21 unknown users
 Page :  1  2  3  4  5  6  7
Previous
[Photoshop tutorial] Crystalised World
n°396
Neil
Posted on 07-06-2006 at 06:47:03 AM
Ok then let's follow a very easy and simple tutorial to make crystalised World globes :wink: (World Globes with reflections) :penguin:
First find a world map you wish to use for the globe :oui:
Then Open a new Design canvas (256x256 pix) in Photoshop. and place your picture (map) as a layer.
Select Eleptical Marque tool and drow a Circle while pressing Shift key
http://img448.imageshack.us/img448/8168/17se.png
http://img448.imageshack.us/img448/3869/21te.png
Then, press Ctrl+Shift+I to invert selection & select the map layer,
Hit delete.
Extra:* If you need go to Filter liquify and use 'Bloat tool' to make the selected part of the map looks like a part of
a sphere :wink:
Press Ctrl+Shift+I again to return to normal selection don't deselect it.
Press Ctrl+Shift+N to create a new layer and place it above the map layer, then select the overlay mode for the layer.
Select Black to transparent gradient and drow it from the bottom to top of the selection.
http://img226.imageshack.us/img226/4097/31wp.png
Contract the selection by 2 or 3 pixels (Select>Modify>Contract)
Create another new layer, and drow a white to transparent gradient from bottom to top.
then press 'M' to return to marque tool and move the selection upwards.(like in picture)
http://img385.imageshack.us/img385/9493/46om.png
Hit delete. & Set an opacity around 30%-40%
Then in a new layer above all, drow another marque selection like this,
http://img96.imageshack.us/img96/6788/55jp.png
Then drow a white to ransparent gradient from top to the bottom of the selection
Set opasity of the layer to 75%
Ctrl+Shift+N to Create another new layer and Ctrl click on map thumbnail to select the border,
Expand the selection by 3 pixels.
Fill the area with White (#FFFFFF)
Contract the selection by 4 pixels and hit delete.
apply a gaussian blur 4 pixels (maybe vary)
Ctrl click again on the map layer, Then press iCtrl+Shift+I to invert selection and hit delete. (you can do the same thing by applying an 'Inner glow' effect to the map layer :wink: )
So now you've finished with the crystalised Globe :whistle:
http://img90.imageshack.us/img90/8206/64af.png
You can add different reflection styles and different maps to customize your collection of world globes. :party:
Here is a sample :smile:
http://img321.imageshack.us/img321/2001/pre3dw.png
Guys, (& ofcourse girls :biggrin: ) what do you think?? :xeyes:
P:s: and feel free to correct my mistakes or post other easy way to do this. :loveit:
n°397
4.9
Posted on 07-06-2006 at 07:56:49 AM
Great tut! Now I can try to make a crystal FireFox to go with the globes.
n°399
sexbox
Posted on 07-06-2006 at 10:06:19 AM
Damn, that is really hot, mate!
Good work, will help many for sure! :biggrin:
n°402
Neil
Posted on 07-06-2006 at 10:42:44 AM
Thank you guys I also hope the same :loveit:
And Nan0me, Welcome to CrystalXP :angel:
n°405
alyxxs
Posted on 07-06-2006 at 03:12:56 PM
thanks Neil, great job :loveit:
n°406
Azzurra
Posted on 07-06-2006 at 04:37:07 PM
Nice Neil :great:
n°407
spydark324
Posted on 07-06-2006 at 04:45:09 PM
It is wonderful  :biggrin:
Now I know how do a globe easier.
