16 unknown users
[photoshop tutorial] Fire effect
n°4147
willem123
Posted on 06-27-2009 at 05:29:16 PM
Hi everyone,
in this tutorial I will learn you how te create something like this:
http://www.markvanoort.nl/van_willem/marleen.pngor this:
http://www.markvanoort.nl/van_willem/willem_van_oort.png
PART 1
step 1:
create a new document 800x800 with a black background.
step 2:
type your text (T). I used broadway.
http://www.markvanoort.nl/van_willem/tuts/tut1.1.png
step 3:
duplicate both layers.
merge the 2 new layers.
http://www.markvanoort.nl/van_willem/tuts/tut1.2.png
step 4:
go to image > rotate canvas > 90 CW
then go to filter > stylize > wind
tick from the left
then click Ctrl + f 3 or 4 times.
then go to image > rotate canvas > 90CCW
http://www.markvanoort.nl/van_willem/tuts/tut1.3.png
step 5:
go to filter > blur > Gaussian blur
http://www.markvanoort.nl/van_willem/tuts/tut1.4.png
step 6:
go to Hue/saturation (ctrl + U), check colorize!!
http://www.markvanoort.nl/van_willem/tuts/tut1.5.png
duplicate "willem copy" and go to hue/saturation (ctrl + U), do NOT check colorize!!
http://www.markvanoort.nl/van_willem/tuts/tut1.6.png
step 7:
select the top layer ("willem copy 2" ), go to blending options > general blending options > blend mode, change it to color dodge.
http://www.markvanoort.nl/van_willem/tuts/tut1.7.png
step 8:
merge the 2 top layers
step 9:
select the merged layer (the top layer) and go to liquify (Ctrl + shift + X) and model your flames with a brush size of about 20 / 25.
http://www.markvanoort.nl/van_willem/tuts/tut1.8.png
step 10:
get the textlayer to the top.
go blending options > gradient overlay with this settings:
http://www.markvanoort.nl/van_willem/tuts/tut1.9.png
http://www.markvanoort.nl/van_willem/tuts/tut1.10.png
step 11:
merge all layers until now (ctrl+e) (3 in total)
PART 2(only if you want to have "van oort" underneath "willem" )
step 12:
get down the 2 letters ("w and the m" ), by selecting the rectangular marquee tool and select the letter, then press ctrl + T. Press the down and repeat the same for the letter 'm'.
step 13:
now, fill the part that was just made transparent.
http://www.markvanoort.nl/van_willem/tuts/tut1.12.png
step 14:
type "van oort" in between the w and the m.
http://www.markvanoort.nl/van_willem/tuts/tut1.13.png
step 15:
make some blending options you like..... I used:
outer glow;
bevel and emboss;
gradient overlay;
stroke;
satin.
http://www.markvanoort.nl/van_willem/tuts/tut1.14.png
PART 3 (reflection)
step 12:
merge all layers
duplicate the layer ("van oort" or "willem" ).
step 13:
go to edit > transform > flip vertical
You will not be able to see the 1st "willem" any more, so delete that black part
http://www.markvanoort.nl/van_willem/tuts/tut1.15.png
step 14:
go to blending options and set opacity to 10-30
final result:
http://www.markvanoort.nl/van_willem/tuts/final1.png
I hope you understood everything, reactions are always welcome!
Message edited by willem123 on 06-27-2009 at 05:40:13 PM
n°4148
uttaresh
The Penguin Master
Posted on 06-27-2009 at 06:44:02 PM
Very interesting tutorial, though I think I've seen a similar tutorial elsewhere. Is this your own, or have you modified someone else's? No offence intended, but I had to ask.
One forum at a time.
n°4150
willem123
Posted on 06-27-2009 at 07:16:42 PM
Well, I actually learnt it from some other tuts, 3 or 4 I think, and mixed them together....
n°4151
ghostnatyphon
Who Dares Wins
Posted on 06-27-2009 at 07:19:23 PM
There is a fire tutorial somewhere on these forums I think, I remember seeing it... but it goes into more detail about using the liquify effect.
Not a bad tutorial, with a nice effect - slightly more cartoonish than realistic I think :great: Might be helpful to go into more detail with the liquify effect, though it's good for people to have a play :)
Perhaps also using a fading reflection - personally I don't like solid ones, just because I've never really seen any in real life, would have to be one spookily shiny surface :o
http://img693.imageshack.us/img693/1117/april2010sigtest1.png
n°4152
willem123
Posted on 06-28-2009 at 12:19:13 AM
can you give me the URL to it, then?
n°4153
ghostnatyphon
Who Dares Wins
Posted on 06-28-2009 at 06:18:16 PM
Wow, well I'll get back as soon as I find it :lol:
EDIT: I can only find two, and in the French section :/
http://www.crystalxp.net/forum/fr/ [...] 0423_1.htm
http://www.crystalxp.net/forum/fr/ [...] 3380_1.htm
I would have sworn blind there was an English one :/
Message edited by ghostnatyphon on 06-28-2009 at 06:30:28 PM
n°4194
willem123
Posted on 07-14-2009 at 08:58:40 PM
I like mine better :) because these tuts have no text :arf: and I don't understand french very well... :arf:
any results??
n°4195
Posted on 07-14-2009 at 09:00:43 PM
Your images are broken. :angel:
n°4209
RDXDukeOfHazard
Posted on 07-19-2009 at 01:47:05 AM
Yup. :oui:
n°4211
Posted on 07-19-2009 at 09:56:44 AM
RDXDukeOfHazard, your signature is too big. :yes:
n°4299
willem123
Posted on 08-22-2009 at 01:54:12 AM
I'm sorry, I'll solve it as fast as I can!
EDIT: I solved the problem, results are always welcome!
Message edited by willem123 on 08-22-2009 at 01:56:56 AM
n°4392
bhargav
Posted on 11-10-2009 at 03:09:25 PM
hey almost got it except part3
and mixed up alot on my own
http://www.crystalxp.net/forum/mesimages/339537/fireeffect.jpg
n°4426
willem123
Posted on 12-24-2009 at 01:35:12 AM
sorry for the late reaction...
That's a cool one :great:!!
n°4584
xciting
Posted on 09-27-2010 at 09:59:24 PM
good tut buddy
The End iz Beginning Here
