Windows Customization & Support : petit black and 21 unknown users
Question on round corners
n°3623
RDXDukeOfHazard
Posted on 12-10-2008 at 02:16:08 PM
I for some reason always seem to have difficulties with round corners, they just don't come out like I want them to? Is there a tutorial or if not someone maybe could make a quick one, cheers.
n°3624
uttaresh
The Penguin Master
Posted on 12-10-2008 at 03:17:40 PM
What do you mean? They look fine in your avatar and sig. :)
Basically you either use the Pen tool to create a custom shape -- or you simply take the Rectangle tool, use the Ellipse tool to make a circle on the corner, inverse the selection, and delete/erase the part you don't want. ;)
One forum at a time.
n°3625
Tanshin
Posted on 12-10-2008 at 07:37:43 PM
Or another thing you could do is use the rounded rectangle tool to make a shape or path and then select the path, inverse, etc like uttaresh said.
You can also change how rounded the corners are in the Radius option box
http://i15.photobucket.com/albums/a398/saladbar1/mystbar_cxp.png
n°3626
uttaresh
The Penguin Master
Posted on 12-10-2008 at 07:41:33 PM
OMG, how could I forget that. :oups:
n°3631
Posted on 12-12-2008 at 08:20:52 AM
Do you mean that they come out aliased? :)
n°3633
RDXDukeOfHazard
Posted on 12-12-2008 at 04:24:22 PM
Yeah Kind of, sometimes they are. Could be doing something wrong or it may just be in my mind..
There is quite a lot of crap in that mind of mine. :yes:
 :he:
n°3679
codenamem2k
Posted on 01-10-2009 at 06:59:25 AM
Round edged rectangles can be a bit messy at times...
I am with the Duke ;)
