How To Make Animated Text / Signature - Video Tutorial
thetmyster
Life is a maze, Love is a riddle Profil: Penguin Pro
Posted on 02-03-2009 at 08:13:23 PM
I did my best so that you can see the actual screen
In 720p HD
Result ~~
Message edited by thetmyster on 02-04-2009 at 08:01:38 PM
Glomping the internet populace.One forum at a time.
uttaresh
The Penguin Master Profil: Penguin Pro
Posted on 02-03-2009 at 09:13:59 PM
Cool! May I ask which application you are using to record the video, and if it is free -- where can I download it?
thetmyster
Posted on 02-03-2009 at 10:40:45 PM
I Used Camtasia Studio 6 With Quiktime In 720p HD
Camtasia is not free... what do you think of the final outcome?
KhainDesign
Posted on 02-04-2009 at 02:44:38 AM
not bad....
the video is good, but the thing, you create would be a bit more difficult...i'll post my result here soon....
uttaresh
Posted on 02-04-2009 at 01:14:36 PM
A piece of advice: Be brief, be quick, be decisive. Your tutorial takes too long - almost ten minutes! For a task as simple as animation, your tutorial ought not to be more than 3-4 minutes long.
Other than that, I like the result ... especially the "Oh yea" one.
thetmyster
Posted on 02-04-2009 at 02:19:11 PM
Ok ill try to make it faster it was originally 5 min but my " )$DMEI£*%R Pc Kept crashing during the original recording hopefully il be switching to a mac soon
any results?
KhainDesign
Posted on 02-11-2009 at 07:30:54 PM
(off:
i've heard a lot bad things about the mac... :S so if you buy a macPro, use windows on that too... the Mac Os doesn't run a lot of mac-converted programs smoothly... so tho Maya and the PS do have some lagg on Mac, doesn't matter the system config... :S correct me if not!
Sorry for the off.... )
uttaresh
Posted on 02-11-2009 at 09:52:32 PM
I think Photoshop was originally built for Mac, so it's actually converted for Windows, not vice-verse. Correct me if I'm wrong.
Posted on 02-12-2009 at 08:01:49 AM
In my opinion the Mac OS works perfectly. Everyone can have his or her own opinion of course. Photoshop version 1 was indeed for the Mac. Although I don't want to speak of the Windows version as a 'conversion', it's been made from the ground up I believe.
Anyway, you can run Adobe software perfectly on the Mac without any problems. 3D programs should work fine as well.
thetmyster
Posted on 02-13-2009 at 10:27:52 PM
Well i do have an old mac G4 and compared to a newer Intel 2.3 ghz to powerpc (677mhz?) and 1 g of ram on both the mac is smoother and more relyable than the pc but pc is better with large images (40/50 m)
KhainDesign
Posted on 03-07-2009 at 11:00:39 PM
wow... than i don't know why did that guy told that... my old dream is a MAC pro, and he totally broke it... and it's cool to hear the good news