n°408
Nelson
Posted on 07-06-2006 at 05:14:51 PM
Nice tutorial  :great:
n°409
Skynix
Profil: Top Penguin
Posted on 07-06-2006 at 05:17:33 PM
Nice job Neil !  :great:
n°410
sexbox
Posted on 07-06-2006 at 05:25:06 PM
Thank you. I like this place, and looking forward to the Apple Tux tut too.  :loveit:
n°411
Neil
Posted on 07-06-2006 at 08:34:31 PM
Well thank you all for your kind words :loveit:
like I said in the tuto we can customize the reflection and other effects we use :wink:
So here are some more to the globe collection of mine :mdr:
http://img341.imageshack.us/img341/5200/23rt.png
and among my globes these were my favourites. I've used many different ways in reflections :wink:
http://img226.imageshack.us/img226/7803/15ls.png
And friends, post your designs on globe crystalization here too. don't be shy, share them with us :loveit:
Edit:*  to 5.0, dear friend, your signature is above the limits of this site please reduse its size. thanks :wink:
Your signature should not be more than 280x70 pixels and                should not exceed 20Kb. If you use an image in your signature, DO                NOT add too much text below.
n°412
Neil
Posted on 07-06-2006 at 09:53:41 PM
Edit again:* acdrocks, I've modified the globe you've posted and  included some reflections too but I was unable to remove the triangular  shaped reflection done by you since it's a png format. So it may make little unfit :biggrin:
http://img237.imageshack.us/img237/2800/acd1ex.png   World globe by acdrocks (modified by Neil)
And those who in need, here are some world globes :wink:
World_Globes.zip
n°413
Pyro
Posted on 07-06-2006 at 09:56:21 PM
That's incredible Neil ! Good Tutorial ! Nice Job !  :great:   :great:   :great:
n°414
Neil
Posted on 07-06-2006 at 10:12:41 PM
Thank you Puma, :loveit:
n°415
banana.boy
Profil: Top Penguin
Posted on 07-06-2006 at 10:55:23 PM
Good tutorial.  :great:
But I like to create my own planets :
http://upload4you.free.fr/20060706224809.png
Is there any way I could make a (french) tutorial about "How to make your own glossy planet" ?  :neutral:
I would quote your tutorial anyway.  :biggrin:
PS : If this tutorial already exists on CrystalXP, then...  :cry:   (<-- Not enough vocabulary :lol: )
n°416
Neil
Posted on 07-07-2006 at 11:03:53 AM
Is there any way I could make a (french) tutorial about "How to make your own glossy planet" ? Neutral.gif
Sure friend, :loveit: No problem. :wink:
n°417
banana.boy
Profil: Top Penguin
Posted on 07-07-2006 at 11:17:39 AM
Thank you very much, the tutorial will be there soon.  :great:
n°418
Neil
Posted on 07-07-2006 at 11:54:59 AM
You're Welcome :loveit: and I'm looking forward for the tutorial :wink:
n°419
alyxxs
Posted on 07-07-2006 at 05:51:23 PM
here is my result :lol:
n°420
acdcrocks
Posted on 07-07-2006 at 06:46:02 PM
Great tutorial Neil!!! :great:  :great:
Here's my result:
http://img408.imageshack.us/img408/6908/crystalglobe1ak.png
n°421
banana.boy
Profil: Top Penguin
Posted on 07-07-2006 at 07:04:25 PM
New version.
http://pix.nofrag.com/a5/73/74dd61174ef1d03fde4391e9c132.jpeg
n°422
Neil
Posted on 07-07-2006 at 07:59:58 PM
Nice designs guys :cool: I'm so glad to see them :wink:
And Banana.boy, I'm willing to see your tuto, Your New version is a great evolution. :great:
n°423
vIcO
Posted on 07-07-2006 at 08:07:48 PM
Very nice tut Neil :great:
But I think you can add a shadow to you Globe  :oui:
n°424
Neil
Posted on 07-07-2006 at 08:15:09 PM
Thanks vIcO :loveit:
Yes, I'll post that soon :cool: Thanks for the hint :mdr:
n°425
banana.boy
Profil: Top Penguin
Posted on 07-07-2006 at 08:35:34 PM
Well I posted it hours ago and it's still not here.  :cry:
But my tutorial just shows how to do this :
http://pix.nofrag.com/0c/23/c0bab7fe4b588dce898ba8b28542.jpeg
I prefer my "New Version" so I will edit the tuto I think.  :beurk:
Damn...  :non:
Previous
Top
