| .drago. I am ALIVE! Profil: Top Penguin | This tutorial has been copied from this website. Please visit the original tutorial - all credit goes to the original creator! 3D Text
Example(s):
The Tutorial:
Step 1: Creating the document and preparing text
Create a new document (File > New) and use any size you want. I'm using 320px x 150px. Next, select a font and type your text. Add any effects you want to the text, such as gradients or colours.
To stretch and transform the text, we need to rasterize it first. To do this, right click the text layer on the layers list, and select Rasterize.
Step 2: Transforming the text
After you have rasterized your text, your ready to transform it. With the text layer selected, press CTRL+T, and press right click in the text then choose perspective or distort to position your text as if it were in 3d perspective, and press Enter to apply the change. You'll want to achieve an effect as shown below. (This will be the top of the 3D text)
Making the text 3D
After you have transformed the text, right click it on the layers list, and press Duplicate Layer. (Alternatively, you could press CTRL+J with the text layer selected.) Now create a new set (see below image), and place your duplicated layer into it. Add a bevel and emboss to the duplicated layer (use the default settings). This will help in achieving the 3D effect.
With the duplicated layer selected, hold shift and press the down arrow 2 times. This will move your text layer down by 20 pixels. Now, hold the alt key and ctrl key and press the up arrow 19 times. This duplicates each layer, and nudges it up by 1 pixel each time.
This is the end of the 3D effect. If you want to add more effects to it, such as reflections and shadows, continue reading.
Step 3: Adding extra effects
Note: These effects aren't needed, but they provide nice details to the final product.
Now that we have the basic 3D effect, we can add more effects to give it a reflection, and an environment. Select the original text layer and add a faint drop shadow to it. Select the layer set, and press CTRL+E (this will merge all the layers inside.) Duplicate the new layer (CTRL+J) which use to be the layer set, and lower its opacity to about 20%. Position it below the 3D text, so it looks like a reflection. There are many tutorials about reflections in our database if you need any more help. On my background layer, I also added a faint gradient instead of just a white backdrop.
Final Result
you can use it too in the shapes
i hope you like it plz reply  Message edited by Gruzz on 10-14-2009 at 09:27:42 PM
darklady Just remember, art saves lives. Profil: Big Penguin | Made a simple avatar using this tutorial! I like it. Good work! (of course I added a few more effects to it)  | |
Asher Genius is not born , it is made.... Profil: Moderator | Nice one DarkLady , may be a bigger image would have allowed us to get a better view  My result  a useful addition to this section  | |
.drago. I am ALIVE! Profil: Top Penguin | thx and nice result DarkLady and you too asher and any can add any effect on it like he or she want i made it with out more effects to be useful for the newbies | |
.drago. I am ALIVE! Profil: Top Penguin | i see that no one more wanna reply plz the replys | |
sensational_one Peace Keeper Profil: New Penguin | Very Nice Thing,I am trying to do that but as a total noob without any help,it may take a little time. Thanks again for 3D Text.  | |
sensational_one Peace Keeper Profil: New Penguin | Sorry for this stupid question.Please tell me how to add gradients to the text. I am using photoshop CS2. Thanks. | |
x3lumin8x Profil: Penguin | Hey Drago. Sweet tut, dude!  | |
sensational_one Peace Keeper Profil: New Penguin | Please Help me,Now I can't add reflection.I am stuck here. | |
x3lumin8x Profil: Penguin | Make sure the reflective layer is under the main text layer | |
.drago. I am ALIVE! Profil: Top Penguin | sensational_one first select the layer u want to put the gradient on it but it must be any but not the background layer then press right click on it then Blending Options then press Gradient Ovarlay it will be like this photo
 i hope u mind it x3lumin8x thx man its your first reply to me | |
sensational_one Peace Keeper Profil: New Penguin | Thanks so much Bro.This is my first...um...uh...well...Something in photoshop. But there is a problem,Dropshadow is showing in reflection too.What can I do? | |
.drago. I am ALIVE! Profil: Top Penguin | sensational_one go on the reflection layer then remove Dropshadow from it u can find it on BlendingOptions | |
Oops ! I think its too late,I can't do this 'cause I Merged all layers with dropshadow,then I duplicated it and used it for reflection. Now the correct thing will be this;before merging all layers with dorpshadow,I should copy a layer without shadow and place it under main layer(Just to know where it is). Now merge all layers but leave the one without shadow intact. Now I duplicate layer without shadow as much as the other layer. Place it as a reflection. Please tell me if I am right. Thanks. | |
.drago. I am ALIVE! Profil: Top Penguin | | |
sensational_one Peace Keeper Profil: New Penguin | Thanks,This time I'll do it right.Can you please tell me about the values you used in dropshadow. Also please tell me where to get the fonts you used in the tutorial and the one you used for preview in the very start of tutorial. This is a great tutorial and it will give me a huge boost to learn photoshop. Thanks again.  | |
.drago. I am ALIVE! Profil: Top Penguin | 1st: its not must to make it like me just play with the values to get a great look 2nd: you can get alot of font like mine i used in the Example and more from here then after u finished show me your work pls | |
Here it is Brother,You like it?
sensational_one Peace Keeper Profil: New Penguin | Also when I use to lower opacity for reflection layer,I use Opacity under Advanced Blending . I almost can't see the reflection layer in the photoshop but when I save work to PNG,it is clear like shown in above post.Is this because I use transparent background?  One more thing,I applied "bevel and emboss" to the duplicated layer but I had to put original layer under duplicated layer AND duplicate it to get this result. This must be because of font and position of text,isn't it? Here is another one in the size of 100x100 for messenger display picture or something like that.  | |
Yes. It's wise to put an extra layer when using a transparent background. Fill this layer with gray, or actually any other color which isn't too dark or light. Now you can see whether the shadow and reflections are correct. Once you want to save, just click the eye before this layer to hide it!
sensational_one Peace Keeper Profil: New Penguin | Hi Brother,I want to say something; If I Add a bevel and emboss to the DEFAULT layer then I should put DUPLICATED layer under it like I did(Plz see the upper two posts of mine). Tutorial says to Add a bevel and emboss to the DUPLICATED layer and place it under DEFAULT layer.Then duplicate it to get 3D effect. Please don't get angry,I am just asking .Which one of them is right? Also Why don't we give Text a glow or crystalline/glass effect. If you tell me how to do it,I can try this.This'll be great. Regards. | |
sensational_one Peace Keeper Profil: New Penguin | Hello Brother,Where are you? You didn't tell me the answers of my questions? | |
.drago. I am ALIVE! Profil: Top Penguin | you are right Gruzz and about your pic. is good sensational_one its nice to know it | |
Boc_est1986 Profil: New Penguin | nothing brilliant but still learning, thanks for the tutorials | |
.drago. I am ALIVE! Profil: Top Penguin | thanks Boc_est1986 for your reply and good result but try to make it a lot because you will make it better in the futer | |
