshack.us/img198/3638/1hx1.png
Then Create a New layer over the current layer(s) and name it 'Ref line'
Now select White to Transparent gradient and select Reflected Gradient Type
http://img207.imageshack.us/img207/7507/2eh6.png
Now click on an area like the green dot in the picture and drag the mouse in the direction of the red arrow. (You can customize your reflected lines as you like I'll give you samples in the end)
http://img54.imageshack.us/img54/5328/3rm9.png
Then you'll have a Ref Line like this
http://img196.imageshack.us/img196/4055/4nt5.png
Now Create another new layer and fill it with any color you want :mdr:
Go to the Layers window and reduse the new layer's Color fill to o%
Now go to that layer's blending options and give the following parameters
http://img529.imageshack.us/img529/7352/9py0.png
Now you'll obtain this
http://img204.imageshack.us/img204/6369/5wg1.png
:info: You can change the Fill Type and the color according to the
main color in your Signature or User bar.
Try to give a color darker than the one in your creation
Now Switch to ImageReady
Select the 'Ref Line' and move it out of the Left Edge of the canvas
your 'Ref Line' should be placed like this
http://img106.imageshack.us/img106/4658/6xn7.png
The blue rectangle is just a reseblance to show you where the layer should be & it won't be shown in your design area
Now click Duplicate Current Frame button in the Animation Window & go to frame 2
There, Move the 'Ref Line' layer out of the Right Edge of the canvas.
http://img56.imageshack.us/img56/9008/7du7.png
Now Hit Tween button
Set the Frames to add to 20 or 30
http://img177.imageshack.us/img177/7139/8jm1.png
Hit Ok
Now play the animation.
http://img142.imageshack.us/img142/8931/sig6cv8.gif
So enjoy the animated reflections :loveit:
n°625
sexbox
Posted on 08-09-2006 at 09:23:02 PM
Woah. Nice tut! I love you. :smile:
n°626
Neil
Posted on 08-09-2006 at 10:04:13 PM
Thank you NanOme :loveit:
Additional:* :ar:
You can Improve your work like this :ar:
http://img90.imageshack.us/img90/4099/neil13wl8.gif
n°627
Draginol
Posted on 08-10-2006 at 12:11:46 AM
Nice :great:
http://www.crystalxp.net/forum/uploads/sm/post-14373-1155161487_thumb.jpg
I just worked with yours...
n°628
Neil
Posted on 08-10-2006 at 08:31:03 AM
Good :cool:
Now you can work on your signature :lol:
n°630
Draginol
Posted on 08-10-2006 at 12:03:02 PM
:lol: I did it before but I've taken on a new style now.  Just nice simple 3D text, a little like Azzuro, he's is sweet.
Previous
Top
