Great tutorial dude I'll try it, and post my results soon!!!
liam3006
Posted on 09-26-2008 at 11:16:04 PM
This is my attempt great tutorial btw
tassam
Posted on 10-05-2008 at 04:45:21 PM
i knew it how they make them... they are simple... VERY SIMPLE!
but thanks to you, you made me try to make one ^^
ghostnatyphon
Who Dares Wins Profil: Penguin Pro
Posted on 10-05-2008 at 05:13:27 PM
Welcome to CrystalXP Tassan
Perhaps you could show us your result? then we can help you to get better
If you need your name changing you'll need to ask a moderator, or better, an admin
tassam
Posted on 10-05-2008 at 05:51:55 PM
Thanks ^^ [[for writing tassan as well]]
what do you say?
Posted on 10-05-2008 at 07:30:08 PM
Changing names is no longer done I believe. Although an exception is sometimes made when you are an experienced/longer forum member. But that will still take a while before you get there.
I think the first two of your user bars a bit too bright. The third one is looking better.
tassam
Posted on 10-05-2008 at 07:53:16 PM
they are looking bright because of the gradient in stroke XD
i liked it that way!
Posted on 10-05-2008 at 08:17:31 PM
Well that's al right but I was talking about the text mainly. It became pretty much unreadable.
codenamem2k
Posted on 10-08-2008 at 01:10:35 PM
How's mine???
cradłe
Cradle-desktop@ubuntu:~$ whatis windows Profil: Penguin Pro
Posted on 10-08-2008 at 01:12:45 PM
How's mine???
The font isn't readable.
codenamem2k
Posted on 10-08-2008 at 01:29:05 PM
Well, the tutorial specified to use the Visitor font I used it, and ended up with this
tassam
Posted on 10-08-2008 at 02:24:43 PM
i recommend adding horizontal scale or changing font
